Old 07-11-2009, 10:48 PM   #1
Da_BossBMW_23
My Ride: 2003 330i
Abnormal Oil light flashing when brake pressed
I was cruising one day in stop and go traffic and noticed that when i hit the brake pedal, and only when i have the brake pedal pressed, that the oil light (RED) flashes intermittently. This problem has been going on ever since i noticed it. And as previously described, it only happens at low speads and when the brake pedal is pressed. I searched other threads, but those didn't seem, to me at least, to describe exactly what is going on with my car ('03 330i).
I had the filter and oil changed a little over a month ago if that changes anything.
Help please
Da_BossBMW_23 is offline   Reply With Quote
Old 07-11-2009, 10:52 PM   #2
330i_guy
My Ride: 330i
id take my car to autozone try to get the reading to see if the ecu throwing any codes.
they'll do it for free
330i_guy is offline   Reply With Quote
Old 07-12-2009, 02:24 AM   #3
canaryM
My Ride: is strong like bull
Oil level is low. When you hit the brakes, the oil is shifting and the sensor is picking it up. Check your oil level.
///Sport Package | Nav | Park Distance Control | LED tails
///M3 Lip spoiler | Adaptive Xenons | 62 LED Angel Eyes
canaryM is offline   Reply With Quote
Old 07-12-2009, 02:31 AM   #4
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Red oil light means loss of oil pressure and is pretty serious.
Check oil level and if that looks ok then have a BMW tech look at it immediately.
SpeedDemon is offline   Reply With Quote
Old 07-12-2009, 02:39 AM   #5
Acarder
My Ride: 69' M3
Don't fvcking drive the car anymore.
Red = bad, always
Low oil pressure.
Tow it to a shop
Acarder is offline   Reply With Quote
Old 07-12-2009, 06:23 AM   #6
bmwbun
Banned
My Ride: Pre-facelift Coupe
When your oil light starts flashing red it is usually because you have a problem with your oil level.
Smoke detectors in your house behave in a similar way. If it starts alarming, don't start thinking about how it might be wired wrong or how it might be a battery problem. Let your first thought be that it could be a fire.
Check your oil level and top it up.
bmwbun is offline   Reply With Quote
Old 07-12-2009, 02:59 PM   #7
ricanpapi
My Ride: 2003 bmw 330ci
I need some help, I have a 2003 BMW 330CI. The video shows what happened . I was driving the car around for about 15 mins and the red oil light come's on and off . What do you guys think the problem is?
http://tinypic.com/player.php?v=28jh3&s=4
ricanpapi is offline   Reply With Quote
Old 07-12-2009, 03:37 PM   #8
MightyMouse04
My Ride: 2004 BMW 325xi
Help please
Hey,
I had the same problem as you about a month ago. When ever I would hit the brakes my red oil light would come on. When ever I let go and accelerated it would disappear. I created a thread about my problem and got lots of opinions. Here is what I did to diagnose my problem...
1. Checked oil level via dipstick, oil level was perfect, but also topped off as recommended by everyone on the forums. Did not help the problem.
2. I used Castrol 5w-30 Synthetic oil when this problem came on cause i could not find BMW approved oil at my local Autozone / R&S Strauss auto center. But luckily I went to Autozone the day after my problem came up and found Mobil 1 0W-40 Synthetic oil which is BMW approved oil.
3. Went to my local Indy shop, who I am very familiar with and had him change my oil/filter and drove for a couple of minutes and the light disappeared. He said if the problem came back to come back to him so that he could check the oil pressure, but he said nothing was wrong with the pressure when he changed the oil.
Here are the links to the threads pertaining to my problem I made on bimmerforums / bimmerfest / e46fanatics
http://forums.bimmerforums.com/forum....php?t=1251020
http://www.bimmerfest.com/forums/sho...590&highlight=
http://forum.e46fanatics.com/showthr...472&highlight=
MightyMouse04 is offline   Reply With Quote
Old 07-12-2009, 04:59 PM   #9
Da_BossBMW_23
My Ride: 2003 330i
Thank You mighty mouse....thats exactly how my problem is. I will do the same and see what happens.
Old 07-12-2009, 05:55 PM   #10
//TRD power
My Ride: 3.0 | 200hp | 214trq
yellow = oil level
red = oil pressure
yellow = mild
red = severe
yellow = not so bad, take care of it later
red = really bad, "why are you still hurting me?"
//TRD power is offline   Reply With Quote
