License plate light out - rusted carrier - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 06-30-2009, 11:16 AM   #1
sna77
sna77's Avatar
My Ride: BMW
Anyone have any idea how I fix this? New bulb was not the answer. The contacts look like they have rusted completely... The right hand light works btw:
sna77 is offline   Reply With Quote
Old 06-30-2009, 09:29 PM   #2
sna77
sna77's Avatar
My Ride: BMW
anyone?
Old 07-02-2009, 06:46 AM   #3
sna77
sna77's Avatar
My Ride: BMW
Old 07-02-2009, 07:57 AM   #4
torosh
My Ride: 2004 330i ZHP
I had the same exact issue on my previous 330i. You can either replace the entire handle assembly or try to clean the contacts somehow. It is easier to clean it if you remove the handle assembly from the trunk. I was able to clean mine with some electrical contact cleaner. This issue with mine was that the gasket that fits between the handle and trunk was folded over during assembly and it caused water to get behind the handle and caused the contacts to become corroded. As you reinstall the handle just make sure you have a good seal as you torque the handle down.
Hope this helps.
torosh is offline   Reply With Quote
Old 07-02-2009, 08:59 AM   #5
sna77
sna77's Avatar
My Ride: BMW
Thanks! Were your contacts on both sides like that?
I dont even see the part # for the new handle:
http://www.realoem.com/bmw/showparts...67&hg=41&fg=60
I'm assuming it is #1 51137170966 , Trunk lid grip with key button (primed).
But that says up to 04/2001. No idea what I need for an 04...
Old 07-02-2009, 10:28 AM   #6
tincup33
My Ride: 2003 325Ci
Try the electrical contact cleaner idea or even some baking soda + water mix for the green crap. I can't tell if the corrosion is causing this or if there is some actual rust I'm not seeing.
tincup33 is offline   Reply With Quote
Old 07-02-2009, 11:01 AM   #7
enelson325
My Ride: 2002 325i
damn that is bad lol
enelson325 is offline   Reply With Quote
Old 08-07-2009, 12:08 AM   #8
Devas
My Ride: 2011 E90 M3
I wonder if you change the unit with LED Bulbs the ones that come with the whole housing, would it fix it?
http://www.bimmian.com/46/LPL/
Devas is offline   Reply With Quote
Old 08-07-2009, 12:18 AM   #9
bigfatvr6prik
My Ride: Z8
Had the exact same issue, ended up getting the new one from Tischer and got it painted from another 50$ (if you get it painted make sure you get it matched as color will be off after 5 years of beating the OE paint has taken). You need part # 13 (not #1 as you stated).
In my case while trying to clean the contacts, they were so brittle, that one bulb holder literally broke into pieces while i tried electrical contact cleaner with a small brush.
bigfatvr6prik is offline   Reply With Quote
Old 08-07-2009, 01:20 AM   #10
dmon_101
My Ride: has sexy fogs/shoes
Send a message via AIM to dmon_101
I had to do this with the lousy New England weather I was living in, just cleaned the contacts, and it worked fine.
Dealer Programmable Options | Projector Fogs FTW
There are a lot of Fs and too many Ks in the F/M/K scenario <- posted before I met my wife
To answer your question, it's something you can find by searching the forum or using Google
dmon_101 is offline   Reply With Quote
Old 08-07-2009, 10:48 AM   #11
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Might as well upgrade to LEDs if you are going to replace the housings. I recommend the Xenon White LED License Plate Light Housings we carry which are a complete replacement with built in LEDs.
Old 08-07-2009, 11:47 AM   #12
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Steel wool or mild sandpaper will do the trick. If it's hard to get in there with your fingers, wrap some sandpaper around the end of a pencil and tape it together, then you can be more precise with it. It just happens when corrosion builds up between the metals and disrupts the electrical current.
hi its me alec is offline   Reply With Quote
Old 08-07-2009, 12:02 PM   #13
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
When it gets that bad the 3 pin connector is damged as well. You will need the grip strip and a connector repair kit(most likely)
I just replace all those parts on my E46
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 08-07-2009, 12:51 PM   #14
CJW2OO4
CJW2OO4's Avatar
My Ride: 2007 MCoupe
Send a message via AIM to CJW2OO4
sucks that happened to my car too...good thing I still was under warranty.
CJW2OO4 is offline   Reply With Quote
Old 08-07-2009, 01:18 PM   #15
hi its me alec
Oh wow, I didn't even see the green corrosion all over the inside.. I was just looking at the prongs. That's pretty bad
Old 08-08-2009, 10:54 AM   #16
piesfinder
Banned
My Ride: liability
You have to replace the entire trunk handle part....and paint it. I think the part costs about $75ish. I got it painted for $20.
piesfinder is offline   Reply With Quote
Old 08-08-2009, 06:05 PM   #17
Devas
Do you have the housing just regular 2005 E46 Sedans? Cause it says it only fits CSL
Old 08-08-2009, 06:43 PM   #18
dmon_101
no it doesn't
Old 08-08-2009, 08:18 PM   #19
Devas
Yea it does look at this advertisment on their website
Old 08-08-2009, 08:25 PM   #20
dmon_101
weird, I don't see the word "only"
