Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
ESS TS2 OBC Fuel Correction
I doubt that the ESS TS2 is able to provide a modified fuel injection pulse signal to the OBC so that it could accurately calculate MPG, but I thought that I would ask. Anyone know? I'ld e-mail ESS, but I suspect that others would want to know as well.
The reason I want an OBC that functions properly is the reason I want an ESS TS; keep the vehicle looking and operating like stock.
Lars
2004 330i ZHP ESS TS2 ![]() |
#2 |
I'd be interested in this as well. I think I've been told that some models can have the OBC recalibrated to be more accurate but I'm not sure of the procedure or which cars this applies to.
#3 |
I'm interested as well. My MPG calculation seems to be off by ~ 7mpg.
- David
![]() 2004 330i ZHP ESS TS2 - 225/35ZR19 / 255/30ZR19 PZero Nero - Rear Subframe Reinforcement Kit |
#4 |
My Ride: comes with blow
Same here. My OBC is consistently off by 30%... would be nice to have it corrected.
Vehicle history
1999 BMW E46 328Ci TS2 1992 BMW E36 316i Sold 1987 Suzuki VS1400 1996 Suzuki LS650 Sold 1984 Kawasaki 305CSR RIP Went from 305cc > 650cc > 1400cc > 2800cc No prizes for guessing what my next engine will be... ![]() |
#5 |
ninja editor
My TT kit is usually within 5% or less margin of error from perfection. NickG FTMFW!!!!1!!1!
#6 |
Past Site Sponsor
The OBC can be recalibrated using INPA quite easily. We typically do it on local installations. There is also a way of adjusting it directly through the instrument cluster menu.
#7 | |
Past Site Sponsor
#8 |
How can it be calibrated through the instrument cluster? Can you provide details/instructions?
- David
#9 |
My fuel consumption is crap already, no need to have the OBC verify it for me
![]() on a side note, my cluster is off by 2-3mpg
#10 |
Can mine be done this way as well ? When I fill up it thinks my range is over 500 miles, even at the track yesterday, it was saying 32 mpg.
STOCK
#11 |
Past Site Sponsor
I am fully aware of the scaling function within the MS43 and MS45, I even wrote a few R&D files calibrated for a few members on here, but beta customers complained about minor issues and we scrapped it since it can easily be configured in the cluster as well. I did not want to waste more R&D time on it at the time as new projects were waiting. There is something weird happening with MS45 especially that affects fuel control under part load when scaled more than 10-15%. On newer cars like the E92 M3 this function works perfect and is incorporated in our SC software.
#12 | |
#13 | |
Past Site Sponsor
Now that I think of it though, in MS45, you actually don't need to change the OBC consumption factor at all in the DME. With MS45, the consumption factor output is independent of the injector size. The consumption factor is derived from the mass fuel flow variable, before it becomes converted to injection time. Thus, if your mass air flow variable and target AFR values are correct (which both determine mass fuel flow), your consumption factor will automatically be correct (thus, no rescaling necessary). |
#14 | |
Past Site Sponsor
If total injection scaling works for you in MS45, then very good! |
#15 |
Guys, I've been correcting this problem for over a year now. If you can't recalibrate your OBC directly, see me.
www.seattlecircuit.com |
#16 |
Grüne Hölle Junkie
Please explain. I am interested too.
#17 |
+11111 please do tell...wait, is this the "fix" where you have to do it every time the car is turned off and then on?
#18 |
My Ride: my favorite two feet
More info on instrument cluster fix please stop leaving us in the dark...
#19 |
Here's my solution.
#20 | |
