Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 06-28-2009, 10:10 PM   #1
NightWolfe
My Ride: 02' 330CI
Soundstream Subs & Amp
(2) Soundstream 10" Subs - $100
(1) Soundstream 520Watt 2 Channel Amp - $150
(1) Ported Box 30" x 16.5" x 13" (inc Beauty Bord for e46) - $200
Prices are PLUS SHIPPING
Will NOT ship the box
Everything has probably way less than 10 hours total on it .. apart from the Amp looking a bit dirty it's fine .. just been sitting in my garage .. I'll clean everything up nice for the buyer
  • Sensitivity: 87 dB
  • RMS Power Range : 300 Watts
  • Peak Power Handling: 600 Watts
  • Impedance: Dual 4 Ohm
  • Low Frequency response: 25 Hz
  • High Frequency Response: 1200 Hz
  • Diameter: 10 Inch
  • 10" Picasso Series Subwoofer
  • Stainless Steel Stamped Basket
  • UDV Cooling Technology
  • Low Resonance Woven Carbon Fiber Cone
  • Black Progressive Roll Conex Spider
  • C-Lock Rubber Gasket
  • Hi-Arc High Excursion Surround
  • Dual 4-ohm Voice Coil Woven Tinsel Leads
  • Vented & Extended Pole Piece
  • Low Carbon Top & Bottom Plate
  • Rubber Magnet Cover
  • Hole Size: 9.5"
  • Outter Ring Size: 10"
  • Woofer Depth: 5"
  • Recommended Enclosure (Ft3): 0.5 - 0.75 cubic feet
  • Recommended Enclosure Type: Sealed
  • RMS Power Range : 160-260 Watts
  • Number Of Channels: 2
  • Maximum Power: 520 Watts
  • Low Frequency response: 10 Hz
  • High Frequency Response: 30000 Hz
  • Built In Crossovers: Yes
  • Channel Separation: Yes
  • No. OF CHANNELS: 2
  • OUTPUT (watts):RMS @ 4 Ohms 160x2
  • RMS @ 2 Ohms 260x2
  • RMS @ 4 Ohm Mono 520x1
  • T.H.D.: 0.02%
  • FREQ. RESPONSE (Hz): 10 - 30k
  • SIGNAL TO NOISE RATIO: >97dB
  • DAMPING FACTOR: >200
  • INPUT SENSITVITY: 0.5 - 4.0V
  • CROSOVER SLOPES: 12dB
  • CROSSOVER FREQUENCY: High-Pass(Hz) 50 - 600
  • Low-Pass(Hz) 50 - 150
  • SUBWOFFER EQ: 0 - 18dB 0
  • SUBWOOFER EQ FREQ. (Hz) : 40 - 120
  • DIMENSIONS (INCHES): 9.5x2.5x15.0
  • Fully regulated MOSFET power supplies
  • PWM circuitry
  • Tri-guard amplifier protection
  • IDI (Intelligent Distress Indicator) gives a visual indication of the amplifiers protection status
  • Platinum RCA inputs and outputs
  • Line Outputs
  • Bi-linear selectable crossovers for inputs and outputs (Hi/Full/Low)
  • Continuously variable high and low-pass crossovers
  • Variable subwoofer equalizer
  • Phase inversion switch (0 - 180)
  • OEM floating ground input
  • Platinum 4-gauge power connectors
  • Tri-mode operation
  • Optional Remote Bass Control (EGA-RM)
NightWolfe is offline   Reply With Quote
Old 06-28-2009, 10:15 PM   #2
Dninty9
My Ride: BMW 330I, VOLVO 850R
PM SENT
Dninty9 is offline   Reply With Quote
Old 06-28-2009, 10:18 PM   #3
NightWolfe
My Ride: 02' 330CI
Replied
And if anyone else is interested .. here is a pic of when it was installed
Old 06-28-2009, 11:08 PM   #4
BMW_Matt
My Ride: 135
If you don't mind me asking, where was you're amp mounted? And sorry to thread jack, but can you post a pic?
free bump cause I have a similar setup
BMW_Matt is offline   Reply With Quote
Old 06-28-2009, 11:13 PM   #5
Attaus
My Ride: '03 330Ci
I have a freestanding box and put the amp on the back of the seat so I can pull the box when necessary. All I do is loosen the caps, pull the wires, and it's all good. It takes <2 minutes.. and I don't need to mess with the amp wiring.
'03 330Ci 5spd PP
Alpine Type R, MRP 500
Attaus is offline   Reply With Quote
Old 06-29-2009, 12:05 AM   #6
NightWolfe
My Ride: 02' 330CI
Amp was mounted right to the back of the box .. it worked ok, but I would have done it differently (paid someone for the install .. mistake number one haha) .. my new setup is going to be a single 12 .. still trying to decide on where to mount the amps though
Old 06-29-2009, 12:07 AM   #7
BMW_Matt
My Ride: 135
Yea that's my problem; 2 12's in a custom box like yours. I don't know where to mount the amp
Old 06-29-2009, 12:09 AM   #8
NightWolfe
My Ride: 02' 330CI
It's pretty much do something crazy custom, or mount it to the back of the box Depending on the size of the amp the rear seats will probably be to small to mount to, however with your sedan that might not be a problem if they don't fold
Old 06-29-2009, 01:28 AM   #9
Attaus
My Ride: '03 330Ci
Back of the seat.. I'm tellin ya...
'03 330Ci 5spd PP
Old 06-29-2009, 01:38 AM   #10
BMW_Matt
My Ride: 135
I don't have any room. I designed the box to be same angle as the back seat and the front of the box vertical and there's only a few inches above the box, and the HK subs are in the way
Old 06-29-2009, 02:03 AM   #11
Attaus
My Ride: '03 330Ci
Remove the HK subs.. I did since they would be easy as pie to reinstall. That way you can mount it to the back of the seat and still keep the clean look.
If that's not an option, look into installing it under the mat/above the spare. If you have a small amp it might be possible.
'03 330Ci 5spd PP
Old 06-29-2009, 02:07 AM   #12
BMW_Matt
My Ride: 135
I have a MA Audio 1200 watt RMS amp. It isn't exactly "small"
Old 06-29-2009, 02:08 AM   #13
Attaus
My Ride: '03 330Ci
Haha damn.. well what about removing the HK sub, moving the box forward, and installing on the seat? It's either that or a random spot in the trunk AFAIK.
'03 330Ci 5spd PP
Old 06-30-2009, 07:00 PM   #14
NightWolfe
My Ride: 02' 330CI
*bump*
I have a buyer for one of the 10s if someone would be interested in just one of them .. otherwise I would still like to sell as a pair
Old 07-06-2009, 07:23 PM   #15
NightWolfe
My Ride: 02' 330CI
*bump*
Old 07-09-2009, 12:42 AM   #16
NightWolfe
My Ride: 02' 330CI
*bump*
Open to offers
Old 07-10-2009, 12:02 PM   #17
NightWolfe
My Ride: 02' 330CI
*bump*
Old 07-13-2009, 10:05 PM   #18
NightWolfe
My Ride: 02' 330CI
*bump* Open to offers
Old 07-20-2009, 11:14 PM   #19
NightWolfe
My Ride: 02' 330CI
Needs to go .. make me and offer
Old 07-28-2009, 11:06 PM   #20
NightWolfe
My Ride: 02' 330CI
Bump .. Accepting resonable offers .. need to get rid of this stuff to pay for more new stuff
