Old 07-29-2009, 07:40 PM   #1
M3 Baddie
My Ride: 05 M3 SMG
Unremovable grime? on windows
Hey guys I have this grime on the windows all of them that dosn't seem to wash off at all. It looks liek dried rain or something of the sort, I know dosnt help with out pictures. Its been raining so when its dry ill get a pic asap. It really looks like dry rain streaks they dont wipe away or wash off at all. Would there be a product or technique i could use to get it off? TIA guys! i didnt know where to post this but i figured you guys might know!
///M3
M3 Baddie is offline   Reply With Quote
Old 07-29-2009, 08:02 PM   #2
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
It sounds like you have etchings from hard water. You can try a 50/50 mix of water and vinegar or use a clay. This usually helps with ultra faint etchings. More noticeable etchings can be cleaned with the Glass Science Glass Scrub. Just pour about a nickel sized drop on a wet foam applicator, rinse the glass and then buff on the product with medium pressure. It helps take care of about 95% of the water marks I've had to deal with.
Greg @ DI
Old 07-30-2009, 02:21 AM   #3
M3 Baddie
My Ride: 05 M3 SMG
Thanks I'm deff gonna try this tommorrow!
///M3
Old 08-03-2009, 01:58 AM   #4
Nuori
_
Nuori's Avatar
My Ride: A 323 mule pepe
The cheapest and simplest solution would be: Steel wool and window cleaner.
Nuori is offline   Reply With Quote
Old 08-03-2009, 04:18 PM   #5
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
you can also use water & newspaper, the ink acts as a polish
Chris
dreamdrivedrift is offline   Reply With Quote
Old 08-03-2009, 04:23 PM   #6
Custom3
My Ride: HellRot 330CI
tried scraping it off with a razor blade?
Old 08-04-2009, 01:39 PM   #7
vberch
My Ride: '03 BMW 325Ci Conv
I just removed mine with Mr. Clean Magic Eraser.
I was cleaning my steering wheel and decided to polish the windows at the same time. It did great job on both!
Oh yes, it is made in Germany .
Detailed Image Auto Detailing Supplies
BMW CCA Member | Badger Bimmers Member | Gallery
vberch is offline   Reply With Quote
Old 08-05-2009, 02:22 AM   #8
trudnick
My Ride: 2005 M3
+1 to distilled vinegar and water.
Good luck.
This is a useful thread on Magic Eraser.
http://www.m3forum.net/m3forum/showthread.php?t=199151
2005 BMW ///M3 / Carbon Black / Black Leather / 6MT
OEM BMW Performance Short Shift Kit, Illuminated ZHP Knob, XM Direct, DICE iPod, Color Matched Reflectors, Hoen Fogs, Stealth Corners, V1 (3.872) Hardwire, Eibach Pro-Kit, RE 15mm-F/12mm-R Spacers, CDV delete, Clutch Stop, Summer OEM ZCP 19s: Vredestein Ultrac Sessantas (245/275), Winter OEM 18s: Dunlop SP Winter Sport M3s (225/255), Self-installed OEM Alarm & OEM Homelink UGDO.
trudnick is offline   Reply With Quote
Old 08-05-2009, 08:30 PM   #9
M3 Baddie
My Ride: 05 M3 SMG
These are the water spots they havn't come off yet tried a razor no luck at all.
///M3
Old 08-05-2009, 08:43 PM   #10
M3 Baddie
My Ride: 05 M3 SMG
tried distilled vinegar and water aswell but nothing.
///M3
Old 08-05-2009, 09:19 PM   #11
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
This sounds odd. But i used Meguiars Cleaner wax. I have very bad water at my house, I have spots like that on my windows.
Once you use the as take it off with a MF and then go over it with your glass cleaner of choice. I like Stoner's Invisible glass.
And it should be good to go.
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 08-06-2009, 10:19 PM   #12
M3 Baddie
My Ride: 05 M3 SMG
If it is mineral deposits in the windows will the Glass Science Glass Scrub work well or is something more powerful needed?
///M3
Old 08-06-2009, 10:40 PM   #13
M3 Baddie
My Ride: 05 M3 SMG
OK so, there was another thread i stumbled upon through google brought me to an e46 forum "big A's Detailing" these are Acid Rain Spots!
http://forum.e46fanatics.com/showthread.php?t=663864
now to figure out how to get rid of them !
Edit:
"Glass Science Glass Scrub applied by Porter Cable for heavy acid water spot stains on every glass window, including sunroof"
Is used to get rid of them TY all!!
///M3
Old 08-06-2009, 11:19 PM   #14
So Lowww
My Ride: E36M
Steel Wool FTW!!
ur
S T A N C E | W O R K S
So Lowww is offline   Reply With Quote
Old 08-06-2009, 11:41 PM   #15
stolidog
My Ride: 2004 M3 6spd
Originally Posted by kk325xi View Post
Steel Wool FTW!!
ur
+1...
But please use 0000 Steel wool... not your normal kitchen sink stuff.
stolidog is offline   Reply With Quote
Old 08-10-2009, 11:59 PM   #16
M3 Baddie
My Ride: 05 M3 SMG
the 0000 steel wool had no effect on these spots! I'm trying Spot-X which seems to be doing the job, tho very slowly =[
I've got no buffer to use Glass Science Glass Scrub that Greg recomended.
///M3
Old 08-11-2009, 12:17 AM   #17
bigfatvr6prik
My Ride: Z8
+1. Worked wondered on my windows/windshield. Dealership apparently use this technique.
bigfatvr6prik is offline   Reply With Quote
Old 08-11-2009, 11:46 AM   #18
mujjuman
My Ride: not an E46
i hate the etchings! thanks for the magic eraser/newspaper tricks
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 09-07-2009, 09:39 PM   #19
04_330ci
My Ride: 2004 330ci
Stoners invisible glass even says on the back "some professionals use news paper to clean" I havent tried it yet but i have the same problem, well something to try tomarrow i guess...thanks guys!
04_330ci is offline   Reply With Quote
Old 09-08-2009, 07:42 PM   #20
You don't need a buffer to apply the Glass Scrub. From my understanding a hand application can be used, just apply a nickel sized drop on a wet applicator and buff it on in a circular motion. Rinse the surface thoroughly when you are done.
Greg @ DI
