Thread Tools Search this Thread Rating: Thread Rating: 28 votes, 4.93 average. Display Modes
Old 06-04-2010, 10:20 PM   #61
zorin
My Ride: 84 318i / 05 325i
you don't have to remove the fan clutch to do the belts - belt goes over the blades and rests on water pump pulley.
Founder & President of Executive Edition Executive Club
2005 e46 325i executive edition / 18" Hartge Classic / Vogtland springs / Depo clears / CSL spoiler / CF CAI / 330i front brakes / ACS roof spoiler / full OEM MTECH 2 kit / Clubsport splitters / UUC Sway Barbarians / UUC Underdrive Pulleys / powered ACS replica mirrors / OEM sport driver seat
zorin is offline   Reply With Quote
Old 06-23-2010, 07:18 PM   #62
golf_234
My Ride: E46, E90
+! thank you delmarco just did my fan clutch using your DIY. (had laptop by car lol) only tip i have is on retightening, instead of tightening futilly with the wrench, you can actually spin the fan gently by hand once the thread has caught and use the viscosity of the fan clutch to tighten back up, then finish with a wrench ( i just let mine spin on ) ps to all e46 auto people: check your fan clutch!!. also the auto fan removal tool is amazing for this job. It is one of those things you should just have. The difficulty of auto compared to manual is drastically exaggerated by most forum members; all you need is the tool and it is very easy. Just get it.
golf_234 is offline   Reply With Quote
Old 06-23-2010, 11:10 PM   #63
golf_234
My Ride: E46, E90
whyy so stubborn haha. It is very easy to take out the fan and should be done. its like 15 min, lol.
Old 07-01-2010, 06:46 PM   #64
CantW84GTR
My Ride: F-16
nice write up.
i was curious to know if anyone has done this with their m3
main drive tensioner
http://www.realoem.com/bmw/showparts...98&hg=11&fg=18
it seems that i have a hydraulic tensioner which does not have the hex for easier release. my question is what to expect when i loosen this torx. i imagine that once i start loosening it, the tension is suppose to loosen? i do not have to take the whole torx out correct?
many thanks
CantW84GTR is offline   Reply With Quote
Old 07-09-2010, 01:38 PM   #65
YOnpds
My Ride: E46
Awesome DIY. Thank you!
YOnpds is offline   Reply With Quote
Old 07-09-2010, 02:22 PM   #66
JM323
My Ride: 5 speed 2003 325i
youre the man!
JM323 is offline   Reply With Quote
Old 07-10-2010, 12:43 AM   #67
330ciwp
My Ride: '01 330ci
Great visual write up. I changed out my tensioner last weekend following some of these tips. Although I used an $8 wrench from Northern Tools and long flat blade screwdriver to break loose the fan nut.
330ciwp is offline   Reply With Quote
Old 07-10-2010, 05:11 AM   #68
n2siast
My Ride: 02 330ci
Ditto, searched locally for the fan clutch tool, needed to change my alternator. Couldn't find the tool and got the northern tool wrench for 8 bucks.
I just banged the wrench against the threaded portion and it loosen up right away. It's a tight spot to work with the wrench, but it works.
Quick and easy diy for my alternator, will be doing all the belts, tensioner and idler pulley this weekend.
Thanks OP for the write up, saved me a few hundred bucks.
n2siast is offline   Reply With Quote
Old 07-10-2010, 11:14 PM   #69
330ciwp
My Ride: '01 330ci
Exactly.
Like other people have said, this can be done without the $40 ebay wrenches. $8.29 32mm combination wrench from Northern Tools, and a long screwdriver. I've worked on a lot of different cars through the years, and always used the wrench/screwdriver method to remove fans or fan clutches without a problem. My only concern with this car was the "plastic" water pump pulley, and the possibility of cracking somehow. After smacking the wrench with a 3lbs hammer like I've seen on here, I gave up thinking I was going to end up breaking something. I removed the airbox so I could get to the lower bolts on the W/P pulley and wedged the screwdriver onto the head of bolts and pulled on the wrench with medium force to get a gauge of things. Pulled on it harder the next time and the nut broke loose.
Old 07-12-2010, 04:19 PM   #70
SHK&BAK3
My Ride: rustles jimmies
Thanks for the write up, I should be using it next weekend : )
SHK&BAK3 is offline   Reply With Quote
Old 07-12-2010, 09:32 PM   #71
SHK&BAK3
Delmarco who was the seller you bought the fan clutch tools from?
Old 07-29-2010, 09:09 PM   #72
ILLuSioNz X
My Ride: 03 TiAg E46 M3 Coupe
great write up delmarco, now if i can only find somebody local to rent the fan tools from.
-Chauncey
2003 E46 M3 COUPE
Check out my for sale threads: Misc. OEM E46 M3 Steering Wheel Parts | (2) H&R 2.5" 650lb/in coilover springs - $85
ILLuSioNz X is offline   Reply With Quote
Old 07-29-2010, 11:10 PM   #73
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
It was some random guy I think.
Also look for the GM fan tools on eBay it is the same as the BMW fan tools and cheaper.
delmarco is offline   Reply With Quote
Old 08-02-2010, 06:27 PM   #74
stapler12345
My Ride: Mineral White F30
32mm wrench code is 115040
pulley holder code is 115030
115040 Northern Tools 8.29 + 5.99 = 14.28
110303 El Paso Tools (ebay seller) 19.95 + 7.50 = 27.45
Total 41.73
If anyone can find me the tools for less, please post the link!
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 08-03-2010, 05:20 PM   #75
dbronnik
My Ride: '03 OB 325i
Originally Posted by libmotors408 View Post
Sweet post. It shows you love your cars! Thanks for taking the time in doing such a great write up!
I can attest to forgetting about attempting to do this job without the 32mm wrench and pulley holder! Forget-a-bout-it!
Just did this job this weekend... Forgot about the special tool though and just fabricated my own.. (just a long skinny piece of scrap metal with 1 hole in it to hold the pulley by the screw). Didn't use any fancy 32mm wrench either, managed to get by with a large adjustable wrench (had to take remove air intake and a hose coming off the radiator to get my big wrench to fit though!).
anyway, good writeup, wish I saw this before I figured this stuff out on my own!
<- "special" tools!
dbronnik is offline   Reply With Quote
Old 08-09-2010, 02:50 PM   #76
stapler12345
wow, i just ordered the tools (32mm wrench & pulley holder) to do this DIY literally seconds ago and then logged on to facebook to see this on my newsfeed
Old 08-11-2010, 06:56 AM   #77
jongy
My Ride: 2002 BMW325xi
Awesome!
Your DYI is simply awesome!!!
I'll try this soon
jongy is offline   Reply With Quote
Old 08-12-2010, 08:31 AM   #78
stapler12345
Old 08-25-2010, 07:57 PM   #79
stapler12345
are the Conti belts OE? I just pulled my belts and the main belt (Conti) seems fine (i bought my car used so im not sure what the guy before me changed)
Old 08-25-2010, 08:25 PM   #80
delmarco
OEM. Conti's are OEM.
