E46 Xi Forum
View Poll Results: Have you experienced a subframe failure in your XI?
No failure, more than 60k miles. 15 18.75%
No failure, more than 80k miles. 25 31.25%
No failure, more than 100k miles. 38 47.50%
Failed by 60k miles 1 1.25%
Failed by 80k miles 0 0%
Failed by, or after, 100k miles 1 1.25%
Voters: 80. You may not vote on this poll
Old 08-30-2010, 08:56 PM   #21
Motorglobin
My Ride: 2004 330xi
bump for XIers
no subframe damage here @ 91k miles
Motorglobin is offline   Reply With Quote
Old 08-31-2010, 12:39 AM   #22
thefrog1394
My Ride: e46- 1999 323i
Originally Posted by cwarner View Post
Well, if you do a little more detailed analysis, a 1999-2000 328Ci has a 2% failure rate on this site alone. A 1999-2000 323ci has a 1.5% failure rate on this site alone. That is only those reported here. The numbers keep climbing...
What the stats from the lawsuit don't take into account is mileage and transmission type. An auto is way easier on the subframe mounts because it engages the drivetrain pretty smoothly. Even brake dumps or whatever its called when you burn out in an auto is probably not as harsh as accidentally letting out the clutch a little too fast. So say 90% of all failures were manual transmission and 20% (no idea just made this number up) of e46's are manual then your now looking at a 4% failure rate. Ok, so now what percent of early e46's are still under 100k miles? Lower mileage = less wear on it so it hasn't failed yet. A lot of these failures are higher mileage vehicles and as all these e46's are getting up there in mileage that means the % of failures will continually increase. And of course factor in spirited driving makes things worse, etc. etc.
I believe on early manual e46's its a matter of when not if. Now depending on your driving style, luck, etc. etc. it could be 100k miles when it fails or 500k miles when it fails. But it will tear eventually. Anyways thats my thought on it.
Back to the topic. Xi's. I personally wouldn't worry as there is 40% less torque on the rear subframe. If I were in the OP's shoes I'd take the car in with aftermarket suspension on and just see if they do the inspection. If they don't oh well but if you get lucky and they do then you don't have to worry.
Photo in Cleveland, Ohio
1999 323i - Totaled at 265,000 miles.
Now an e30 & e90 owner.
thefrog1394 is offline   Reply With Quote
Old 10-05-2010, 02:31 PM   #23
TiAgXi
My Ride: e46xi, e46m
Bump for more votes!
TiAgXi is offline   Reply With Quote
Old 12-04-2010, 11:07 PM   #24
chaso
My Ride: 2001 330xi
I've got a nasty clunk in the rear. Getting it checked out Monday. Don't be surprised if I vote yes.
chaso is offline   Reply With Quote
Old 12-05-2010, 03:12 PM   #25
White_Knuckles
My Ride: 2003 325xi
Okay, forget the exact percentage numbers for a minute. My original post was before they enlisted the free inspection when speculation and crazy talk was breaking out on this site. I called BMWNA and had an interesting talk with a representative who quoted the low numbers. The point is, I think we can agree something changed after 2001 where cars are less prone to fail. I was questioning all E46's not XI specific data. It seems XI's are even less effected but let's get back to exploring possible reasons why.
The theory about less applied torque is interesting but could there be something more? Are XI rear drive mounting points, linkage, sway bars, etc. exactly the same as non-XI cars? The gearing is different but consider all rear geometry effects on sub-frame stress. I spoke with Turner Motor Sports about their "kit" which is a weld-in plate solution. When I mentioned I had an XI, he said, "you shouldn't be concerned as they don't have that problem". I was relieved and didn't think to question why.
I wonder why random reports of tweaked front shock towers or torn sub-frames appear where the car bodies are the same across the line. Therefore this plague should effect the XI as well. Perhaps it's due to not lowering or driving the cars hard but I still suspect something else plays into this. I sure hope it's not due to XI drivers putting around like grandma's 'cause, I drive mine like a stolen bicycle!
Old 12-05-2010, 04:48 PM   #26
shadow 2
My Ride: 07 328i
Highly unlikely.
shadow 2 is offline   Reply With Quote
Old 12-05-2010, 04:54 PM   #27
chaso
My Ride: 2001 330xi
Then what could it be?
Old 12-05-2010, 06:38 PM   #28
shadow 2
My Ride: 07 328i
Look at the stats, xi's almost never have subframe tears. Diagnose it yourself or take it to a pro. There are a number of possible causes for that noise.
Old 12-06-2010, 10:06 PM   #29
chaso
My Ride: 2001 330xi
Had the car up in the air today. Subframe is intact and functional.
My clunk is still unsolved!
Sent from my SAMSUNG-SGH-I897 using BimmerApp
OEM+ 2001 330xi | Steel Gray | Black | FK Highsports
