Australia
Old 04-01-2012, 10:21 PM   #181
dan_1337
My Ride: 330CiC
Originally Posted by Oz 330 View Post
All with fixed roof. Verts have never had the issue.
Not true. There are two verts in this thread that have had subframe issues.
I also posted this in another thread:
Originally Posted by dan_1337 View Post
I've found this info from http://www.bmwmregistry.com/model_faq.php?id=19:
How does the suspension of the E46 M3 differ from that of the regular E46 3 Series?
The E46 M3 utilizes the same basic MacPherson strut/multi-link suspension design as the standard E46 3 Series. However, it has been substantially modified by BMW M GmbH with the following changes:
-Wider track both front (by 3.4-in.) and rear (by 1.8-in.)
-Unique "bat wing"-shaped forged aluminum lower control arms with M3-specific bearings, bushings and cushions
-Thicker (3mm) aluminum thrust plate
-Special wheel bearings
-More robust subframe from E46 convertible
-Separate mounting of top spring and shock anchor points
-Modified rear suspension links with steel balljoints (instead of rubber bushings)
-Larger halfshafts and wheel carriers
-Unique spring and shock rates
-Larger anti-roll bars (26mm front, 21.5mm rear)
...which concerns me because the M3 also suffered quite badly from subframe issues, and if we share the same subframes then we probably also have the same issues.
dan_1337 is offline   Reply With Quote
Old 04-01-2012, 10:25 PM   #182
Nats
My Ride: BMW E46 M3
i have a 2001 M3 manual 100,000kms and my subframe mount has a crack now, only a small one.. im guessing being more than 10 years old theres no chance of getting BMW to fix it?
I have tried going through insurance.. didnt really expect it to work and they said they wont fix it as its wear damage.
Not looking forward to the bill after getting it fixed..
Nats is offline   Reply With Quote
Old 04-01-2012, 10:27 PM   #183
ating
My Ride: 2004 M3
^ you can try call BMW. See what they say? Or have u already made plans for a mechanic to repair it?
ating is offline   Reply With Quote
Old 04-01-2012, 10:30 PM   #184
Hazey82
My Ride: M3
I would still be pushing even if its after 10 years. If they dont then basically BMW are saying the car is onyl good for 10years before it starts to rip apart..
Hazey82 is offline   Reply With Quote
Old 04-01-2012, 10:33 PM   #185
Nats
My Ride: BMW E46 M3
mm true, but it seems like people with newer models have had problems getting bmw to fix it. Im gonna give bmw a try, who do i call? or do i take it to my local bmw dealer? i didnt buy the car from a BMW dealer..
Old 04-02-2012, 07:25 AM   #186
Aussiemark
My Ride: 2002 E46 M3
First step is to call BMW Australia. They will either assess it themselves or send you to a dealer to have it assessed.
Aussiemark is offline   Reply With Quote
Old 04-09-2012, 04:04 AM   #187
PRAVE39
My Ride: E39/VX COMMI SPACK
Hey guys being reading this thread very interesting.
It says that all E46 Bmw are effected. Is this the case for the 318i E46 sedan. 02-05?
Seems like the 6 cylinder E46 are having this problems? Any one out there had this problem on there 318i Oz version.
PRAVE39 is offline   Reply With Quote
Old 04-09-2012, 04:19 AM   #188
M3N7AL
My Ride: E46 M3
I have a 2004 M3 Vert, what are the symptoms to cracked subframe?
M3N7AL is offline   Reply With Quote
Old 04-09-2012, 04:26 AM   #189
02PRUV
My Ride: E46 M3 Turbo
Originally Posted by ating View Post
You are wrong. There are verts with subframe issues, they are just less common due to the extra chassis reinforcement that they have.
You sure it's that or is it that girls buy verts and they don't get driven hard
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
Old 04-09-2012, 04:33 AM   #190
MSportBMW
My Ride: E46 325, EVO8 MR
MSportBMW is offline   Reply With Quote
Old 04-09-2012, 06:36 AM   #191
LSM3
My Ride: E46 ///M3
Haha, burn!!
___________________________________________
2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon
LSM3 is offline   Reply With Quote
Old 04-09-2012, 08:08 AM   #192
M3N7AL
My Ride: E46 M3
What's the symptoms of sf issues?
Old 04-09-2012, 08:14 AM   #193
Aussiemark
For me, it was a clunk when changing from reverse to first or vice versa.
Old 04-09-2012, 08:38 AM   #194
sonaldinho89
My Ride: e90 325i 6MT
+1, and a clunk when changing from first to second after a hard launch
sonaldinho89 is offline   Reply With Quote
Old 04-09-2012, 08:43 AM   #195
ating
My Ride: 2004 M3
^ sounds like the "M" clunk? clunk that occurs when you disengage the clutch.
Old 04-09-2012, 08:48 AM   #196
M3N7AL
My Ride: E46 M3
Hmm how loud is this clunk? There's heaps of clunks with the bloody m3's lol. Mine is SMG, so i get a bit of clunking out of it here and there.
Old 05-26-2012, 12:48 PM   #197
Aussiemark
Just an update, for those interested.
BMW Australia agreed to pay half the costs as a goodwill gesture. I supplied the plates. There were two cracks in the rear axel mount. One was the right front and the other was left rear. The left rear was over 10cm but wasn't visible until the rear axel was off and the rust-proofing stripped back.
I could have forced the issue with lawyers etc as one could argue that the car unsafe due to a manufacturing fault. It just wasn't worth the effort and time off the road. As it was, I was without the car for a month!
Now it drives beautifully, with no major clunks.
Old 05-26-2012, 08:31 PM   #198
M3N7AL
My Ride: E46 M3
I have clunks that come from the gearbox.. is that different to the "subframe clunks" ? I always get clunks from the SMG changing gears and stuff, is that normal?
Old 05-26-2012, 08:48 PM   #199
Aussiemark
My subframe clunk was on starting to move the car, especially reversing after going forward, or going forward after reversing. It was louder than the SMG clunk, which changes depending on the driving mode.
Old 05-26-2012, 08:58 PM   #200
Honro
My Ride: M3 E46
Thats good news mate, out of principle, I would have gone the whole nine yards complaining how they have fully funded the repair other cars! Either way, a result is a result and gratz and i bet your now enjoying your car!
Can we ask how much your half of the repairs were?
SOLD - 2002 M3
- MOD LIST -
- ESS VT550 SUPERCHARGER @ 307rwkw | KW V2 Coil Overs | 20' Vertini Hennisy Wheels - 20x 8.5F & 20x10R -
Watch My S/C Install Vid Here: http://www.youtube.com/watch?v=guCnA...ature=g-user-u
Honro is offline   Reply With Quote
litigation
