Old 07-13-2009, 11:04 AM   #1
bullfrogs_M3
My Ride: 2004 330i ZHP
DIY Swapping Side Mirror Motors into Replica M3 Mirrors
This was written up due to some people on here wanting to know how to tear down and swap their existing side mirror motors into replicas. This is specifically for the Euro-Division mirrors but the same principal should apply to other replicas. This DIY is for the ribbon cable motors
Here is a much anticipated write-up on putting ribbon cable motors into the ED M3 replica mirrors (or possibly any replica-type mirrors). My car is a 2004 ZHP Sedan with the ribbon cables. The tear down of stock mirrors/motors should be the same for the 6-pin/12-pin/ribbon/etc cables.
*Editor note: When I refer to the back of the mirror I am referring to the "base" side of the mirror. The base being the part that attaches to the car. Also note that I was able to source a set of old 330i mirrors from a member here and didn't need to sacrifice my own set of mirrors for this install.
* IMPORTANT NOTE: The ribbon cables are EXTREMELY delicate! I can't stress this enough! Use very delicate hands when pushing and ESPECIALLY pulling on the cables. If you are pulling on the cable you BETTER be pushing on the other end. These things will snap in a heartbeat and then...well...your gonna have to source another motor.
The pics on this DIY is for the driver side. The only difference on the passenger side is that there is only one ribbon connector instead of two on the driver side.
Step 1.
Tear down your doors and remove the stock mirrors. There are numerous writeups on tearing down your door so i'll let you source that info yourself. Here is another link (yes it is for replacing speakers but the principal is the same) http://www.my330i.com/mod46.php. Just behind the top speaker there should be three star/torx bolts that hold the housing on. The easiest way to do this is with the window DOWN. That way you can have one hand holding up the mirror while another loosening up the screws from the interior. The last thing you need is a massive scratch down the side of your doors.
Step 2.
With the mirror out, find a flat space and assemble your tools:
Large(r) phillips screwdriver
Small(er) phillips screwdriver
Set of picks (the orange set I have is the one that comes from BSW to tear down the interior)
Sharpie
Some electrical tape
1'-2' of feeder wire or pullstring or something like that.
Step 3.
Mark off the white connector to show where the pins go and so you know which cable will go to what connector.
Step 4.
Using one of the picks, push in the pins on the connector and slightly pull on the connector as you push in on the pins
Step 5.
When both are out it should look like this:
Step 6.
Using the pick again, pop off the small plastic cover:
Step 7.
Pull the cable through the back of the base
Step 8.
Flip the entire thing over and pop off the mirror. Its held in there with four plastic clips. If you have heated mirrors then pull off from the OPPOSITE SIDE that i did in that pic or else you might break the cable connected to the mirror. Just like I did in the second picture. But since I don't need heated mirrors here in Phoenix, it was no big deal.
Step 9.
Using the smaller screwdriver, take off the four screws holding the plastic front piece.
Step 10.
Pop the four tabs that are holding the metal frame to the body.
Step 11.
With the metal frame pulled apart from the body, you'll have to feed the cable through the "spring" setup. Slowly push the cable in from one side while pulling it from the other till it is completely out. *NOTE: It might be necessary to pull off the existing OEM tape and kinda rework the cables to get it straight enough to fit through the spring.
Step 12.
Once the cable is free, remove the actual motor from the metal frame with the three screws. Once those screws are removed your left with nothing but the motor and ribbons
Step 13.
Grab the new housing and feed your feeder wire or pull string into the base hole and pull it out the mirror part.
Step 14.
Tie/Tape up the ribbon cable on the mirror side and slowly push it through from the mirror side to the base side. The hole that the wires go through to the base are a lot smaller than they really should be. It may be very very tight (thats what SHE said) to get the wires through so try and wiggle them as you push from one side and pull from the other. If it gets too tight try and put some lube on there (thats what SHE..... nevermind) like dishsoap.
Step 15.
Push through as much cable as you can as you move the motor into place. If you don't have the heated mirrors you can tuck those parts of the cable back into the housing somewhere. Use the SUPPLIED screws from Euro-Division to fasten the mirror motor to the housing. Do NOT reuse the old screw set. They may look identical but they aren't.
Step 16.
Put on the provided mirror holder. There should be four audible snapping positions that pop onto the stock motor.
Step 17.
Pull off the piece of paper on the double sided tape and press firmly (but carefully) to put the mirror glass on the mirror holder. * NOTE: Try to put the mirror on at the back/base side FIRST. If you do it the other way you will scratch the front of the inside of the housing removing some paint when the mirror moves and you position everything..... ask me how i know!!!!! argh! Try to eliminate the need to put the mirror on and then remove it and reposition it over and over. While the double sided tape is probably pretty good, you don't want to mess up the strength of the tape if possible. I realize that this might be hard to do, as it took me three-four times to get it lined up the correct way. During this process, i would gently move the motor in as many directions as I could with the mirror glass on so as to make sure I wasn't rubbing in any one direction.
Step 18.
Tape up the ribbon cable as best you can using the natural folds in the cable. Again, be gentle when taping up and folding. Then push the connectors back onto the pins, making sure to put the ones with the sharpie marks together correctly
Step 19.
Put the mirror back on the car. Reverse the directions in step 1. but do the following:
1. Loosely hold the mirror on the car by finger tightening the three screws/bolts.
2. Plug in the connectors
3. Plug back in your mirror switch
4. Turn the key in the ignition to the Auxillary position
5. Try all your directions to make sure it moves (also try your memory seat buttons as these should move the mirror as well....if you have memory seats)
If it works, then tighten the bolts up and finish up the door
Step 20.
Repeat the process for the passenger side. It will be the same with the exception of only ONE connector on the cable vs TWO on the driver side.
PROS:
Paint on them is awesome!
They don't have ANY wobble like some(most?) Replicas do. The hinge seems very tight and strong
Looks like my old M3 mirrors! Freakin love it
CONS:
The hole that goes from the base to the housing is WAYYYYYY to small. Jason (or any other Euro-Division rep) you need to fix this ASAP!!!!!!!!!! The longest part of this entire thing was not the tear down of everything it was the feeding of the cable into the hole. It is extremely bad! I feel sorry for those guys without ribbon cables cause they might have to cut and splice to get it through the hole. I even tried to tear down the base from the housing but was unable to unscrew the 6 point (not Torx but more Hexagon shapped) and ended up destroying a screwdriver bit on it, so said F it and then wiggled the cables through. If some of you do have a problem with getting the cable through, the only thing I can honestly suggest is to try drilling it out more.
I am keeping a sharp eye on the double sided tape thing. Here in Phoenix, we easily have over 110 degree 8 hr days. I am gonna give it a week and then see how easily the mirror moves or comes off. My personal suggestion is to use a couple of strips of the 3M double sided tape that body shops use. Pepboys here sells the stuff and its the next best thing just shy of glue.
I'll post up pics of the end product tomorrow after I have cleaned up the car
bullfrogs_M3 is offline   Reply With Quote
Old 09-21-2009, 04:42 PM   #2
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
I've considered jumping in on the ED group buy but things are taking way too long. Do you know if this is basically the same process for putting ribbon motors in OEM M3 mirrors. If this much work is required for the ED reps then why not just buy OEM ones and do the same retrofit? Plus, I'm very partial to the OEM blue tinted glass and I'm not wanting the clear offered by ED.
'04 Silbergrau Metallic ZHP 6MT
zhp pilot is offline   Reply With Quote
Old 09-28-2009, 05:02 PM   #3
1sickbmw
My Ride: ///M3--323i--RHD ek4
nice
1sickbmw is offline   Reply With Quote
Old 09-28-2009, 09:15 PM   #4
x13atma17x
x13atma17x's Avatar
My Ride: E46 323i & MK6 Jetta
nice write up
thanks for sharing!!
-omar-
x13atma17x is offline   Reply With Quote
Old 09-28-2009, 09:47 PM   #5
bullfrogs_M3
A couple of things:
1. A coupe can use the OEM M3 mirrors (non-ribbon) and bolt right up.
2. The sedans CAN NOT use the OEM M3 mirrors (ribbon or non-ribbon) without modifying the bases. Not a job for the weak of heart as it involves a grinder and multiple testing on the car.
3. I don't know if the ribbon mirror motors will work within the OEM M3 mirror mounts. I have never torn down an OEM mirror so I can't speak on it. If they do fit in the OEM M3 mirror mount then you should be able to swap em out with this DIY and bolt your mirrors right up on your coupe.
Old 09-28-2009, 09:47 PM   #6
bullfrogs_M3
Originally Posted by x13atma17x View Post
nice write up
No prob. I hope it helps everyone out
Old 09-29-2009, 03:43 PM   #7
lkstaack
My Ride: 04 330iZHP, 05 325iT
I'm looking forward to your review of the fitment of this assembly. I completed a simular retrofit with the M5 style replica mirrors. Unfortunately, the drivers side housing angled the mirror away from the driver necessitating the mirror be adjusted/angled towards the driver to its full stop. While I can see with it this way, it allows easy viewing of the ugly, unfinished inside portion of the housing. I'm not satisfied with it.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 09-29-2009, 05:55 PM   #8
zhp pilot
zhp pilot's Avatar
If I remember correctly, this was also an issue with the first run of the ED M3 reps. Currently a new mold has been made to correct this issue. OP, do you have this issue?
Old 09-29-2009, 05:58 PM   #9
bullfrogs_M3
I didn't notice any issues with mine. I was one of the first people to receive a set so I don't know if something changed from the time i got mine to some of the issues. I'll have to go out and check it out again by pushing the mirror all the way up
Old 08-17-2010, 12:01 PM   #10
bullfrogs_M3
Reposting this here, because I can't edit the original with the new image links anymore
Step 1.
Step 2.
Sharpie
Step 3.
Step 4.
Step 5.
Step 6.
Step 7.
Step 8.
Step 9.
Step 10.
Step 11.
Step 12.
Step 13.
Step 14.
Step 15.
Step 16.
Step 17.
Step 18.
Step 19.
Step 20.
PROS:
CONS:
The hole that goes from the base to the housing is WAYYYYYY to small. Jason (or any other Euro-Division rep) you need to fix this ASAP!!!!!!!!!! The longest part of this entire thing was not the tear down of everything it was the feeding of the cable into the hole. It is extremely bad! I feel sorry for those guys without ribbon cables cause they might have to cut and splice to get it through the hole. I even tried to tear down the base from the housing but was unable to unscrew the 6 point (not Torx but more Hexagon shaped) and ended up destroying a screwdriver bit on it, so said F it and then wiggled the cables through. If some of you do have a problem with getting the cable through, the only thing I can honestly suggest is to try drilling it out more.
Old 08-17-2010, 12:23 PM   #11
lkstaack
Originally Posted by bullfrogs_M3 View Post
CONS:
I tore one of my ribbon cables trying to work it through the small hole, trying to be as careful as I could. I then disassembled the entire mirror in order to drill the holes bigger. I thought I faced a $200 bill replacing a mirror motor assembly and the time without a working mirror until it came in. I was able to repair the ribbon by:
-sanding the clear coat off of the copper traces on both sides of the torn cable with #600 sandpaper. You must be very careful and patient or you will sand off the traces as well.
-carefully soldering 20 gauge wire onto the traces of both sides. Temporarily tape the ribbon cable and 20g wires down so they are making contact to aid in the soldering.
-Tape the ribbon so that there isn't any stress placed on the soldered joint.
The repair wasn't as difficult as I expected. Anyone who has soldered can repair this cable. The key was setting up the cable/wires so they are making contact prior to soldering.
Lars
Old 10-06-2012, 02:09 PM   #12
Gmon35saleX
My Ride: 04 325i, 05 G35
I can see the photos?
Gmon35saleX is offline   Reply With Quote
Old 02-26-2013, 02:32 AM   #13
bmwstephen
My Ride: e46 325XI, e36 M3
bump anyway for u to rehost photos?
bmwstephen is offline   Reply With Quote
