***JJR4884 Clams Zuppa w/ Toasted Ciabatta*** - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Everything Else > The Off-Topic > Food Talk
Food Talk
Do you like food? If so, you came to the right off-topic section. Discuss your favorite food topics here!
Old 07-16-2009, 08:32 PM   #1
JJR4884
My Ride: BMW
Ahoy all
Wow haven't done this in a while lol.... anyways my father has been begging for this for 2 weeks now so I figured I would DIY this as well. Basically cooked clams in a loose tomato broth, don't be shy on the crushed black pepper
OK list of ingredients
21 Littlenecks
1 can of crushed kitchen ready tomatoes (28 oz, Pastene brand if you got it)
1 tsp of tabasco sauce
8 garlic cloves, sliced not too thin (6-8 slices per clove)
1 loaf of ciabbata bread, you should get 10 1 inch slices out of it, maybe a few more
EVOO
Kosher Salt
Black Pepper... more than your average amount
Pinches of:
garlic power
dried basil
red pepper flakes
fresh parmigiano if you have it
Start with the garlic, slice em up... if they are too big cut it in half lengthwise first, then slice
Put some EVOO in a pan and sautee that garlic. Med heat for about 7 minutes, since the garlic is big, you don't want to cook it too fast since the outside will burn and the inside will still be raw.... caca
a good test is to put a fork through it, if its soft and doesn't stick to the fork, you are good to go
put the can of tomatoes in, then fill the empty can up 3/4 the way with water, pour it in. Get your clam juice bottle, pour it in. Add a normal amount of salt and a generous amount of black pepper, and a teaspoon of tabasco.... stir well so the water can mix well with the tomatoes, put on high heat.
This sauce is going to cook on high (or med-high) for a good 45 minutes before the clams go in. I try to keep the heat on high and actually "burn" the sauce a little just because it gives a ton of depth and "rustic-ness" to the entire dish.
FYI, when i am cooking the sauce i keep the lid on, tilted just a tad
So, when the sauce is cooking, get the ciabatta and cut it (i angle it like teh ) and make 1 inch slices... should get about 10 slices Put the bread on a cooking sheet and brush some EVOO on the top, and sprinkle some kosher salt and black pepper on top.... nothing crazy, just a little bit
After about 15 minutes or so of cooking on high, and stirring every few minutes give the sauce a taste. I had to add a sprinkle of grated parmigiano, garlic powder, and basil, and a pinch of red pepper flakes. Added a little water as well (quarter can)
See how you can see how some of the sauce is a dark brown?
At this point after the sauce was cooking 15 minutes, you can put the bread in the oven on a cookie sheet, 350-400 for a good 15-20 minutes. Keep an eye on it, the bread should be crispy out the outside, but not browned and "toasted." Check it after 15 minutes, and use your judgment to see if it needs to be in there for longer. Middle rack is fine
Keep stirring and let this sauce really cook well, don't be surprised if you have to add a quarter can of water from time to time. I think i added water to the sauce 3 or 4 times just because it was thickening up a lot.
You'll see when you stir it, the outside edges will actually be brown (as seen above), ... the reason i do this (like said before) is because it just adds so much depth and flavor to the sauce, it just tastes better with this dish "burnt" than it does with that "fresh tomato taste"... rustic is the best way to describe it i guess LOL
when the bread is ready, take it out of the oven and just leave it, nothing else has to be done with it
ok so if you are happy with your sauce, and its loose, keep the heat up and throw the clams in. be careful, don't actually throw them lol... drop them in nicely because they can crack if dropped hard enough. the clams don't really need any prep, a quick rinse is fine but if you want to give them a little scrub you can do that as well....
FYI, closed lid when the clams are cooking
once the clams are in, keep on med-high heat, stir every 5 or so minutes that way they cook evenly. Should take about 10-15 minutes for them to open up. if you see some that don't open don't worry, just stick a spoon through the front of them and twist a little bit, if they open right up you are good.... if not and they still remain closed, chances are that clam is dead so just toss it something not to get nervous about, this time there were about 6 clams i had to open up at the end. just make sure you wait until most of the clams are open before you test the ones that are closed.
once they are done, its time to plate up. your bread should have been out of the oven a while ago which is fine, i serve the bread at room temp anyways
so put a few clams in a bowl, fill'er up with some broth, and serve with the bread
See the consistency? Definitely best when loose
nommmmmmmmmmm nice and crispy
Yep...... thats all garlic in there :excited
FYI, had a bunch of broth left over since i made this for 3 people.... i'll use that for 3/4lb of linguini some time this week If you have about 5 or 6 people to serve, give them 4 or 5 clams each and you'll have just enough broth for the entire serving
Hope you enjoyed As usual sorry for the shitty pics
J
*Adam wish you were here
JJR4884 is offline   Reply With Quote
Old 07-17-2009, 12:53 AM   #2
Wes
Wes's Avatar
Looks great...
HOWEVER!!!!!!! you use soooo much garlic in your food. Dayum dawg.
Wes is offline   Reply With Quote
Old 07-17-2009, 01:00 AM   #3
xFalleNx330Ci
My Ride: '01 330Ci
hmmmm.....do want
Originally Posted by beingdevious View Post
OT is like a bunch of rabid horny monkeys that run around and rape other forums, any new monkeys, and then throw **** at eachother, take pics, and demand nudes.
xFalleNx330Ci is offline   Reply With Quote
Old 07-17-2009, 01:25 AM   #4
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
Gaaaarrrrllllliiiiicccc!!!
Breyton-BMW is offline   Reply With Quote
Old 07-17-2009, 01:51 AM   #5
JJR4884
My Ride: BMW
Looks great...
when cooked right, you can't get enought garlic
melts in your mouth, and its really good for you
Originally Posted by xFalleNx330Ci View Post
hmmmm.....do want
i can melt glass w/ my breath right now
Old 07-17-2009, 08:02 AM   #6
Wes
Wes's Avatar
Well, I expect you to make me dinner one of these days.
Old 07-17-2009, 08:40 AM   #7
JJR4884
My Ride: BMW
when i come to california i expect to have a full kitchen ready for me to get at
Old 07-17-2009, 01:17 PM   #8
that_one_guy
My Ride: 3er Schaltgetriebe
Damn I've always wanted to try and cook clams and or mussels but I'm afraid I'll poison myself
that_one_guy is offline   Reply With Quote
Old 07-17-2009, 03:45 PM   #9
OrisuE46
My Ride: 325xi
i love garlic!
>>*David*<<
R.I.P
OrisuE46 is offline   Reply With Quote
Old 07-17-2009, 03:46 PM   #10
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
i love how clams open when they're ready
VALMONT is offline   Reply With Quote
Old 07-17-2009, 03:46 PM   #11
VALMONT
The De46vil's Army
VALMONT's Avatar
and when is that?
Old 07-17-2009, 05:57 PM   #12
doubleloseven
Slave of Barbri
My Ride: 2002 330i
You should try it with chorizo. Start by browning some chorizo and then toss in the garlic and the other stuff.
doubleloseven is offline   Reply With Quote
Old 07-18-2009, 01:21 PM   #13
JJR4884
My Ride: BMW
lol... no you won't poison yourself, if they open right up they are fresh, and they are fully cooked as well
mussels will open up a lot faster than clams
Originally Posted by dwade325xi View Post
i love garlic!
garlic loves you too
in comparison to.................
and when is that?
not sure yet, but i do want to come out there soon. hopefully you socal fanatics won't ditch me like the so flo ones did (besides meltdown )
i despise this dish with chorizo.... its not bad but the chorizo completely overpowers the taste of the clams, which i am not crazy about
Old 07-18-2009, 06:27 PM   #14
work_lol
My Ride: car
so where'd you go to culinary school?
work_lol is offline   Reply With Quote
Old 07-18-2009, 06:30 PM   #15
JJR4884
My Ride: BMW
lol no culinary school for me bud.... strictly recreational
Old 07-19-2009, 05:09 AM   #16
EDawg
My Ride: :/
how thick is that sauce? that looks like it would be delicious over fresh linguine.
EDawg is offline   Reply With Quote
Old 07-19-2009, 05:24 AM   #17
mkodama
mkodama's Avatar
Nice Russo.
Old 07-19-2009, 10:02 AM   #18
JJR4884
My Ride: BMW
pretty thin, its not a broth like chicken soup, but its definitely not even as thick as a marinara (which is relatively thinner)
i could have easily made this dish with linguini, simply just boil a 1lb of pasta instead of the bread.......... HOWEVER...... when the bread soaks up all that sauce....... omfg
but as a meal this could be served with linguini any day of the week
Nice Russo.
thanks miles
Old 07-19-2009, 01:48 PM   #19
Wes
Wes's Avatar
and when is that?
He is mine! Get your own :|
Old 07-20-2009, 08:29 AM   #20
JJR4884
My Ride: BMW
now now boys..............
