///M3 Forum
Old 03-21-2013, 01:27 AM   #481
ANREC330
My Ride: C6 Vette & M3
78,380 and I haven't had a problem.
ANREC330 is offline   Reply With Quote
Old 03-22-2013, 11:32 PM   #482
monkawekrue
My Ride: 13 X3 AW/04 M3 AW
2003 -112,XXX all original no issues.
2004 -67,XXX all original no issues.
addicted.
monkawekrue is offline   Reply With Quote
Old 03-25-2013, 07:59 PM   #483
MACKY83
My Ride: 2002 Topaz Blau M3
2002 SMG. 97, 750 kms only last week I've gotten the emissions error and a rough idle with a significant loss of power. Changing out all plugs and coils hopefully this will work. Looking forward to having the 100k service Otherwise flawless performance delivered daily to a very aggressive driver. SMG FTW!
Sent from my GT-I9305 using Bimmer App
MACKY83 is offline   Reply With Quote
Old 03-25-2013, 10:10 PM   #484
M3 FOR LIFE
My Ride: BMW M3 E46
87k original pump no issues..
M3 FOR LIFE is offline   Reply With Quote
Old 04-08-2013, 12:49 PM   #485
hegamiz
My Ride: 2004 330Ci SSG
Does this cover us non-M owners? 2004 330Ci 120,000miles. Had the slave cylinder repaired recently. It was leaking hydraulic fluid. Other than that I love it.
hegamiz is offline   Reply With Quote
Old 04-08-2013, 07:08 PM   #486
Active 2
My Ride: 02 E46 m3
Just hit 250k last week
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 04-08-2013, 07:29 PM   #487
eson
My Ride: E46 M3, Porsche 911
Attachment 499499
How has your VANOS, subframe, and SMG pump held up? Any other notable issues/fixes?
| '02 LSB slicktop ///M |
StopTech. SGT. AKG. TMS. BimmerWorld. Sparco. Kirk. RE. Enkei. Meisterschaft.
eson is offline   Reply With Quote
Old 04-08-2013, 11:38 PM   #488
e36-2.0
My Ride: 330xi
02 55000kms no problems
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 04-09-2013, 12:31 PM   #489
Dirtbmw20
My Ride: 2002 M3
Attachment 499499
VERY encouraging.......
Dirtbmw20 is offline   Reply With Quote
Old 04-09-2013, 02:33 PM   #490
OfficinePanerai
My Ride: M3
190k here
[CENTER]
OfficinePanerai is offline   Reply With Quote
Old 04-10-2013, 01:35 PM   #491
E46 WOT
My Ride: 2004 M3 SMG
144k here, owned it since 78k bought it in Feb of 2009. Since then done 6 HPDE weekends and 4 private track days.
Recently when going from 3rd to 4th it's "missed" engaging the clutch and would grind for a split second until I take my foot off the gas and it catches the gear. It's only happened 5 times in the last year and a half but 3 were in the last two weeks, each time it's been when I'm driving fairly hard but seem to lift off the throttle some while making that shift (like catching a car I can't pass yet on the track or under some braking). it never happens going wide open and typically is attached to cornering or post cornering.
That's the only SMG issue I've had. besides that I did the fuel pump after the factory one died 3k miles ago, did the input seal on the diff 6 a year ago, replaced FCAB after tearing the driverside, and need to replace the oil pan seal as it has a small slow seepage. And replaced the drive shaft coupler (guibo) as it was torn to shreds a month ago... track time will do that!
2004.5 M3 SMG
CF CSL Trunk, CSL replica bumper, 18x9.5 BW Arc-8 w/ 245/265 R-S3s, PFC 08 pads, SS brake lines, Prospeed 683 Brake fluid, ISC N1 Coilovers, Powerflex poly RTABs, sways, and diff bushings, solid FCABs, BW performance motormounts, Rogue transmounts, BSW I-Pod Dock, Rookie BMWCCA Club Race license, 2:08.935 VIR Full Course, BW intake boot + K&N drop in filter. Borla catback exhaust.
E46 WOT is offline   Reply With Quote
Old 04-10-2013, 02:24 PM   #492
ANREC330
You might need to replace the clutch.
Old 04-10-2013, 07:57 PM   #493
Active 2
My Ride: 02 E46 m3
Vanos is holding up just fine
original SMG pump was changed at 241k
Subframe was reinforced at 241k (only had 1 small crack maybe 2 inches long)
My wheels speed sensor just died so i need to replace that (car has no dsc atm)
All of the bushings replaced (RTAB's, etc..)
Diff seals changed
other than that it has just been performance upgrades and lots of detailing maintenance
Thank you, I pretty much beat on my car and surprised its holding up so well
My last compression test about 1k miles ago was ~175 all the way across and made 285rwhp on mustang dyno with only tune, headers and filter. I want to go FBO and hopefully FI soon
Old 04-11-2013, 12:39 PM   #494
E46 WOT
It doesn't slip though, it grabs hard in every other gear, I'm wondering if it's the pump and under cornering it experiancing some kind of fluid starving or something.
2004.5 M3 SMG
Old 04-11-2013, 12:49 PM   #495
MisterM
My Ride: 03 M3
If the pump sees inadequate pressure codes will be stored and do not always give the yellow cog of death. You will need a BMW specific tool to read the SMG codes - Peake RC3 at a minimum but a GT1 would be preferred. The generic OBD2 tools will be of no use for the SMG.
My guess is the gear position sensor, accumulator leaking pressure or the actuator is getting grumpy.
All fairly easy DIYs and fixes.
MisterM is offline   Reply With Quote
Old 04-11-2013, 03:43 PM   #496
NorthJersey 3er
NorthJersey 3er's Avatar
My Ride: '03 M3 / '72 2002tii
your factory fuel pump lasted 141k??
Matt
co-founder of
euro techniks
NorthJersey 3er is offline   Reply With Quote
Old 04-15-2013, 12:11 AM   #497
AlpineKnight
My Ride: AW E46 M3
72,000 Miles. No issues aside from a sporadic fault that trip an smg light then went away and never came back! Have a salmon relay handy 24/7. Fault was "Smg ON PERIOD" No pump replacement yet.
AlpineKnight is offline   Reply With Quote
Old 04-15-2013, 02:19 PM   #498
creed
My Ride: 325i
141000 Miles. SMG pump has been replaced twice (@60K for free and again @120K for $5K incl. clutch). I wouldn't
buy it again, but I don't regret getting it. It's been fun.
creed is offline   Reply With Quote
Old 04-16-2013, 09:47 PM   #499
XKR
My Ride: 2001 M3 Convertible
not exactly high but a little over 41k on an 01. It has a pretty bad oil leak coming from inside the engine and it isn't accessible from taking the trans out so the whole engine has to be pulled, unfortunately..
XKR is offline   Reply With Quote
Old 04-26-2013, 04:20 PM   #500
Dwydz
My Ride: 2003 M3
just clicked over 50k miles on my 2003 m3, I bought mine last year this month at 40k miles. Drove it down to Florida from Illinois. It had basic maintenance done before I bought it not sure if it was Inspection II and all that but I have had no issues *cross fingers* My SMG light has turned on once but it was for a brief 20min period when it was very hot outside. When I restarted the car it turned off.
Question, I have only done an oil change and I changed my air filter as it seemed to be the original one in there. What would one more experienced suggest I look into doing? I took it two a trusty mechanic down the road to let me know what I needed done and it was basically my brakes, that's about it. Should I change my SMG fluid? Should I look more into inspection II??
Thanks!
You only live once.
Dwydz is offline   Reply With Quote
