M54b30 intake manifold swap into m52tu - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 07-17-2009, 08:07 PM   #1
b/\/\w STREETS
My Ride: 00 BMW 323I
My 2000 bmw 323i m52tu got an intake manifold swap. Got the intake manifold from 2004 bmw 330i m54b30.
Parts need just to complete the swap are:
1-intake manifold m54b30
2-m54b30 disa valve
3- turner motorsports m50/54 throttle body adapter plate
Parts I change while I was in there:
Two hard plastic bypass tubes
One bypass hose
fuel injector o rings
throttle body gasket
intake manifold gasket
all vacuum hoses
CRANKCASE-VENTILATION/OIL SEPARATOR
All the vent pipes/hose that go with it
Also many other misc items:
coolant, water wetter, carb/ throttle body cleaner, engine degreaser, seafoam, and seafoam deep creep
My 323i has 120,xxx miles on it. If the stock hoses/pipes have lasted this long, its good for another 120,xxx.
Now what has to be modified to make this work?
Your throttle body has to be grinded on the top right to be able to clear the idle air control valve
Only two of the four throttle body bolts are used
Also the bracket that holds all the wiring will not bolt back on due to the turner plate. The turner plate moves the throttle body forward causing this problem. (no biggie)
You have to adjust your throttle body cable to be able to open complete at full throttle.
I pretty much just flushed my coolant, cleaned my engine very detailed and cleaned the m54b30 manifold completely.The swap is straight forward, everything is reused again or could be replace with new parts. The m54b30 intake manifold itself is bigger and has longer runners than the m52tu. The first 80-100 miles the car seems to adapt itself to more air flow. The difference is completely different at all rpms. The car just revs freely all the way to redline, no more choking.Well worth the 8 hrs of work and about $400 spent in everything.Any questions feel free to ask
Ps: activ3 the intake ports on the head are D shaped. The port on a stock m52tu are oval and the ports on the m54b30 are D shaped
ID:	323892   Click image for larger version
ID:	323893   Click image for larger version
ID:	323894   Click image for larger version
ID:	323896   Click image for larger version
ID:	323897   Click image for larger version
ID:	323898   Click image for larger version
ID:	323900   Click image for larger version
ID:	323901   Click image for larger version
ID:	323902   Click image for larger version
ID:	323904   Click image for larger version
ID:	323905   Click image for larger version
ID:	323906   Click image for larger version
ID:	323908   Click image for larger version
b/\/\w STREETS is offline   Reply With Quote
Old 07-17-2009, 08:20 PM   #2
///Flash
Banned
My Ride: a donkey
wow...continue to update us. do you think you will do a DYNO?
///Flash is offline   Reply With Quote
Old 07-17-2009, 08:25 PM   #3
b/\/\w STREETS
more to come
ID:	323910   Click image for larger version
ID:	323911   Click image for larger version
ID:	323912   Click image for larger version
ID:	323914   Click image for larger version
ID:	323915   Click image for larger version
ID:	323916   Click image for larger version
ID:	323918   Click image for larger version
ID:	323919   Click image for larger version
ID:	323920   Click image for larger version
Old 07-17-2009, 08:29 PM   #4
haplo_84
My Ride: 328Ci
Whats supposed to be the advantage of doing this?
I still have a ways to go to get it where I want.
haplo_84 is offline   Reply With Quote
Old 07-17-2009, 09:31 PM   #5
b/\/\w STREETS
air flows easier into the engine making it breathe better making more power
ID:	323931   Click image for larger version
ID:	323932   Click image for larger version
ID:	323933   Click image for larger version
ID:	323935   Click image for larger version
ID:	323936   Click image for larger version
ID:	323937   Click image for larger version
ID:	323939   Click image for larger version
ID:	323940   Click image for larger version
ID:	323941   Click image for larger version
ID:	323943   Click image for larger version
Old 07-17-2009, 10:33 PM   #6
haplo_84
My Ride: 328Ci
Where did you here about this swap at, i mean I'm not putting it down. I'm just a bit skeptical is all. i like numbers and facts. But i do find it really interesting.
Old 07-18-2009, 12:00 AM   #7
Iceman00
Banned User
My Ride: E90 6MT
2-m54b30 disa valve
One bypass hose
all vacuum hoses
Awesome. I'm doing the same, but with a B25 manifold instead. Where did you buy your hoses?
Old 07-18-2009, 12:17 AM   #8
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
supposedly the hp gains are small, but there is a pretty decent jump in torque.
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 07-18-2009, 12:29 AM   #9
haplo_84
My Ride: 328Ci
I wonder what a bit of tuning with that and an exhaust and intake would do overall for it? You have any of those planned with it?
Old 07-18-2009, 12:44 AM   #10
Iceman00
Banned User
My Ride: E90 6MT
I think it is the other way around and gains should be around 10whp at top end. I chose the B25 manifold because that is what the World Challenge Cars use. I think the B30's manifold is more geared towards torque.
Old 07-18-2009, 01:56 AM   #11
azzy989
azzy989's Avatar
My Ride: 325i
ya i was speaking of the b30 manifold. i would have to search for the thread but apparently turner stated that there was almost 20 tq gain going from a b25 manifold to a b30 manifold.
Old 07-18-2009, 03:08 AM   #12
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Who told you that?
Every WC engine I've seen uses the B30 Manifold...heck I even bought one from a TMS engine.
Old 07-18-2009, 09:15 AM   #13
Iceman00
Banned User
My Ride: E90 6MT
F**k
Old 07-18-2009, 09:17 AM   #14
haplo_84
My Ride: 328Ci
Its not the end of the world man.
Old 07-18-2009, 12:01 PM   #15
Iceman00
Banned User
My Ride: E90 6MT
You're right. I just checked, there was NO GAIN going from a 325 manifold to a 330.
http://forum.e46fanatics.com/showpos...3&postcount=61
Apparently, Will Turner runs a 325 manifold and that is good enough for me.
Old 07-18-2009, 12:07 PM   #16
haplo_84
My Ride: 328Ci
He would be one of the leading authorities in the tuning world of bmw's. Can't really argue to much, cause i have no where near the amout of knowledge that guy would have. My experince is mainly limited to japanese imports and and american iron. I'm working on the german end of it though.
Old 07-18-2009, 07:54 PM   #17
b/\/\w STREETS
My 323i has e36 m3 ebay headers,gruppe m replica intake, uuc pulleys,custom exhaust , aa tuned, 50 wet shot. Thinking of redoing the exhaust to a 3inch but i should dyno soon after
ID:	324057   Click image for larger version
ID:	324058   Click image for larger version
ID:	324059   Click image for larger version
ID:	324061   Click image for larger version
ID:	324062   Click image for larger version
ID:	324063   Click image for larger version
ID:	324065   Click image for larger version
ID:	324066   Click image for larger version
ID:	324067   Click image for larger version
ID:	324069   Click image for larger version
ID:	324070   Click image for larger version
ID:	324071   Click image for larger version
ID:	324073   Click image for larger version
Old 07-18-2009, 07:59 PM   #18
b/\/\w STREETS
All the hoses/pipe were bought at the dealer iceman00
Old 07-18-2009, 08:13 PM   #19
Iceman00
Banned User
My Ride: E90 6MT
+110% respect
Old 07-18-2009, 08:20 PM   #20
b/\/\w STREETS
thanks man
