Old 07-18-2009, 08:24 PM   #21
Iceman00
My Ride: ghey
My only real question regards the throttle body and the adapter plate. If only 2 bolts are used, does it stay tight on the Manifold? And the throttle body wire, how hard is it to re-arrange it?
Old 07-18-2009, 08:50 PM   #22
b/\/\w STREETS
My Ride: 00 BMW 323I
they stay on tight, the 3rd post i did with pictures, the last picture shows the two bolts used. Throttle cable is a snack just clip it on the throttle body itself and then have someone press the gas pedal all the way and then just adjust it accordingly with the screw the throttle cable has
b/\/\w STREETS is offline   Reply With Quote
Old 07-18-2009, 08:52 PM   #23
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by Iceman00 View Post
You're right. I just checked, there was NO GAIN going from a 325 manifold to a 330.
http://forum.e46fanatics.com/showpos...3&postcount=61
Apparently, Will Turner runs a 325 manifold and that is good enough for me.
Did you talk to him? We email pretty much every week.
I don't know why you are so set on giving poor advice, but I know of numerous race teams and top level tuners that switch the B25 manifold out for B30s and see substantial gains.
Edit: I guess what needs to be acknowledged is the context of this conversation. I think every one of the engines I'm referencing are fairly "built" with different cams. On a stock engine, I'm inclined to agree that the B25 may be best for the B25. My frame of mind is very rarely stuck in "stock" configurations.....
Sorry for the sidetrack.
Old 07-18-2009, 08:59 PM   #24
Iceman00
My Ride: ghey
Did you read what I posted? According to the post, a person contacted Will directly. Will was quoted as saying there were no gains in horsepower to be had, but the manifold did move the torque curve around, though it was not specified how.
Old 07-18-2009, 09:07 PM   #25
Iceman00
My Ride: ghey
I was about to flip out to be completely honest.
Old 07-18-2009, 09:12 PM   #26
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I would have sent you an "E-hug".
Old 07-18-2009, 09:14 PM   #27
Iceman00
My Ride: ghey
I would have accepted
Old 07-20-2009, 03:24 PM   #28
Iceman00
My Ride: ghey
My M54b25 just walked in the door.
Old 07-20-2009, 03:31 PM   #29
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Looks good man! You're M52TU head has the D shape ports too though, as well as your intake manifold, along with the M54 manifold
I have a b30 manifold already, I just need to get the DISA and the TB adapter plate.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 07-20-2009, 04:38 PM   #30
Iceman00
My Ride: ghey
Adapter plate is next. I cannot wait!
Old 07-20-2009, 05:41 PM   #31
hoveringuy
My Ride: e30
I would say it's worth it for the DISA, alone. Having seen the same motor with and without DISA I can say the low-end torque gains are subtantial.
Why couldn't you use the M54b30 throttle body?
hoveringuy is offline   Reply With Quote
Old 07-20-2009, 06:16 PM   #32
b/\/\w STREETS
Activ3 Looks good man! You're M52TU head has the D shape ports too though, as well as your intake manifold, along with the M54 manifold
yea bro m54=D m52=o on the manifold
hoveringuy I would say it's worth it for the DISA, alone. Having seen the same motor with and without DISA I can say the low-end torque gains are subtantial.
m54= drive bywire m52= cable
Old 07-20-2009, 06:37 PM   #33
hoveringuy
My Ride: e30
I'm not that familiar with M52tu, but looking at the picture it looks like a DBW TB. What's the big plastic lump on the side?
Reason I'm interested is because I have an M54b30 intake on an m54b30 engine with an M50 throttle body that was necessary for the OBD1 conversion. I WOULD like to be able to use the orignal M54 TB because it fits with all 4 screws (I'm only using 2, also!).
To accomplish this, I'm working on a standalone electric throttle to electric throttle body interface. I have the prototype working nicely in the lab, I can input a sinusoidal signal off my signal generator and watch the TB respond. Open-close-Open-close...
The best part about it is that the Egas pedal is SMOOTH! It uses a full H-bridge with a motor control MOSFET. I'll have the car test running on it in a few days. I won't install it until massive testing, but it's getting close.
www.seattlecircuit.com
Old 07-20-2009, 06:52 PM   #34
b/\/\w STREETS
i think it is for the traction control but not sure
Thats a nice project you have going on there
let us know how it comes out
Old 07-21-2009, 12:37 PM   #35
Dirty Tool
My Ride: Free-To-Ate-See-I
excellent work OP...i posted a thread about this not too long ago but with no real input. Many thanks!
Dirty Tool is offline   Reply With Quote
Old 07-21-2009, 08:50 PM   #36
b/\/\w STREETS
thank you
Old 07-22-2009, 01:19 AM   #37
alexxander.foster
My Ride: 2000 323i
haha! im so glad to see someone actually did this swap and documented it! other than the guy in south africa on the zroadster forum, nobody has documented this. i was planning on doing a write up myself next week with pictures and such but you beat me to it! and i couldnt be happier (you saved me a bunch of work b/\/\w STREETS)! excellent write up by the way! i couldnt have done a better job myself.
keep us posted on what kind of power gains you got.
alexxander.foster is offline   Reply With Quote
Old 07-22-2009, 03:38 PM   #38
b/\/\w STREETS
ill keep you updated with power level
Old 07-30-2009, 12:19 AM   #39
boto1818
My Ride: BMW E46 323i w/330i
Send a message via Yahoo to boto1818 Send a message via Skype™ to boto1818
I have done engine swap on 323i e46 with 2003 530i engine but i use intake from 323i and i have K&N filtel plus "ebay" headers.I am going on dyno Monday..
boto1818 is offline   Reply With Quote
Old 07-30-2009, 12:25 AM   #40
boto1818
Is the Injectors from 2000 e46 323i and 2001 e46 330i same size.????
