Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 07-30-2009, 04:49 AM   #41
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
Originally Posted by boto1818 View Post
Is the Injectors from 2000 e46 323i and 2001 e46 330i same size.????
nope, the 330 has larger injectors on it.
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 08-05-2009, 08:56 PM   #42
JackEatsEmoKids
My Ride: '02 E39 530/5
Send a message via AIM to JackEatsEmoKids
Dyno yet?
- BMW Master Certified Technician -
'02 530i - PTE6262 - MegaSquirt3X - E85 fuel -
596whp/558ft-lbs @ 22psi
JackEatsEmoKids is offline   Reply With Quote
Old 09-09-2009, 09:25 PM   #43
b/\/\w STREETS
My Ride: 00 BMW 323I
same update my car was misfiring at idle , this was due to the fuel injectors. Any one doing the swap make sure to get 330 injectors, they r the purple ones . 323,325,328 r black. After swapping them out no more misfire
b/\/\w STREETS is offline   Reply With Quote
Old 09-10-2009, 12:53 AM   #44
mik_jack
My Ride: 1999 323i
does the 330 injectors effect mpg???
mik_jack is offline   Reply With Quote
Old 09-10-2009, 10:03 PM   #45
b/\/\w STREETS
will c gonna fill up tomorrow
Old 09-13-2009, 01:55 AM   #46
e46bluehulk
My Ride: 99 e46 328i
this looks awesome! any links to possible hp gains?
e46bluehulk is offline   Reply With Quote
Old 09-13-2009, 05:17 AM   #47
Iceman00
Banned User
My Ride: E90 6MT
I don't think injectors were the issue, unless you were running at 100% duty cycle (again which doubt) more than likely, the AA tune has you running leaner for a bit more power, and as a result of more airflow with the manifold swap, you are leaning out a bit to much..
The 330 injectors are bigger, but they don't match up with your tune, meaning they are going to just dump in fuel.
Old 09-13-2009, 08:11 PM   #48
b/\/\w STREETS
good thing im local gonna take a trip and ask
Old 09-13-2009, 08:12 PM   #49
b/\/\w STREETS
i have no hp numbers but i sure felt the difference
Old 09-15-2009, 08:43 PM   #50
Iceman00
Banned User
My Ride: E90 6MT
Well?
Old 09-17-2009, 03:49 PM   #51
rmank
My Ride: 2000 323Ci
Great write up, good to see there are a few people working on this. I was following the other thread that died off and just found this one. Just ordered an m54b25 intake manifold and DISA, and received my throttle body adapter yesterday.
Would this be worth having a shop do, and would it take them less time (3-4 hours maybe)? I'm having my exhaust done and ebay headers put in soon and was thinking of just having these parts put in at the same time. I've done some DIY work, but this looks like it may be over my head.
Iceman00, I got your PM, thanks for the response. Sorry for not getting back to you, got busy at work and haven't really be on the forum until recently. Hope your swap is going well.
pei330ci, you talked about some built engines and cams. Any ideas on what cam profiles may work well here? And what type of mods are in the 'built' engines...cams, headers, custom tune? With the new manifold I was thinking cams would probably help a lot, but the info on the other page about the b30 vs b25 manifolds made me wonder which one would be best if cams were in the future?
rmank is offline   Reply With Quote
Old 09-17-2009, 08:10 PM   #52
Iceman00
Banned User
My Ride: E90 6MT
I have all the parts I need, I just waiting for the time. It seems like a straight forward swap, so I'm going to pick a day, and go to town. But my car has some other issue that need attention (low rpm stumble, soft low end = vanos seals?) (rear end vibration and grating sound at high rpm WOT = cracked Guibo?)
Old 09-18-2009, 09:05 AM   #53
rmank
My Ride: 2000 323Ci
I know what you mean. I just did my valve cover and vanos, then the intake cam sensor went, then the exhaust sensor went (sounds kinda like a diesel). When you do your vanos you may want to have a code reader handy for a while, my codes popped up one at a time right after each other. When I fixed one the next would come up.
Old 09-19-2009, 06:55 PM   #54
b/\/\w STREETS
rmank the swap is simple. The same way you take it out , you put it in. The throttle body is really the only thing you have to mess with. Try to replace all the vacuum hose possible while ur at it because they crank and ur just going to waste time.
Old 09-22-2009, 12:43 PM   #55
rmank
My Ride: 2000 323Ci
I was reading it over in the Bentley manual and wasn't too sure about disconnecting the fuel lines. They explain it as part of the engine removal so it seems a bit complicated. Is it possible to remove the manifold by disconnecting everything and moving it aside to pull out the manifold? I haven't received my new manifold yet so I'm still working on visualizing where everything will go and fit. I'll def be sure to get new vacuum hoses, should help speed up the install.
Old 09-23-2009, 07:11 PM   #56
b/\/\w STREETS
you dont need to remove the fuel rail, just put it aside
Old 09-26-2009, 01:58 PM   #57
Juhani
My Ride: 328i e46
Send a message via MSN to Juhani
328i
Nice thread guys =)
I buyed a m52tub28 99mod Sedan, and i have got my FULL Supersprint exhoust, with Headers (Replaces Cat) So i will have no cats.
i will change my intake cams, to Schrick maybe? Whats the best?
And the Kn filter kit, alminum Flywheel, and sport clutch, pulleys
And the m54b30 Manifold from an 330i.
So you guys can u guide me to Adapter and Disa? =)
Juhani is offline   Reply With Quote
Old 09-26-2009, 08:49 PM   #58
b/\/\w STREETS
disa= 330i
adapter= turner motorsports adapter plate m50/54
Old 09-27-2009, 01:58 PM   #59
Juhani
My Ride: 328i e46
Any place to get it more powerful or is it best orginal? ;P
Old 09-27-2009, 03:17 PM   #60
b/\/\w STREETS
oem
