Thread Tools Search this Thread Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 01-21-2011, 08:20 AM   #41
Safar
My Ride: comes with blow
Wow, I had almost given up on this :p
Keep us posted =)
Vehicle history
1999 BMW E46 328Ci TS2
1992 BMW E36 316i Sold
1987 Suzuki VS1400
1996 Suzuki LS650 Sold
1984 Kawasaki 305CSR RIP
Went from 305cc > 650cc > 1400cc > 2800cc
No prizes for guessing what my next engine will be...
Safar is offline   Reply With Quote
Old 01-21-2011, 08:36 AM   #42
paraklas
My Ride: ESS TS2 320ci
Without any unforeseen events, it should be ready this Sunday. I know it took me a while but I knew that if I did this project before I'd bin my almost new brakes for this setup because that's what happened with the front conversion.
Old 01-21-2011, 01:53 PM   #43
paraklas
Just finished the second set of pads, tomorrow is test fitting day
Old 01-23-2011, 05:11 PM   #44
paraklas
Keep us posted =)
It's done, and it WORKS! I adjusted the brakes using the adjustment screw while I had the rotor only on, so I could "feel" when it would start touching the inner drum. I had a really hard time bending/cutting the dust shield but once I'll do the bearings I'll get a proper one as well.
Another question, is it "normal" for the half shafts to rotate a bit? around 10-15mm back/forth. I am not talking in/out of diff movement, but actual rotation.
Old 01-24-2011, 01:59 AM   #45
paraklas
Final pics of the conversion
Car on jack stands
2x 16mm bolts removed and caliper slides out of rotor
Handbrake assembly.
Disassembling the handbrake mechanism
Test fitting the new shoes!!
After test fitting, all that was left to be done was to fully weld the shoes, paint them and install them just like any other handbrake diy
Old 01-24-2011, 03:58 AM   #46
Alex323Ci
My Ride: M3 & 323Ci (sold)
great work
youre right, it does look a little odd without the dust shield
Old 01-24-2011, 04:10 AM   #47
p][m
My Ride: E46 Compact 320td
You have done a really great job...
p][m is offline   Reply With Quote
Old 01-27-2011, 01:14 AM   #48
paraklas
Originally Posted by Alex323Ci View Post
great work
The 330 dust shield will not bolt to the 320 assembly from what I gather so I decided to make a custom dust shield. Shouldn't be too hard, I'll take a sheet of metal, cut it and bend it. Then I'll just spot weld it on the existing shield
Thanks!!!!!
Total costs:
OEM Rear 330 brake disks from ebay: $80
Zinc coated rear disks from local shop: $90
Reconditioning of calipers: $45
330 Brake shoes: $40
Old 01-27-2011, 05:29 AM   #49
roni
My Ride: 320D 2003
have you modified the front disks from a 330 as well? is there any difference in the master breake pump? waht is the feeling with the new disks - are there any difference in the handling of the car?
roni is offline   Reply With Quote
Old 01-27-2011, 06:14 AM   #50
paraklas
Yes I also got the 330 front brake setup, which is straightforward and no modifications required. I haven't noticed any difference at all (brake cylinder remains stock), apart from the fact that the brakes do not fade that easily/fast anymore with the larger rotors.
Old 01-27-2011, 06:20 AM   #51
roni
My Ride: 320D 2003
ok! and have you driven your car only with front disks from 330? (the rear remain the stock ones) i want to make this swap- but only for the front wheels. i am bothering if i the the brake balance will remain the same
Old 01-27-2011, 06:25 AM   #52
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
This applies to me and my 318. Although I dunno why I would need bigger brakes. Better brakes wouldn't hurt though. Good job. Subscribed.
Breyton-BMW is offline   Reply With Quote
Old 01-27-2011, 06:59 AM   #53
paraklas
I was driving like that for a year or so, no problems at all. It's not like you installed 8-piston BBK in the front and left the rear stock
Yes, our cars share the same braking system, so for you as well 11.5 mm is the magic number
Old 02-28-2011, 01:21 AM   #54
paraklas
Thread bump with rear 330 dust plates modded to fit as well and PBR pads installed:
Also due to stupid imageshack disabling the pictures, I'm attaching the whole DIY as PDF in case somebody wants to re-view it.
Complete 330 Rear Conversion DIY
Old 11-23-2011, 03:08 PM   #55
shwagon
My Ride: 325it 5-speed
Any chance you are taking orders for this conversion? I have already upgraded the front and have purchased everything but the parking brake components for the rear on my car.
Do you know how much of a difference there is between a 320i and a 325i parking brake set up and size?
subscribed!
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 03-13-2012, 07:05 PM   #56
Quenotte
My Ride: E46
Hi Paris,
I would have some questions concerning your setup.
What did you do while modding the 330 dust plates to fit your trailing arms?
Since you modded the 330 dust plates to bolt them properling to trailing arm, and since parking brake shoes are attached to dust plates, I think all you need is just 330 adjusting screws to have a correct setup for parking brake?
And no need to weld anything in this case.
Am I right? Or wrong?
Quenotte is offline   Reply With Quote
Old 03-14-2012, 06:43 AM   #57
paraklas
I cut around 2" of the 320 dust plate to remove the outer section that bends outwards to cover the rotor perimeter and also cut the 330 dust shield a bit more, so basically creating an "extension" of the 320 cover. The 330 piece is welded on the existing 320 shield
Old 03-14-2012, 08:12 AM   #58
Quenotte
My Ride: E46
Ok, I just noticed that this was discribed in your PDF...
But is there a way to bolt the 330 cover on 320 trailing arm or the inner diameter of 330 cover is too large for that?
Thanks!
Old 03-14-2012, 03:55 PM   #59
paraklas
Won't fit. The diameter is off and so are the punched holes for the handbrake mechanism. Plates are cheap, $10 each so when it's time to take everything apart i.e. replace a bearing, I might just put a used 330 section. This mod was done this way mainly for fun and financial reasons.
Old 03-14-2012, 08:26 PM   #60
jogfrogjog
My Ride: car e46 330xi
nice
jogfrogjog is offline   Reply With Quote
318, 323, 330, discs, disks, rear
