Australia
Check out other E46Fanatics members rides in the Enthusist Directory! If you don't have your garage setup, sign up today HERE |
#41 |
I've had my M3 checked twice now. BEMW in Castle Hill had a look while replacing RTABs and were happy to report that so far no cracking. ( 74,000 kms ).
RTABs on the M3 don't last that long and when they are worn the rear suspension can move around pretty badly, mine did! This puts extra stress on all the rear parts and may assist in fatiguing the sub frame mount points. I'd suggest collecting as much info on the US class action. This document should be of particular interest. BMW USA have issued two repair methods. 1) they fill the frame channel with epoxy / sealant for cars prior to 04 with cracking less then 20mm. 2) they replace the whole floor section for cracks greater than 20mm or older than 04. I'd like to see BMW offer repair type (1) to all BMW owners as a preventative measure, probably save themselves a shot load of money in the long run. But at this point i think the plates are looking more and more like the best option... the mind boggles though because the e36 M3, had plates standard iirc?
#42 |
My Ride: '99 E46 328CI
#43 |
Let's get more pics up.
![]() Ride 1 Fully Optioned Euro Spec Imola Red E46 M3 2004 Ride 2 GU Nissan Patrol TI Fully Optioned & Lifted |
#44 |
#45 |
80+% are passanger side.
#46 |
FYI
This would be worth Pershing would love to see BMW have all e46's covered http://www.infrastructure.gov.au/roa...lls/index.aspx
#47 |
My Ride: 325Ci ClubSport
i was under the impression that most happened on the left,.. same side as the muffler..on non M obviously
#48 |
After speaking to BMWboy we have the ball rolling. He is assisting in getting information of his own vehicle which had been repaired by BMW Oz.
Should anyone else have a repaired vehicle please submit your information via pm, dont worry about discretion, nobody will know. It will only be documented for legal reasons against BMW Australia. |
#49 |
mine was repaired by BMW under goodwill for the previous owner. it is a 2001 M3 coupe.
i am currently going into my own class action about the passenger RTA mount as this is the other area of manufacturer defect. the estimate for these costs is $7,250. i am about to start a new thread whereby we just list our year,. model, defect and whether it was repaired by BMW or not..... |
#50 |
pm replied lordgrunter
This sure is getting interesting... |
#51 |
Hi,
I'm just about to buy an E46 325Ci and have been following the subframe issue with some interest. I joined here just to offer a suggestion on negotiating this with BMW for those with issues. If enough people make it known that we, the owners of E46's, are aware that the fault is a manufacturing defect. Should enough people complete this form: http://www.infrastructure.gov.au/roa...s/defects.aspx BMW may be forced into issuing a recall for all E46's. This would be quite costly and time consuming for them. Instead, they should just do the right thing and fix any cars reported to them. Make it known that you're part of one or several BMW owner communities and that you WILL publicise the fault, taking it to DOTR if needed. Has anyone yet got enough information to get an idea of the percentage of cars affected by this fault? I'm honestly a bit nervous about handing over my cash for one, especially if there is no recourse thru BMW for the repair. |
#52 |
+1 on left (that's the side it started on my car)
#53 |
keep it going guys, the more info the better.
#54 |
BMW are keeping this a massive secret
i was talking to a guy who worked quite high up at BMW Australia.. and he wasnt even aware of this so called "fault" ... it scared me to think how many 46's are out there with their subframe mounts fkt and the owners arnt even aware |
#55 | |
Which part of the company does he work in? Finance, or marketing, or corporate, sales, or technical? Do you really think the finance or the corporate marketing guy will know anything about the cars? If those owners are getting the cars serviced then they will be aware of a hole in their rear floor as the mechanic should check all suspension mounting points on every service. BobZ PS. If you used the F word as often in your conversation as you use it on this forum I would try to get the hell away from you as well without saying much
"Little knowledge is Very Dangerous"
#56 |
My Ride: 95 525TDS, 94 525iT
Hey Jack, what was the conclusion with yours? Saw it at work the other week
#57 | |
Dominich(?) said he would contact me when he had heard from them, said Wednesday by the latest, so if I don't hear by this afternoon I'll be calling to check in.
#58 |
My Ride: 1990 E30 318is
Today's Friday. Please update us as to where you are at.
#59 |
BrisM3 - Nice car^^^^ Specs?
I currently have some owners wanting to use my lawyer to help their similair situations, as said above the more the better. Please keep info updated guys as this is a benefit for all E46 owners both now and in the future. My lawyer is a sponsor of major car events and also a driver in Australia wide events. i.e Targa. In all honesty I cant see anyone better to handle this situation. Should you wish to have help feel free to pm me and I will forward you the details. |
#60 | |
Location: Sydney, Australia ( Best Country In The World !)
My Ride: 2002 e46 M3 SMG Coup
I just Spoke with my Service advisor at BMW Sydney and he said the defect was only for a certain chassis range and a very small amount of Australian cars were affected. He also said it was mainly USA cars that were affected and that they are a diffecnt chassis ype to the bulk of Austarlian cars. He also said not to worry because if it does happen BMW will sort it out.
| Tags |
| its subframe mount n00b, litigation |
