Thread Tools Search this Thread Rating: Thread Rating: 28 votes, 4.93 average. Display Modes
Old 08-05-2009, 11:39 PM   #1
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Cool Pictorial DIY: BMW E46 Fan Clutch Removal & Engine Belts Change For Automatic Cars
Because every DIY I've seen are for manual cars without the stupid fan in the way. This DIY is for the rest of us who own automatic cars. Also for everyone that is in need of possibly pulling out their water pump since removing the fan clutch nut is the exactly what you will have to do on all cars (whether manual or automatic) to get the water pump out.
The belts DIY is easy in itself. The large pictures and crayola text within each picture below should give anyone with a brain the basic idea of what to do. I've changed belts on older BMW cars before without having to bother with the fan (like on the M44 engine) so the fan removal part of the M54 DIY was always a mystery to me and many with automatic E46 cars. Many of us followed all those website and forum DIYs, that was using manual cars for their DIY projects, up until we realized there was a big a$$ fan in there for our cars and couldn't go any further.
This DIY shows you how to safely remove the fan, belts, look at the inevitable water pump/thermostat failure regions and put everything back in.
My DIYs do not end in the middle, like most DIYs, and leave you stranded . I show you how to double check what you did and safely put everything back in there.
WATER PUMP and THERMOSTAT DIY QUICK INFO:
Only read this bit if you are interested in these tasks.
Said and done, if you can do this DIY then the water pump/thermostat DIYs will be not much more difficult, if not as easy. With the fan clutch out and shroud out and coolant drained, all that is left is removal of the bolts and bits that hold the water pump and thermostat in place. These are right there in front of you.
My car only has 49k on the clock, as of this writing, but it is still a 7-8 year old car so I plan of changing my plastic OEM pump and thermostat housing for the metal high performance water pump and an aluminum body thermostat housing over the next couple of months just to be safe.
HERE IS THE BMW M54 E46 Automatic Fan Clutch & Engine Belts DIY:
delmarco is offline   Reply With Quote
Old 08-05-2009, 11:40 PM   #2
delmarco
PART 2
Old 08-05-2009, 11:47 PM   #3
delmarco
PART 3
Old 08-05-2009, 11:50 PM   #4
delmarco
PART 4
Old 08-05-2009, 11:52 PM   #5
delmarco
PART 5
After you are done and double checked everything (including those front-fan shroud/radiator connector plugs) get yourself cleaned up and go start your car leaving the hood up and the windows down. Keep your hand on the key in case you have to shut off the engine immediately.
If the engine starts up okay and everything sounds and feel normal (no squealing or fierce vibrations) after a minute or two go look under the hood. The fan and belts should be moving okay. My fan seemed wobbly for the first couple of minutes but after it was okay-leaving me thinking it was just my imagination.
The worse that can happen is usually the fan blades either break off spontaneously and/or the fan comes off, thus exploding sending pieces of hard plastic everywhere. This is why you NEVER drop the fan, lay it flat or damage it if during the DIY you plan on using it again. Even if one blade gets chipped or scuffed then the fan can quickly lose equilibrium and wobble itself to bits destroying your engine block and hood.
This is also why it is best to first start the engine with the hood up and everyone clear of the engine bay, and your hand on the key in case you have to cut the engine off pronto. I think the rule of thumb is if your fan doesnít explode right away you should be good.
That is it! DIY completed! Now itís time to think about that inevitable WATER PUMP failure prevention upgrade and Thermostat Housing upgrade DIY.
Enjoy,
Delmarco.
Old 08-06-2009, 02:10 AM   #6
Shayn
My Ride: 325ci
Well done, good write up!
Shayn is offline   Reply With Quote
Old 08-06-2009, 08:40 AM   #7
delmarco
I got a few more DIYs coming by the Fall.
1. Replacing the E46 plastic-army of fail: WaterPump/Themostat Housing/Fan Pulley Wheel with all aluminum/metal parts.
2. BMW Coolant Flush
3. E46 Power Folding Mirrors Parts 2 and 3 complete
4. Window Regulators (maybe)
Old 08-06-2009, 09:28 AM   #8
skang330
My Ride: 2005 E46 330ci
Send a message via AIM to skang330
Very Very Nice!
skang330 is offline   Reply With Quote
Old 08-07-2009, 02:55 PM   #9
libmotors408
My Ride: 2002 BMW 330Ci
Job Well DONE!
Sweet post. It shows you love your cars! Thanks for taking the time in doing such a great write up!
I can attest to forgetting about attempting to do this job without the 32mm wrench and pulley holder! Forget-a-bout-it!
libmotors408 is offline   Reply With Quote
Old 08-08-2009, 12:30 PM   #10
GurvM3
My Ride: 02 M3
thx for the awesome diy!
GurvM3 is offline   Reply With Quote
Old 08-08-2009, 12:34 PM   #11
ginpunk
My Ride: E46
Got to have the wrenches as noted above.
I just did this two weeks ago and the pulley method to de-tension the belts is not right. Use 16mm (or 5/8s) as well as appropriate torx (60 if I recall) on the a/c belt. You will be happy you did it this way.
ginpunk is offline   Reply With Quote
Old 08-08-2009, 01:10 PM   #12
delmarco
you mean a T50 Torx for the AC. Also known as a Brake/Caliper RemovalTorx.
Yeah, lots of DIY want you to de-tension the pulley at the pulley tension wheel with a T50 but I quickly realized that way is ridiculous. The 16mm or 5/8 ratchet is 100 times easier and 1000 times safer.
Old 08-08-2009, 01:21 PM   #13
packrat555
My Ride: 2001 325i
I got my fan off using a 1 1/4 (32mm) wrench using the whack it with a hammer and let the belt tension hold the fan method (another diy shows this technique). I didn't really expect it to work so easy but the second whack and it was loose.
packrat555 is offline   Reply With Quote
Old 08-10-2009, 09:29 PM   #14
bmwmedic
My Ride: 323i 99 01 530i sp
Nice DIY, thanks
Any tips anyone on separating those "quick disconnect" hose ends FROM EACH OTHER?
The ones from the radiator came off OK, but the hose to hose connections on the drivers
side where the first hose from the radiator (which I planned to replace) connect to the second hose
that runs to the firewall connections??
thanks
BTW, nice timing too Last weekend I drove 500 miles with a leaking radiator in my 01 530. the radiator was half empty when I returned.
the first picture shows a white line starting at the base of the neck for the hose where it was dripping
the next shows what happened when I GENTLY (REALLY) tried to remove the hose!
Holy crap, the radiator plastic was dust, all of it. and to think I was just bragging about how mine was still original at 150k and 8 yrs!
ID:	326858   Click image for larger version
bmwmedic is offline   Reply With Quote
Old 08-11-2009, 12:37 AM   #15
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
that only works if you have a mechanical tensioner however. If you have a hydraulic tensioner you have to use the T50 bolt.
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
Old 08-11-2009, 01:00 AM   #16
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Was just about to mention this.
Great write-up I have a manual so I don't have to worry about the fan, however if I didn't, a DIY like this would be just what I was looking for. You may also want to mention that the fan clutch is reverse threaded, don't recall reading that above. Pretty important note to make in a DIY like this, IMO.
-Gary
DiscoStu is offline   Reply With Quote
Old 09-07-2009, 10:35 PM   #17
delmarco
You know I honestly didn't even notice it was reverse thread. Sorry. I'll fix the picture.
Old 09-07-2009, 11:11 PM   #18
Riverbmr3
My Ride: MB E350 & BMW 325i
nice DIY
Riverbmr3 is offline   Reply With Quote
Old 09-15-2009, 04:24 PM   #19
VladE46
My Ride: 2001 325CI - E46
Thumbs Up
Great write-up. My first time using how-to's from the forum and worked like a charm. Appreciate the post.
VladE46 is offline   Reply With Quote
Old 09-16-2009, 06:27 AM   #20
2001bmwe46
My Ride: '01 ci
nice DIY. It'll help a lot of auto e46 owners. I'm glad I don't have to go through that since manuals don't need a fan tool
2001bmwe46 is offline   Reply With Quote
