Old 07-29-2009, 08:04 AM   #1
vanessahudgensfan
My Ride: swapped eg6
Help clutch pedal dead and car won't go in gear
I started my car this morning while noticing my clutch pedal was gone. the car barely started and it won't go in gear i'm thinking its the clutch or a throw out bearing. the car does start but undriveable. how much am i looking at to get it fixed?
vanessahudgensfan is offline   Reply With Quote
Old 07-29-2009, 09:38 AM   #2
vanessahudgensfan
could it be a slave/master cylinder
Old 07-29-2009, 09:40 AM   #3
TX_Bullet
My Ride: 2001 325Xi
Thats what it sounds like.
Slave cylinder usually run $60 and take less than an hour to do.
Just replaced one on my friends e36, his clutch pedal was on the floor.
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 07-29-2009, 09:44 AM   #4
vanessahudgensfan
haha damn thats how mine is...did his car not go in gear after he started it as well??
Old 07-30-2009, 10:06 AM   #5
vanessahudgensfan
can anybody else give their opinion
Old 07-30-2009, 10:38 AM   #6
TX_Bullet
My Ride: 2001 325Xi
You could start the car in neutral, but not go into gear.
What happens is the seal inside cause bad over time and leaks. While you down there you should probably go ahead and do the CDV delete.
The Mods
Power Flex FCAB
Old 07-30-2009, 10:44 AM   #7
vanessahudgensfan
yea for sure do you think the leaking caused the faint burning smell from the vents then
Old 07-30-2009, 10:50 AM   #8
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
Check the fluid
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 07-30-2009, 10:53 AM   #9
TX_Bullet
My Ride: 2001 325Xi
Originally Posted by ferrarix99 View Post
Check the fluid
I was assuming he already checked, but just to be sure you know where the clutch fluid goes........its the same where your brake fluid goes. BMW set it up to where you would lose your clutch pedal before your brakes
The Mods
Power Flex FCAB
Old 07-30-2009, 10:58 AM   #10
mvrk10256
My Ride: E30 325i
ya, i had this problem on another car. if you keep putting in brake fluid and keep some in your trunk you can drive around for a while before replacing (depends on how much you leaking. I drove around for a week with a few bottles of brake fluid in my trunk. its the air bubble that forms in the line from lack of fluid. air doesnt compress like brake fluid does. hence no clutch movement. In my experience its the slave that goes first so thats where i would check. However i have never done this on a BMW so ihave no idea where it is or how much it costs....
am curios however is the safety cluch to the floor before starting car feature linked to a sensor in the pedal (ie the pedal has to be to the floor regardless of clutch positions) or if the sensor is linked to the clutch itself.... cause on my pontiac when i had the same problem the car would also start.
Old 07-30-2009, 11:03 AM   #11
vanessahudgensfan
alright i'm gonna check my clutch fluid, when i get home if its all gone where should i buy clutch fluid so i need BMW brand or???
Old 07-30-2009, 11:40 AM   #12
TX_Bullet
My Ride: 2001 325Xi
You need DOT4 brkae fluid, brand really doesn't matter unless your doing auto cross.
As for the clutch safety switch you need to have the clutch dam near pressed to the floor. That is really the only reason I don't have a clutch stop
The Mods
Power Flex FCAB
Old 07-30-2009, 11:53 AM   #13
vanessahudgensfan
thanks man
Old 07-30-2009, 11:55 AM   #14
mvrk10256
My Ride: E30 325i
I used autozone brand. its like 99 cents a bottle and its DOT4 works like a dream .
when you get home with the fluid, pour it in and then get into the car and pump the clutch (with car off) until the feeling returns. that way you know the air bubble is out. just make sure the break fluid cap is on tight.
i feel you on the clutch stop but taht doesnt actually make the switch be on the pedal area.....
Old 07-30-2009, 12:12 PM   #15
vanessahudgensfan
thanks man i'm definetly gonna grab some how many bottles should i buy
Old 07-30-2009, 02:43 PM   #16
TX_Bullet
My Ride: 2001 325Xi
A standard bottle should work. When I did my master cylinder and slave cylinder and bleed it with the Motive bleeder I didn't even use all of the liter.
On your clutch pedal, there are 2 sensors, one is the safety switch and the other is for the cruise control(if you hit your clutch pedal while using cruise control it will cut it off)
The Mods
Power Flex FCAB
Old 07-30-2009, 05:02 PM   #17
Poon Stick
My Ride: ///M 330xi Sedan
You may find that you're not missing any fluid at all - this happened to me with my e30. The internal seals in the master cylinder went so the clutch did nothing when pressed and didn't return. No fluid was missing as it was just going past the piston in the cylinder.
Poon Stick is offline   Reply With Quote
Old 07-30-2009, 08:17 PM   #18
vanessahudgensfan
Oh okay so is this hurting my clutch...the car is going to the dealership tomorrow hopefully the warranty will cover it but will the clutch need to be replaced
