Thread Tools Search this Thread Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old 01-15-2014, 01:49 PM   #161
dymONE
My Ride: E46 323Ci M-tech II
http://www.ebay.com/itm/BMW-M54-B30-...item1c3b4ab6b7
This one fits perfectly. Price is decent as well.
H&R Cup Kit | H&R Stabilisators kit | SS headers + Thermotec | M3 front brakes | Meyle HD RSM's + Z3 reinforcement plates | M3 RTAB's + limiters |
CCC rear adjustable camber arms | Powerflex subframe bushing | GoodYear Eagle F1 A2 + Nokian WR A3
dymONE is offline   Reply With Quote
Old 03-01-2014, 08:27 AM   #162
beņat
Problem BMW 328i e46 race car not max rpm
hello. I have a problem with my 328i e46 race. lobque happens is that I canceled the abs and inatrumentos box and I left the ews and sensors with the engine control unit. what happens is that it goes up to 7000rpm horn in 4 runs to 5200. till then not turn off and restart the car bo horn that goes well 4 ya I put up no more 5200.must connect the unit to have abs infprmacion sw speed or to do something in the engine control unit. I've tried everything and I can not think nasa. thank you advanced.
beņat is offline   Reply With Quote
Old 03-09-2014, 11:36 AM   #163
BartenderPlease
My Ride: '03 540i/6 M-Sport
beņat, please use a _____ to English translator.
I ordered my plate from Turner, made in the USA, gets here fast, supports the race team.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 07-13-2014, 01:58 PM   #164
TheSlowClub323Ci
My Ride: 2000 323ci
I finally joined just for this post, I've decided to start this project but im not plannning on doing the labor for a few more months until i can acquire all the parts! Is there a link to the correct throttle body adaptor for a 323ci to a 330ci manifold??
Does this look correct?? Will i need to grind it down or will it directly bolt on?
http://www.ebay.ph/itm/BMW-M54-B30-3...item1c428a0277
TheSlowClub323Ci is offline   Reply With Quote
Old 11-20-2015, 11:27 AM   #165
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
let's bring this thread back tolife (as my car)
ok i've found an m54b30 intake, complete with wiring, injectors (purple) fuel rail and DISA.
i've understood almost everything for this swap but there are just some questions that i'd like to ask:
(consider that my 323 already received a b28 swap years ago)
-Injectors: 330 injectors seems not to be necessary, but better to have them for eventual future upgrade or not? (to be added with 330 maf + bored b28 TB)
- TB Adapter plate: even if i'm in europe there are many replicas on Ebay here so no need to get a TMS, i'll DIM (do it myself) but...the problem is the cnc machine that my friend owns, it can only work on delrin/teflon (to work on alluminium we need a lubed one), considering that on the intake temperature are not that high, may i go on delrin's way or it's a weird idea?
- TB/gas cable: is there any adaptation/reset necessary after all the process? as adjusting the play, lenght??
i remember that some years ago i changed the cable and mach @ dealer spoke about "setting up" the cable, thing that i knew as necessary only on DBW sys.
any other advice??
thnx
TheRiddle is offline   Reply With Quote
Old 07-13-2016, 07:29 AM   #166
Darkomarko
My Ride: E46 323ci
Originally Posted by hoveringuy View Post
I would say it's worth it for the DISA, alone. Having seen the same motor with and without DISA I can say the low-end torque gains are subtantial.
Why couldn't you use the M54b30 throttle body?
Hello. Does it mean that I can change JUST disa from 330 to 323 and it is worth it? Sorry if it sounds stupid to you
Darkomarko is offline   Reply With Quote
Old 07-14-2016, 04:06 PM   #167
e90Unicorn
My Ride: 2011 328i, 2001 325i
disa is physically bigger on 330 and the disa from the 2.5l manifold is too small to be installed in the 330 manifold
e90Unicorn is offline   Reply With Quote
Old 07-14-2016, 04:27 PM   #168
Darkomarko
My Ride: E46 323ci
So does that mean disa from 330 wont fit to 2,5l manifolt? Sorry if it is stupid but i just want to know. Thnaks.
Old 07-14-2016, 05:00 PM   #169
mikeetastic
My Ride: lots of 3
yes wont work. its big. M56 disa is the same as M54B30 so you can buy that too in case you are looking.
mikeetastic is offline   Reply With Quote
Old 07-14-2016, 05:27 PM   #170
mikeetastic
My Ride: lots of 3
might do this on my 328i wagon. anyone know where to source the adaptor plate cheap or anyone selling PM me?
