M54b30 intake manifold swap into m52tu - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 10-06-2009, 12:54 PM   #81
Iceman00
Banned User
My Ride: E90 6MT
Did the swap too
http://forum.e46fanatics.com/showthread.php?t=710600
Old 10-06-2009, 12:54 PM   #82
Iceman00
Banned User
My Ride: E90 6MT
Did the swap too
Old 10-07-2009, 10:43 AM   #83
b/\/\w STREETS
My Ride: 00 BMW 323I
+1
b/\/\w STREETS is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-20-2009, 12:56 AM   #84
alibusoul
My Ride: 04 330Ci
Originally Posted by b/\/\w STREETS View Post
as for the hoses try to replace as much as possible vacuum and crank case ventilation hoses.
now im in the process to see if 01 or 02 330 maf will help if anything. The 03 and newer have a different plug,so thats a dead end.
If you go with the 330 MAF then you need the 330 air box w/ a 3in opening, then 3in intake tubes, which would lead to ur smaller 2.5in TB... I dont think it would work...
Plus I doubt that the ecu will work with that MAF
alibusoul is offline   Reply With Quote
Old 10-20-2009, 11:46 AM   #85
Iceman00
Banned User
My Ride: E90 6MT
I'm sure my maf is 3inches, and I'm a 2.5 liter...
Old 10-20-2009, 11:54 AM   #86
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
The 330 MAF is larger than 3 inches.
Old 10-20-2009, 12:45 PM   #87
Iceman00
Banned User
My Ride: E90 6MT
So what, is this some measuring contest?
Old 10-20-2009, 01:29 PM   #88
mrshelley
My Ride: 2004 330i
It's the girth that matters with a MAF, not the length.
Old 10-20-2009, 10:09 PM   #89
b/\/\w STREETS
got a 330 air box , now i need to source a 2001 or 02 maf and i got the reducer for it, will see what happens
Old 10-20-2009, 10:39 PM   #90
aggieE46
Keep it clean
aggieE46's Avatar
Sorry, I guess I jumped in the middle of something. I'll shut up.
Old 10-22-2009, 04:04 PM   #91
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
Holy shute this is awesome! This is EXACTLY what I was looking for!
I bought a B30 manifold including ALL parts (except TB) last month and it has been giving me headaches on how to install it, and I just ordered the TMS adapter plate as my mechanic says he won't make one and install the manifold for me after all (he's a VW/Audi geek and has no nerve to bother with BMW's )
Anyway, I was reading through the Bently manual and it says I have to keep pressure on the fuel lines and rail. Now I was about to DIY this project, but this part (and grinding the TB) gave me a bit of a shock and I am currently looking for a competent mechanic over here who could help me out with this.
The B30 manifold I bought also came with the fuel rail and the larger injectors. Is it recommendable to use both for the install?
And what exactly is the DISA valve?
Here is a picture of the manifold:
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 10-22-2009, 04:04 PM   #92
Rayce185
Rayce185's Avatar
Sorry, double post
dun dun duuuunnnn
Old 10-22-2009, 07:13 PM   #93
Iceman00
Banned User
My Ride: E90 6MT
Old 10-22-2009, 07:18 PM   #94
Iceman00
Banned User
My Ride: E90 6MT
No, use your standard rail and injectors. The DISA is the big box that covers that gaping hole in the manifold, and switches the manifold from the low end runners, to the high end (it the hole above the TB opening) You'll need a B30 valve.
Old 10-24-2009, 01:21 AM   #95
alexxander.foster
My Ride: 2000 323i
Just to further elaborate on Iceman00's explanation of the DISA valve, its a flap designed to change the length of the intake manifold runners. its actually a really fascinating concept and BMW did some serious R&D on this.
with engines, there are usually two routes you can go with intake runner lengths: shorter for better low end power or longer for better high end power. well, BMW came up with a way to put two lengths into one intake manifold and have a flap change the runner length, thus optimizing power across the entire power band. the DISA valve is the piece that changes the length of the runners. during low engine speeds it stays closed but about half way through the RPM band (i dont remember where) the flap opens up changing the length. but in order for BMW to make an intake manifold with dual length runners fit in that sardine can of an engine bay, they had to get creative. thats why our intake manifolds have more tubes than an oil refinery. especially compared to the old M50 intake manifolds you can see the differences made to capitalize on the DISA valve. all things considered though, i think BMW did a great job. the space where they "added" intake runner tubing was basically unused space.
now, just for the sake of saying it, its totally possible to put another intake manifold on these cars that uses no DISA valve (say an M50 intake manifold). i have absolutely no idea how well it would run but i would imagine it would improve power in the top end and you'd definitely lose power in the low end. in fact, while doing research for this swap i found tv show posted on youtube where a guy had an M50 intake manifold put on his supercharged M54 engine to get more power. apparently they are a lot better for supercharged applications on our cars than the manifolds that incorporate the DISA valves. but i dont remember where i saw the video so if someone is interested say so and i'll try and find it again.
here are some pictures. the DISA valve isnt labeled but its the red line in the middle of the diagram next to the "magnetic valve" and "vacuum unit" (which are all components of the DISA valve)
ID:	336208   Click image for larger version
alexxander.foster is offline   Reply With Quote
Old 10-31-2009, 11:52 AM   #96
KevinJ_2k1_325ci
My Ride: 2001 325ci
I tried a 330 MAF, won't work
I tried this about three years ago with a 330 airbox, maf, and intake tube which connects to the 325 throttle tube. You just have to tighten down the throttle tube clamp.
The car won't stay stable I think because the 330 MAF is also tied to the injector size also.
KevinJ_2k1_325ci is offline   Reply With Quote
Old 11-01-2009, 09:23 PM   #97
b/\/\w STREETS
i have 330 injectors installed now, so will see what happens
Old 03-10-2010, 09:26 PM   #98
vwandbmw521
My Ride: 00 328ci, 98 jetta
Send a message via AIM to vwandbmw521
Is there a part number on these manifolds? I bought one and they sent me the completely wrong one so after two weeks I got the replacement and the adapter doesnt fit the bolt holes are off
K&N intake UUC SSK UUC Exhaust
UUC Underdrive pullies UUC Sway bar kit
UUC Tranny mounts UUC DSSR
Shark Injection BSW stage 1 speakers
BSW dual 10" subs
18"staggered Beyern mesh rims
Drilled and sloted rotors
Smoked tails, sides,and turns
Painted reflectors
Meyle HD bushings
vwandbmw521 is offline   Reply With Quote
Old 03-11-2010, 09:20 PM   #99
vwandbmw521
Intake manifolds?
I thought I ordered a manifold for a 330 but the bolts dont line up to the turner plate they are about a 1/2" off
is there any way to tell what manifold came from what car?
BSW dual 10" subs
Painted reflectors
Meyle HD bushings
Old 03-11-2010, 09:33 PM   #100
whitecord
My Ride: stage 2 aa 330i
i have a manifold....in the for sale section.
whitecord is offline   Reply With Quote
