Oil Light . . . . - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-03-2009, 12:09 AM   #1
freakinshutty
My Ride: 2000 323i
Oil Light . . . .
Hey Guys -
I have a 2000 323i - changed the oil the other day but might have a problem. When I start the car, the oil light comes on along with all the other lights as usual. Then, about 30 seconds later, it comes on again - not in red but in orange. It stays on in orange, anywhere from 8 to 15 seconds then goes off and stays off. It only happens after I start it up then doesn't happen again until the next time I start it.
When I changed the oil, I made sure I put the right amount in and even now when I check it, it's dead on in between the two markers. Anyone have any thoughts on what might be going on here? Thanks in advance.
TB
freakinshutty is offline   Reply With Quote
Old 07-03-2009, 12:11 AM   #2
GRIDLOCK
My Ride: E36 / E46
If your oil level is fine, then it's your Oil Level Sensor.
Have an EVAP code? Replacing gas cap did not fix? Give me a holler, I can do a smoke test for ya.
GRIDLOCK is offline   Reply With Quote
Old 07-03-2009, 12:33 AM   #3
Chris-TK
My Ride: Mk VI GTI
How many quarts did you put in?
K.
Chris-TK is offline   Reply With Quote
Old 07-03-2009, 12:35 AM   #4
freakinshutty
My Ride: 2000 323i
About 6.5 Quarts . . .
Old 07-03-2009, 12:39 AM   #5
Chris-TK
My Ride: Mk VI GTI
The E46 takes 6.9 quarts. That's probably why you're light is coming on, you're low on oil.
K.
Old 07-03-2009, 12:43 AM   #6
doje3series
My Ride: 2003 325Ci
you're not low on oil. it's the oil level sensor. get it replaced next time you change your oil.
doje3series is offline   Reply With Quote
Old 07-03-2009, 12:46 AM   #7
GRIDLOCK
My Ride: E36 / E46
Naw, he's good w/ 6.5 qts. 6.9 qts. is best (factory spec), but he's not "low" w/ 6.5.
Old 07-03-2009, 12:57 AM   #8
Chris-TK
My Ride: Mk VI GTI
Don't you think it could be low enough that it's causing the oil light to come on intermittently?
K.
Old 07-03-2009, 01:06 AM   #9
GRIDLOCK
My Ride: E36 / E46
Possible.
Old 07-03-2009, 11:11 AM   #10
freakinshutty
My Ride: 2000 323i
Well - I'm admittedly no mechanic but hope I at least know how to check my oil levels! Here's a shot of my dipstick . . . (um . . . .that just sounds wrong!)
Old 07-03-2009, 11:30 AM   #11
GRIDLOCK
My Ride: E36 / E46
Your oil level is way good. Your oil level sensor has (or is) taking a dump.
Old 07-03-2009, 11:59 AM   #12
Chris-TK
My Ride: Mk VI GTI
Agreed
K.
Old 07-03-2009, 08:20 PM   #13
grafiksguy
My Ride: 2010 328xi
^+1. When the sensor starts to go it glows yellow after startup and stays lit for 20-30 seconds then goes out. If you keep an eye on the oil and you can live with it this won't cause any problems. Part's not hard to replace, but costs about $100 and needs to be done at an oil change.
grafiksguy is offline   Reply With Quote
Old 07-04-2009, 12:30 PM   #14
freakinshutty
My Ride: 2000 323i
Thanks guys - good to know. I'll keep an eye on it. Now if I could just fix my freakin door lock issue! I'm almost positive THIS is the problem as my symptoms are identical to those laid out on the site. Also, about 2 years ago my AC started blowing hot air, mainly on the drivers side. Turned out to be a hose of some sort but now it's starting to blow hot air on the passenger side . . . when does it end?!
Old 07-11-2012, 09:57 PM   #15
bmw probz
My Ride: bmw320
bmw e46 320 petrol auto.... red oil light comes on for few days then goes off can any one please help....
bmw probz is offline   Reply With Quote
323i, oil light
