///M3 Forum
Old 04-27-2013, 11:59 AM   #501
Active 2
My Ride: 02 E46 m3
Originally Posted by Dwydz View Post
just clicked over 50k miles on my 2003 m3, I bought mine last year this month at 40k miles. Drove it down to Florida from Illinois. It had basic maintenance done before I bought it not sure if it was Inspection II and all that but I have had no issues *cross fingers* My SMG light has turned on once but it was for a brief 20min period when it was very hot outside. When I restarted the car it turned off.
Question, I have only done an oil change and I changed my air filter as it seemed to be the original one in there. What would one more experienced suggest I look into doing? I took it two a trusty mechanic down the road to let me know what I needed done and it was basically my brakes, that's about it. Should I change my SMG fluid? Should I look more into inspection II??
Thanks!
Check your bushings, subframe, maybe a valve adjustment (if needed), diff seals, cabin filter, other small maintenance pieces
Hope this helps
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 04-29-2013, 12:18 PM   #502
E46 WOT
My Ride: 2004 M3 SMG
Originally Posted by NorthJersey 3er View Post
your factory fuel pump lasted 141k??
yep!
2004.5 M3 SMG
CF CSL Trunk, CSL replica bumper, 18x9.5 BW Arc-8 w/ 245/265 R-S3s, PFC 08 pads, SS brake lines, Prospeed 683 Brake fluid, ISC N1 Coilovers, Powerflex poly RTABs, sways, and diff bushings, solid FCABs, BW performance motormounts, Rogue transmounts, BSW I-Pod Dock, Rookie BMWCCA Club Race license, 2:08.935 VIR Full Course, BW intake boot + K&N drop in filter. Borla catback exhaust.
E46 WOT is offline   Reply With Quote
Old 04-29-2013, 12:20 PM   #503
E46 WOT
Originally Posted by MisterM View Post
If the pump sees inadequate pressure codes will be stored and do not always give the yellow cog of death. You will need a BMW specific tool to read the SMG codes - Peake RC3 at a minimum but a GT1 would be preferred. The generic OBD2 tools will be of no use for the SMG.
My guess is the gear position sensor, accumulator leaking pressure or the actuator is getting grumpy.
All fairly easy DIYs and fixes.
Yeah I need to dive in and see what codes are in there, my SES has been on and off for a few months now, maybe it's related. Good advice!
2004.5 M3 SMG
Old 12-08-2013, 06:17 AM   #504
hemi6
My Ride: M3
134,000 miles: original fuel pump, alternator, just tuned by FS, 300rwhp and runs perfect. Just replaced the original shocks w/Koni yesterday.
Mike
2004 M3 Coupe, Euro headers, 200 cell cats, tuned by FS.
hemi6 is offline   Reply With Quote
Old 12-08-2013, 11:58 AM   #505
SteveEvans
My Ride: 2003 M3 Coupe SMG
Just past 165K and on the original clutch. There, I've said it. Fate tempted!
Steve
SteveEvans is offline   Reply With Quote
Old 12-09-2013, 09:37 AM   #506
Dwydz
My Ride: 2003 M3
thanks for all the great input!
You only live once.
Dwydz is offline   Reply With Quote
Old 12-18-2013, 02:55 PM   #507
Goku9384
My Ride: 03.5 BMW M3
102k miles original smg no issues.
Goku9384 is offline   Reply With Quote
Old 06-06-2014, 06:20 PM   #508
AMG&M3Lover
My Ride: 2002 Mercedes ML-320
Exclamation Help!
Hey I'm new here, and I'm seriously considering/about to buy 2002 M3, and at this particular dealership, there are two 02 M3's a 115k SMG with everything I want (Laguna Seca Blue too!) and a 95k 6MT, I have read over so many reviews. Now this car will be a graduation gift, so I won't be driving it much any other time than summer's probably less than 3k a year. I take care of my cars even my 91' Accord with 185k. And I have been in the Mercedes brand for a lonnng time from C-220 to S500 4Matic with all the bells and whistles, so maintenance cost aren't new, nor do they scare me. Should I be afraid of the SMG, I really like that one too. And more specifically am I going to walk into a $4500 transmission headache or should I not be concerned. I don't drive too aggressively and only enjoy exercising the right toe when its just right. Also note a 112k 05 S60 R and a 78k 05 S4 is in the mix too. Help me please!
AMG&M3Lover is offline   Reply With Quote
Old 06-07-2014, 12:47 AM   #509
TitanSl33pr
My Ride: 330ci
Smile
Happy to hear that you are about to join in on owning an M3. However, not quite the thread for your post. In fact, there are many threads that inquire the same exact questions...check them out. To entertain a portion of your concerns, a pre-purchacse inspection (ppi) is imperative! It does't matter 6T or SMG if you don't do that. The ppi will be more detailed than looking for oil leaks and listening weird noises, i.e. subframe cracks. As for 6MT vs SMG, it comes down to preference. I have an 03 steel gray with SMG. I didn't care either way, plus I've had straight shift coupes since I started driving. Actually, I liked the idea of having the option of paddle shift. If both turn out to be in great shape, then I would seriously consider the 6MT. They are a bit more rare and will give a more real driving experience. I hope this helps and much success to you and your M3 purchase.
TitanSl33pr is offline   Reply With Quote
Old 06-07-2014, 10:30 AM   #510
AMG&M3Lover
Hey thanks a lot. Also yeah I was new I think I've found more treads as well, and that honestsly answered my question. When the E46 M3 came out I was like 7, so now that I can actually afford one it's like a dream come true haha. Thanks again!
