Old 03-09-2014, 11:59 PM   #1
Kayss
My Ride: Bmw 328i 1999
Overtightened valve cover
Just put a new vcg on and im thinking I overtightened my valve cover by quite a bit. Is this goint to cause a problem. Can I still loosen the bolts and retorque them?
Sent from my SGH-I337M using BimmerApp mobile app
Kayss is offline   Reply With Quote
Old 03-10-2014, 12:07 AM   #2
Knight
My Ride: '05 330Ci | '01 325i
The key here is that nothing was snapped/stripped. If you are sure you overdid it, then I would loosen the bolts and re-tighten them in the proper pattern using a 1/4 inch drive ratchet. Keep going until the bolts bottom out and then give each one an 1/8th turn afterwards for good measure.
Knight is offline   Reply With Quote
Old 03-10-2014, 12:10 AM   #3
new//M3fan
My Ride: 77' 924 87' E30
You can't overtighten the VC.
The nuts have a sleeve that will bottom out with the stud nut below. It's supposed to do that then tq to 10-14ftlbs-- I forget-- I just turn 1/8 of a turn once it has bottomed out. This mean's the sleeve will touch the top of the nut stud. So no you can't overtighten the VC. What CAN happen is snapping the stud of lol
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 03-10-2014, 01:48 AM   #4
Phoenix330ci
My Ride: 04 330Ci Convertible
Yeah just did mine tonight. They bottom out and then the torque wrench will snap at 10 Nm. I have done this several times and have not broken a stud yet.
Foot pounds is too much.
Phoenix330ci is offline   Reply With Quote
Old 03-10-2014, 02:06 AM   #5
Cowspoo
My Ride: 328Ci
No! They're to be 6 ft/lbs. Better yet. Don't even torque. Just tighten until they stop, then try a little further. Anything more and you'll strip it.
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 03-10-2014, 03:57 AM   #6
jcns
My Ride: California
before you do anything, go buy a good torque wrench. Trust me, it will pay off for years to come.
Loosen, tighten and use a torque wrench to finish off.
Ensure you have a new VCG just in case it leaks. VCG are supposed to be one time use.
jcns is offline   Reply With Quote
Old 03-10-2014, 05:41 AM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I just get to 'bottoming out' and stop. This is the first I've heard of going 1/8th after bottoming out. I think that that might be enough to snap the stud...and it's because of using a 'too large' torque wrench that this happens at all. Tighten from the center out in the prescribed pattern in stages.
Some here 'bottom out' and then back off each screw a little...so bottoming out is enough. If you didn't break a stud, I'm sure you're fine...as long as you did do it in the proper pattern in stages.
gl...hth
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-10-2014, 10:43 AM   #8
Kayss
Yeah I did everything in the proper steps and then I tightened until it wouldent go anymore but I put some effort in, any more I would have stripped the bolts. Do you think im good or should I still go and do it over? Worst case I have a spare EZ vcg that came with my vanos kit.
Old 03-10-2014, 10:47 AM   #9
Kayss
And ive got a shwaben torque wrench but i didnt think it would be nessesary. Im not too woried since I have a spare but it would be nice to have that one for the next time I do this.
Old 03-10-2014, 10:58 AM   #10
WDE46
My Ride: '13 128i, '04 330Ci
You're fine.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 03-10-2014, 11:13 AM   #11
Kayss
Good to know. Thanks for the help guys.
Old 03-11-2014, 06:07 PM   #12
new//M3fan
Bottoming out is what I meant.
