Old 09-01-2009, 12:18 AM   #41
dpgrand
My Ride: 2005 330xi
if you put a lsd in the back of an xi, you do not need to put one in the front. The ratio's just need to match.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 09-01-2009, 03:40 AM   #42
Richy_Boy
My Ride: Alpina B3S
You might get unpredictable handling on the edge though.. i.e. in a seriously fast courner the inner front wheel might spin up whilst both rears bite down (due to the LSD), so you might get oversteer.
Rich
Alpina B3S - 3.4L, 305bhp, 267ftlb
K&N panel filter, SPAX Coilovers, M3 Sway Bar, RedStuff pads, Brembo Grooved/dimpled discs.
Richy_Boy is offline   Reply With Quote
Old 09-01-2009, 04:00 AM   #43
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
you will probably find that starting in 2nd gear works best for smoothness in everyday driving...at least that is my case with 3.46 and 330/TS
/_________\
O==[][]==O
Old 09-01-2009, 09:10 AM   #44
TiAg2247
My Ride: E39 M5 | E55 AMG
Yup! I rarely use 1st now unless I want to launch the car hard.
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is offline   Reply With Quote
Old 09-01-2009, 09:14 AM   #45
AdamBath
My Ride: E30
Nice.
AdamBath is offline   Reply With Quote
Old 09-01-2009, 12:18 PM   #46
dpgrand
My Ride: 2005 330xi
http://forums.bimmerforums.com/forum...d.php?t=931368
Old 09-01-2009, 12:36 PM   #47
AdamBath
My Ride: E30
Originally Posted by dpgrand View Post
And? 3.64 != 3.62, you won't be using the M3 diff.
Old 09-01-2009, 12:39 PM   #48
dpgrand
My Ride: 2005 330xi
Once again - i'm not concerned with the ratio - that is easy to fix and match. I'm just putting forth information suggesting that an LSD in an xi is doable and, in fact, worth it.
Old 09-01-2009, 01:46 PM   #49
AdamBath
My Ride: E30
Not using the M3 diff, its not. The only way its doable is using a custom built diffsonline diff, and its not like people don't already know that...
Old 09-01-2009, 03:47 PM   #50
Alex323Ci
My Ride: M3 & 323Ci (sold)
I'm not sure why that is for you, it's not like people with M3s can't use their 1st gear. When I drive my brother's E46 M3 I use 1st with no issues at all.
Old 09-01-2009, 03:54 PM   #51
AdamBath
My Ride: E30
But you also have another 1000 rpm's to play with, it makes plenty of sense to me. 1st gear would be pretty short on a 5 speed non-M.
Old 09-01-2009, 04:02 PM   #52
Alex323Ci
it's short but has nothing to do with smoothness on a non FI car.
Old 09-01-2009, 09:47 PM   #53
330i ZHP
330i ZHP's Avatar
at least in my case i have more torque and first seems like a waste...and i often go 2nd 4th to 6th...or 1st 3rd 6th...etc, etc
/_________\
O==[][]==O
Old 09-02-2009, 02:15 AM   #54
TiAg2247
1st ends VERY quickly when you rip on it. It's just so much easier and smoother to start off in 2nd sometimes. Meh.
Same here... I find it a bit more economical when I feel like granny driving.
Too many mods
Past:
'04 E55 AMG
Old 09-02-2009, 06:46 AM   #55
330i ZHP
330i ZHP's Avatar
exactly - I dont lug the engine and I am not slipping the clutch - so i cant see any damaging effect...in fact its the same way I drove my vette's if I was just commuting and not driving or trying to get somewhere
/_________\
O==[][]==O
Old 09-02-2009, 04:38 PM   #56
Alex323Ci
i don't see how that is not lugging the engine and prematurely wearing the clutch.
with your FI engine i can see the supercharger kicking in and maybe better to not get the rpm that high(atleast that's how my ASA is designed). but on a basic 330 i can't see how starting out in 2nd is good(even with a 3.62). that's the same as a 330hp M3 only using 2nd gear and that has much more torque/hp than a 330.
Old 09-28-2009, 05:39 PM   #57
cancell
My Ride: Is slow
Freaking awesome, do you use the m3 struts/springs/mounts or the ones you had on the vehicle? Does this require a diff size wheel or offset than what the non-m e46 run?
J/w
Live slow, die whenever.
cancell is offline   Reply With Quote
Old 10-11-2009, 03:11 PM   #58
TiAg2247
J/w
The only thing left from my stock 330Ci rear end are the PSS10s and RSMs. Everything else (hubs, calipers, trainling+control arms, axleshafts, diff, subframe mounts) is all M3 spec. Your offset will NOT change.
Too many mods
Past:
'04 E55 AMG
Old 10-16-2009, 02:53 PM   #59
tehsex
My Ride: 330i zsp...
tehsex is offline   Reply With Quote
Old 10-16-2009, 06:39 PM   #60
myksbmw
My Ride: BMW 2003 325i
How would this work with an automatic? Would that be a straight swap?
myksbmw is offline   Reply With Quote
