Australia
Old 05-26-2012, 09:05 PM   #201
M3N7AL
My Ride: E46 M3
Originally Posted by Aussiemark View Post
My subframe clunk was on starting to move the car, especially reversing after going forward, or going forward after reversing. It was louder than the SMG clunk, which changes depending on the driving mode.
Ahh k. Cause i get clunks coming from the gearbox upon changing from Reverse to 1st, vice versa.
It clearly comes from the front/middle of the car (gearbox).
Is there any other symptoms to know if your subframe is damaged? I have a 2004 SMG Convertible.
M3N7AL is offline   Reply With Quote
Old 05-26-2012, 09:38 PM   #202
CortinaD
My Ride: lots
The subframe has a crack in it when you get underneath and look at it.
CortinaD is offline   Reply With Quote
Old 05-27-2012, 06:57 AM   #203
Aussiemark
My Ride: 2002 E46 M3
Originally Posted by Honro View Post
Can we ask how much your half of the repairs were?
About two and a half grand. They quoted $4,800 for the total cost. I supplied the plates. I think that it took them more floor time than they quoted, but they absorbed that then sent me the bill for half. I also replaced the shock mounts with urethane and reinforced the front tower before the alignment.
By the way, I checked out your SC install on YouTube. It looks great. I know that it's off-thread, but how much was it and who can you insure it with? Maybe PM me.
Cheers
Aussiemark is offline   Reply With Quote
Old 05-27-2012, 04:50 PM   #204
Honro
My Ride: M3 E46
Cheers
4.8k? Sounds like they may have done the epoxy method? I dunno that just sounds too cheap to be a full replacement of the floor pan? When I had mine done, the bill from the body shop TO BMW was around the 12k mark. So that didnt include BMW's labour to strip the car!
The whole install of the S/C was 12k. That also included 6 new coils cause one of them started misfiring. The car, S/C and all mods are insured with Justcars. I dont have a bill handy but iirc, it about 1540 p/a. That's having the car insured for 54k.
SOLD - 2002 M3
- MOD LIST -
- ESS VT550 SUPERCHARGER @ 307rwkw | KW V2 Coil Overs | 20' Vertini Hennisy Wheels - 20x 8.5F & 20x10R -
Watch My S/C Install Vid Here: http://www.youtube.com/watch?v=guCnA...ature=g-user-u
Honro is offline   Reply With Quote
Old 10-30-2012, 07:04 PM   #205
[SeN]
My Ride: 2002 M3 Imola Red
Hi Guys,
If I wanted to do a subframe re-enforcement kit as part of preventative maint, will I still be up for 5k bill? or will it be around the 1k mark?
Cheers.
Bilstein PSS10 /// Vorshlag Camber Plates /// Turner Motorsports RSM /// Rogue Engineering Octane SSK w. ZHP gear knob /// Dice MediaBridge 1500
[SeN] is offline   Reply With Quote
Old 10-30-2012, 08:20 PM   #206
CortinaD
My Ride: lots
Originally Posted by [SeN] View Post
Hi Guys,
Cheers.
It's a full days work to get the subframe in & out plus a couple of hours messing around with the plates. It wont be 5k unless you get BMW to do it.
Old 10-30-2012, 08:23 PM   #207
ating
My Ride: 2004 M3
Yeah I've thought about doing it, but then my mechanic said for the cost of installing the kit, it's probably the same as repairing a small hairline crack in the sub-frame. So I just get mine regularly checked out. I still might consider it though. Where are you getting your reinforcement kit from [SeN]?
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 10-30-2012, 11:24 PM   #208
[SeN]
That's good to hear, no way I'll get a stealership to do the job if its for preventative maintenance.
+1 I get mine regularly checked as well.
Was thinking of ordering it from Turner Motorsports.
Old 10-31-2012, 05:22 PM   #209
Honro
My Ride: M3 E46
Just a reminder guys, that even though you can install the reinforcement plates like the ones from turner motor sports, it doesn't mean you have "fixed" the problem. Your car will still be prone to subframe cracking. All your doing is pro-longing it just that bit more. Your driving habits really dictate when its going to fail.
The only real way to "FIX" the problem is to do what Alan (02PRUV) has done. If you search some of his threads you will see.
SOLD - 2002 M3
- MOD LIST -
Old 10-31-2012, 06:01 PM   #210
DesiredM
My Ride: E46 M3
But realistically how weak are the actual subframes? A lot of talk about them cracking just scares everyone, just like the SMG gearbox failing. Realistically it's not that likely to happen to you unless you are unlucky, drive the crap out of our car frequently or track your car.
DesiredM is offline   Reply With Quote
Old 10-31-2012, 06:50 PM   #211
Honro
My Ride: M3 E46
Unfortunately mate, your statement is completely wrong. With the subframe it its not a matter of "if", its a matter of "when".
It WILL happen to you, all you can do is be pre-paired and keep an eye on it, catching it in its early stages (cracks) just makes it cheaper to repair. Also, driving you car hard, just means it will happen sooner.
SOLD - 2002 M3
- MOD LIST -
Old 10-31-2012, 07:01 PM   #212
ating
My Ride: 2004 M3
I think on this forum at least, there appears to be more SMG issues than sub-frame issues. They're still issues though. Yeah some people say it's just a matter of time, and that may be so, but it may be at like 200k kms. Like in the US they're always going on about them, but if you look at their cars, a lot of them have done 100-150k miles. That's a lot more kms than the ones we have here in Australia.
Old 10-31-2012, 07:28 PM   #213
Honro
My Ride: M3 E46
I found mine had failed at approx 72,000km. Had two cracks, one was 4inches, and the other 2inches long - by the size of the cracks id say it had happened alot earlier though :/
And the car was bone stock when I found them.
SOLD - 2002 M3
- MOD LIST -
Old 10-31-2012, 08:15 PM   #214
CortinaD
My Ride: lots
+1
My car failed at 41k, pics are floating around. Only visible in the car if you knew where to look and cleaned the surface.
IMO it is a much bigger problem than SMG issues, you just need to look at the lists and the fact there was a class action in the US.
EDIT: I think it also needs to be pointed out that the e46 hasn't been in production for 6 years. You may even find that you have bought would have already had the repair done if you are coming into ownership now so it should last to 100k or more. Back in early 07 when mine was done there was 3 M3's on hoists at adelaide motors getting repaired, even here, Adelaide motors had several jigs made to bolt to the E46 chassis so the car could be transported. The repairer I used said he was getting about 1 e46 M3 every couple of months for a couple of years.
Old 10-31-2012, 08:21 PM   #215
[SeN]
Damn, sorry to hear man.
Did you buy ur car brand new?
I think by adding bigger, wider and thus usually a heavier wheels and then doing hard launches and burn outs will surely add more stress to the subframe. After all its carry more weight. That's just my opinion and I could be wrong.
Old 10-31-2012, 09:23 PM   #216
DesiredM
My Ride: E46 M3
Did you guys pay for the repair yourself or did you get BMW Australia to cover it?
Old 10-31-2012, 09:39 PM   #217
CortinaD
My Ride: lots
BMW paid for mine
Old 10-31-2012, 09:43 PM   #218
ating
My Ride: 2004 M3
The ones I read affected earlier model M3s more. What year is your M3 CortinaD? I notice Honro is 2002.
And yer, don't think BMW will pay for it nowadays...
I read someone say that BMW might cover your car up to 10 years from date of manufacture. Not sure how true that is.
Old 10-31-2012, 09:47 PM   #219
CortinaD
My Ride: lots
March 2004
Old 11-01-2012, 06:28 AM   #220
02PRUV
My Ride: E46 M3 Turbo
That's not the case. This has happened to all 3 series BMW's from E30's, E36's, E46's. It affects every model from a 318i to an M3. Year of manufacture doesn't mean anything.
I have seen a granny driven 318i put on a hoist and the only thing holding the rear end in the car was the exhaust.
As soon as it starts cracking it continues to get worse quick.
Rides:
BMW E46 M3 Turbo 570rwhp @18psi (old setup)
BMW E46 M3 LSX 427ci 800hp N/A
Ultima GTR LSX 440ci 800hp N/A
VY SS Ute Turbo 1004.6rwhp @ 28psi E85
Ford Escort Mk2 2JZGTE 600rwhp @14 psi
04 Yamaha R1 154.3rwhp
ISUZU FZR550 tilt tray (GT35 Turbo)
02PRUV is offline   Reply With Quote
litigation
