Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
Old 04-28-2014, 11:49 PM   #1
E46bound12
My Ride: 02 330i
CX Racing turbo kit for e46
Iknow what your thinking,, again?? Ahah
I jst want to see what you guys think about this kit by CX Racing.
Here are the specs.
Spec:
- T3 T04E Turbo Charger, .50 A/R Compressor, .63A/R Turbine, 3" Inlet & 2" Outlet, 300 to 350HP,This Turbo has Brand New Air Inlet Design for Better Air Flow and Spools Faster
- With Proper tuning, it will support up to 350WHP, with upgraded Injectors and ECU
- 28"x7"x2.5" Intercooler, Bar and Plate
- 2.5" Aluminum Piping kit
Items Included on this kit:
- T04E Turbocharger, with Oil Kit
- BOV + flange pipe
- 8-pcs 2.5" Aluminum Piping kit with necessary Silicon hoses and T-Clamps
- Manual Boost Controller
- 38MM Wastegate, 8PSI
- Aluminum Intercooler, 28"x7"x2.5"
What do you guys think? Should I give it a try?
Should I be the guinea pig on this one? Had auntie one els had success with this or knows anyone who's tried it?
Or is it honestly to risky. If I do I'll be running it on my 330i Zpp
Stumbled upon this while looking for a S/C , what do you guys think?
E46bound12 is offline   Reply With Quote
Old 04-29-2014, 12:12 AM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Do it.
Forget everything I said last night about getting a "Tune" to make it work.
Good luck.
Nitrous !
SUMMIT POINT WV 1:24:229 SCCA
Old 04-29-2014, 12:23 AM   #3
JaYaRe
My Ride: goes, Brroom Brooom
Everything should bolt upnwith some mild fabrication. But our cars are hard to tune and its going to cost $$$$
100_0903-1
JaYaRe is offline   Reply With Quote
Old 04-29-2014, 12:35 AM   #4
E46bound12
My Ride: 02 330i
Originally Posted by Rob43 View Post
Do it.
Good luck.
Nitrous !
Dude I totally forgot about that last night,
Your right . Bmw not honda lol.
Old 04-29-2014, 12:52 AM   #5
Rob43
Rob43's Avatar
This F/I option can be done very well with everything needed at a price of about $1500,.......no ECU tune needed.
Take a read through.
http://forum.e46fanatics.com/showthread.php?t=1031817
Old 04-29-2014, 01:20 AM   #6
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
All I see is a thread about nitrous. Nitrous has nothing to do with forced induction. This is not a debate either. If the manifold pressure isn't higher than atmospheric pressure, there's no force. Very simple concept to grasp here.
Cavi Mike is offline   Reply With Quote
Old 04-29-2014, 01:23 AM   #7
Rob43
Rob43's Avatar
Whatever you say,...................your the F/I expert.
Old 04-29-2014, 07:24 AM   #8
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Here are the specs.
Spec:
- BOV + flange pipe
You are driving a german car.
Our wheels tighten up with almost as much torque as the 6th gen Honda Civic made.
Our TPMS is more complex than your typical Honda ECU.
You can tune a Honda ECU to it's max with 50 bucks and a spare weekend.
Theoretically, YES. You can run this turbo kit, it will bolt on perfectly, but the performance will not be good. At all. Why? Because, the engine can't do anything with 10 lbs. of boost, unless it knows that the 10 lbs. of boost is even there,
You need to tune. Or else just do nitrous.
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 04-29-2014, 09:15 AM   #9
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Who's going to do your tune? /thread.
Tim
tim330i is offline   Reply With Quote
Old 04-29-2014, 09:36 AM   #10
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Tim
+1 Going F/I without tuning is like driving a ticking time bomb
Viral@ActiveAutowerke is offline   Reply With Quote
Old 04-30-2014, 03:35 AM   #11
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
In for videos.
Old 04-30-2014, 04:04 AM   #12
Commanderwiggin
My Ride: 900rwhp Turbo M3
Getting the popcorn ready...I'm in for the tears of ignorance
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 04-30-2014, 11:20 PM   #13
6spd_legend
My Ride: acura legend 6spd
sub'd
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 05-01-2014, 01:41 AM   #14
BrianSpilner
My Ride: Max PSI Stage 2
Install it, start it (don't wait for it to warm up), and immediately do 4k launches. Your motor will love that 10psi without a tune I promise. You will have a huge smile on your face too.
Follow My Builds: Max PSI Stage 2 E46 M3 Turbo Build | 1972 2002 Restomod Build
2004 BMW E46 ///M3 | Maximum PSI Stage 2 Turbo | SMGII | Non-Catted | 711rwhp | 578rwtq
BrianSpilner is offline   Reply With Quote
Old 05-01-2014, 02:00 AM   #15
Commanderwiggin
**** ya take vids! We'll all be mirin!
Old 05-02-2014, 04:44 AM   #16
E46bound12
My Ride: 02 330i
So can I go to a local tuner shop to get this tune?
I'm not educated in F/I when it comes to our cars.
But Hondas yeah, your right about that $50 tune. Honda flash pro lol.
Old 05-06-2014, 01:20 AM   #17
r111093
My Ride: '04 330xi
I'm sure all the people above you with boosted M3s got their tune at a cheap local tuner shop.
I agree, this should be good.
r111093 is offline   Reply With Quote
Old 05-06-2014, 03:54 PM   #18
Sweed
My Ride: 07 6.0L / 04 M3
This is most epic I'm doing this.
AA HKS Stg 2 / Nitrous Express
Sweed is offline   Reply With Quote
Old 05-07-2014, 03:58 AM   #19
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
Sometimes I feel like I'm wasting time telling folks but, I have to remember we all started somewhere.
to the OP:
First step-back and understand what your realistic goals are, and how much you are willing to shell out. if you are not looking to spend 6k+ I wish the best.
1) everything can be modified, but skip the china turbo, and get turbo brand that has been proven (garrett, precision , holset, tubonetics etc.) Don't think that you may have the upper hand with a china turbo being cheap, as yes they can look identical, but the REAL issue with them is the turbine shaft and/or the core. Yes you could run low-boost with them, but they just wont last long. Ask me how I know.
2) if you are not a DIY'er, and don't have welder, fabrication skills, then just give up, as its cheaper to by a bolt-on kit (technique tuning) even though their kit has issues its painless except shelling out 7-8k.
3) the tune... very important. Now sure you can try and run 5psi with no tune. I've done it. but its a useless gain. again it comes back to what your goals, are and how much will you want to tweak the configuration. stock ECU tuning is very limited to only a few people in the US that spent the time and/or have the tools to tweak the firmware in the ECU. Going with a piggy-back configuration and/or stand-alone EMS is the ideal way to go.
4) Looks like you have NOT done research other than finding keywords on eBay that matches "turbo kit" and "e46" so you NEED to spend countless hours studying peoples setup, as by now there as been at least a dozen e46 non-m turboed DIY projects on these forums.
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 05-07-2014, 09:10 AM   #20
NickG
My Ride: 2011 BMW 550i M-Spor
How can a kit have issues, yet be painless at the same time?
Nick
For Sale: 2005 BMW 330i ZHP with Technique Tuning Stage1 Turbo Kit
NickG is offline   Reply With Quote
