Go Back   E46Fanatics > E46 BMW > Regional Forums > Australia
Australia
Old 06-23-2009, 07:37 PM   #1
Black320i
My Ride: 320i
Tail Light connector problem
Hi All
My tail lights are not working on the left and there is a indicator lit in the dash as well.
I checked the lights and the connector seems to be faulty. Does any body know where i can get that or where should I take it for repair. I have read in general forum's that it should cost $5 or sumthing but dont know where to get it from.
Also if you can recomend any service center near the Parramatta area in Sydney.
Thanks guys
Bob
Black320i is offline   Reply With Quote
Old 06-23-2009, 07:55 PM   #2
t.wak
My Ride: 95 525TDS, 94 525iT
You can buy the parts at your BMW dealer, fairly common so they will have it in stock. Costs more than $5 though.
t.wak is offline   Reply With Quote
Old 06-23-2009, 07:57 PM   #3
Ballistic325
My Ride: slow and steady
Welcome to the BMW family and to the forum Bob
Would have been good driving the car up from Melbourne.
You might like to try Peak in Parramatta - http://www.peakrpm.com.au/
I previously had an E30 323i for which I used Peak to rebuild the engine and upgrade the brakes (ported & polished head, remapped ECU, Alpine body kit, JPS interior, lowered, multispoke wheels and exhaust). They did a great job and were very professional, really know their stuff. From memory Peak is on the expensive side in terms of labour cost.
Is it the connector in the housing or is it the wiring harness? Depending on how bad / what it might be, it may be cheaper and easier to get a replacement cluster. Maybe go LED tail lights? Your first mod! hahaha
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is online now   Reply With Quote
Old 06-23-2009, 09:08 PM   #4
Black320i
My Ride: 320i
Hi Ballistic
Thanks for the number, I just had a chat with peakrpm...they have given me quotes on service
$350 for a minor and $560 for a Major service
Is that sumthing u normally would pay for a service ?
Also they said about the tail light that the whole tail light uinit is to replaced as opposed to the connectore replacement ( which i found on forums as the very common problem with an easy fix)
Any suggestions where else i shld ring for connector ?
And yesh it was great to drive from Melbounre ...the car was so wonderful throughout and I am happy to get it ...
Cheers
Old 06-23-2009, 09:43 PM   #5
Ballistic325
Minor / Major service prices sounds quite good, and I assume they do all the items mentioned in the service book. Nick Peake is ex-BMW service and racing, so he know his way around. Coincendentally he did the work on my E30...
Like what t.wak said, you may be able to get it from your local dealer. Maybe take the car to the parts shop there and ask them? Or... I'll come by tomorrow night and see what the problem is and work it out from there.
Worst case, we make a temp solution until you can some LED tail lights
I can help with
* RTABs
Old 06-23-2009, 11:07 PM   #6
Black320i
My Ride: 320i
I have booked in for Saturday. Have to get the Pink Slip done as well ...and mite need to fix the tail lite b4 the pink slip.
RTA closes at 12 on saturday so that would be a bit of rush ...
LED tail lights ---- sounds like fun
Old 06-24-2009, 12:24 AM   #7
t.wak
Seriously, BMW parts department can sell you parts for your car.
Old 06-24-2009, 12:55 AM   #8
bobz
My Ride: 0 BMW's
NO they only rip you off and destroy your beautiful car
You should go to other places to get your work done dont listen to t.wak hes a part of the conspiracy....
I think I need to take my happy pills again....
See you soon my car will be there soon for 2 or 3 days...
Hope you enjoyed the joke.... t.wak
BobZ
"Little knowledge is Very Dangerous"
bobz is offline   Reply With Quote
Old 06-24-2009, 01:25 AM   #9
t.wak
What's wrong with your car Bob?
Old 06-24-2009, 01:28 AM   #10
bobz
My Ride: 0 BMW's
Front oil seal, trailing arm bushes and in between oil change.
And maybe the guibo?
BobZ
connector, parramatta, service, tail light
