Thread Tools Search this Thread Rating: Thread Rating: 28 votes, 4.93 average. Display Modes
Old 09-06-2010, 06:20 PM   #81
stapler12345
My Ride: Mineral White F30
i did the a/c pulley and the tensioner pulley last time. today, i decided to put in the idler pulley and pulled a delmarco and broke one of the water pump pulley screws as i was torquing the fan clutch. where i can pick up some new screws and what spec are the screws?
also, the Northern Tool 32mm wrench is rather thick. wish i had bought the thin wrench that delmarco had rather than be cheap...
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
Old 09-17-2010, 05:53 PM   #82
mugsy77
My Ride: 2001 BMW 330ci vert
Just wanted to let my fellow enthusiasts know I found a great quality clutch fan kit (both 32mm wrench and holder) for $34.99 on Koch Tools website. I looked on ebay and amazon, and just ran into these pups which I feel better about to purchase.
http://www.kochtools.com/index.php?p=product&id=115
2nd Day Fedex was $17.40 which is pretty dang good imo.
Total: $52.39 (tons cheaper then what I have seen online, and this set looks like it's much better quality
mugsy77 is offline   Reply With Quote
Old 09-17-2010, 11:11 PM   #83
stapler12345
also, if you take out the air filter and its enclosure, you can apply the clutch tool much easier
Old 09-30-2010, 01:26 PM   #84
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
Originally Posted by delmarco View Post
I got a few more DIYs coming by the Fall.
1. Replacing the E46 plastic-army of fail: WaterPump/Themostat Housing/Fan Pulley Wheel with all aluminum/metal parts.
2. BMW Coolant Flush
3. E46 Power Folding Mirrors Parts 2 and 3 complete
4. Window Regulators (maybe)
Your DIY are Excellent, and PERFECT pictorial.
sellsellsell2000 is offline   Reply With Quote
Old 09-30-2010, 02:12 PM   #85
Wreckless
My Ride: E60 528xi
Once again, lots of great info!!
Wreckless is offline   Reply With Quote
Old 09-30-2010, 02:14 PM   #86
Wreckless
My Ride: E60 528xi
Maybe I'm completely missing it but I don't see the holder on there anymore.
Old 09-30-2010, 08:08 PM   #87
steve.325i
My Ride: 2003 325i
They must have redone the product id's ...
http://www.kochtools.com/index.php?p=product&id=2
http://www.kochtools.com/index.php?p=product&id=5
steve.325i is offline   Reply With Quote
Old 10-01-2010, 10:25 AM   #88
Wreckless
My Ride: E60 528xi
Originally Posted by steve.325i View Post
Will that Mercedes holder work on a BMW? The BMW one I've seen looks a lot different than that one.
Old 10-04-2010, 07:26 PM   #89
steve.325i
My Ride: 2003 325i
I am not 100% sure. I have emailed kochtools but I haven't had a response yet.
Old 10-05-2010, 11:39 AM   #90
steve.325i
My Ride: 2003 325i
I am sorry - I am incorrect. Kochtools says they do not think this tools will work on BMW's.
I personally have this one:
http://www.bimmertools.com/Fan-Clutc...00-sl62100.htm
But I have seen the three hole style available for teh BMW somewhere. I would actually prefer the three points of contact for a better hold.
An overpriced ebay add has wrenches for both cars:
http://cgi.ebay.com/ebaymotors/OTC-6...item35a6ab49d5
One just for BMW:
http://cgi.ebay.com/ebaymotors/BMW-G...item4cf1e97d01
Old 10-25-2010, 08:14 PM   #91
Pancho328i
My Ride: 328i
Strange that almost noone mentions that when you de-tension the tensioner there are two holes that align on it, you can put a pin/nail/allen wrench in there and it will hold it in that position.
You can then calmly set up your belt. When it is all set de-tension a little more, remove pin and slowly let the tensioner go back to press on the belt.
It-s quite an elegant solution. It prevents you from having to push on the ratchet with one hand while trying to position the belt with the other.
Pancho328i
2000 328i Single Owner...me ;)
Pancho328i is offline   Reply With Quote
Old 10-26-2010, 02:26 PM   #92
LeontiyZHP
My Ride: '04 330Ci ZHP
Great Writeup! Def need to refer to this when I get a chance to work on the car!
Leo
2015 BMW 335i M-sport (BSM)
2014 BMW x3 28i M-sport (BSM)
2004 330Ci ZHP SOLD and very much missed.
DIY Facelift Angel Eyes | AVIC-D3 Install | flickr
LeontiyZHP is offline   Reply With Quote
Old 10-29-2010, 11:33 AM   #93
adrianpl
My Ride: 01 330ci
Anyone know the torque specs?
adrianpl is offline   Reply With Quote
Old 10-29-2010, 10:44 PM   #94
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
idk the specs.
not sure how relevant it is to torque 'em to spec.
I know the fan nut is self torquing once you start the car.
delmarco is offline   Reply With Quote
Old 10-30-2010, 08:19 AM   #95
Itzed
My Ride: 2004 325xi
I don't know the spec, but I don't think it needs to be very tight. After I put it all back together, I just torqued it as tight as it would go before the belts and pulleys moved. Then I remembered I had forgotten the pulley dust caps and needed to take it off again. I had to hold the fan with a wrench again and it was not easy to get off, so that is definitely tight enough.
Itzed is offline   Reply With Quote
Old 12-02-2010, 01:34 PM   #96
SWFan
My Ride: 2011 335is
How did you get the AC belt back on. My car has sat undriveable for two days now because I can't get that bugger back on. The problem is the tensioner. It uses T50 Torx and every time I crank it down the driver pops out of the hole because its not very deep. The only way I'm able to even remotely get it done is to use two hands, then I have no free hand to mount the belt.
2011 BMW 335is
SWFan is offline   Reply With Quote
Old 12-02-2010, 02:17 PM   #97
Itzed
My Ride: 2004 325xi
I don't remember having any problem with it, just using my one hand on the tensioner. I used a standard ratchet and was able to hold the tensioner while maneuvering the belt. Make sure you put the belt on over the handle of the ratchet first.
Old 12-09-2010, 01:40 PM   #98
ericsonp325i
My Ride: 01 Black 325i
Great write up bro, about to go tackle this and the water pump and housing in my 323i, wasn't so lucky when my radiator sensor pegged out at hot on the dash bored while I was on the freeway doing 70....
MODS:Harmon Kardon System// HK Drive+Play// CCFL Angel Eyes// Motorola HF850 BT Kit// Black Headlight Corners// Clear Side Markers// M3 Style Side Mirrors W/ LED Turn Signal// 20% Tint// LED Rear Tailights// M3 Style Front Bumper
ericsonp325i is offline   Reply With Quote
Old 02-11-2011, 11:41 AM   #99
Ivanhoe
My Ride: BMW 330 xi 2005
Ivanhoe is offline   Reply With Quote
Old 02-11-2011, 12:21 PM   #100
msuka
My Ride: 2013 335i M sport
Pancho328i
this will help you out a lot.
msuka is offline   Reply With Quote
