Australia
Old 11-02-2010, 11:41 PM   #121
Scotty_89
My Ride: 2007 335i Coupe
Ok, so I just had a quick peek and could not see any cracks.
Is it the front left or rear left mount out of the 4 that is most prone to tearing? The right hand side is easier to inspect, but the front left one has some other components that cover over the mounting point and it's hard to see, and the rear left is tucked in behind the exhaust.
Scotty_89 is offline   Reply With Quote
Old 11-03-2010, 12:16 AM   #122
CortinaD
My Ride: lots
RHS for ours. You really need to get in there with some degreaser and a dentists mirror & a torch, just poking your snout under for a casual look will only show you if its really bad.
Thats what they cut out of my car. Front Right is what failed, it was hardly visible with the subframe in.
CortinaD is offline   Reply With Quote
Old 11-03-2010, 12:21 AM   #123
Nae323
My Ride: '99 323Ci 5sp
Definitely getting this checked next time I see the mechanic.
If this has already been replaced/repaired will it be easy to see/tell?
Nae323 is offline   Reply With Quote
Old 11-03-2010, 01:19 AM   #124
mtria
My Ride: 03 E46 M3
Originally Posted by CortinaD View Post
They pulled the age card with my transmission on the 330i when that failed as the car was 5 years old with 68k or so. They didn't cover that repair but they did cover the M3 subframe without any fuss at all and my M3 was 4 years old at the time with 40k on the clock. Print off all this stuff from the web and show them like others have done - it can't hurt. I would agree with them about not repairing it on a old car if it was a once off failure, but this is a documented issue with these cars no matter what the age.
Hi CortinaD, What did you do excactly or say to cover the subframe repair? I assume you were out of warranty when you took the car in?
mtria is offline   Reply With Quote
Old 11-03-2010, 02:28 AM   #125
CortinaD
My Ride: lots
I had a couple of personal friends at the dealer at the time (they have since moved on) who helped me out so I am not a good example as their efforts definitely made the process easy & stress free process. Having said that - I was like the 2nd or 3rd car to be covered here and from what they say a year or so ago, 4 or so cars were repaired after mine before BMW started tightening the purse strings. But the process for me started with a phone call to my mate to tell him the bad news and he said bring the car in as is (i.e. lowered etc), they took a photo, sent it to BMW and heard back in a few hours that it was covered. I was told to drop car off in a week and I had it back 3 weeks after that.
The car was out of warranty by 1.5 years when i took it in as they only started doing the 3 year warranty in Jan 06 from memory. Either way it was out of warranty and was covered as good will.
EDIT: All I paid for was a wheel alignment afterwards at another joint arount the corner as BMWs alignment machine doesn't fit on the car with the superlows in.
Old 11-03-2010, 06:08 PM   #126
mtria
My Ride: 03 E46 M3
Thanks for the quick respose and advice, I'll keep posting info as it come through.
Old 11-03-2010, 07:05 PM   #127
Rajvosa
My Ride: M3
Cortina..yours cracked at the front? mine failed at the right rear and Dragan (ex owner) had it repaired and reinforced before we finalised the deal. nice of him!
where at the front do they fail? i wanna have a look when i get the chance..
Rajvosa is offline   Reply With Quote
Old 11-03-2010, 07:30 PM   #128
CortinaD
My Ride: lots
Hey mate if you have a look at the 2nd photo it is the rhs front, the bushing covered most of it but there was the crack only visible by like 10mm on the right hand side of the bolt hole. You can see it go up and around the spot weld and then up again.
Old 11-03-2010, 10:30 PM   #129
Rajvosa
My Ride: M3
can i see it if i get under the car or too many things in the way.
also if the rear was cracked slightly, is it a good chance that the front will also be?
Old 11-03-2010, 10:36 PM   #130
CortinaD
My Ride: lots
No idea but no doubt Dragan would have fixed it properly.
Old 11-03-2010, 11:10 PM   #131
Rajvosa
My Ride: M3
He fixed the rear and put reinforcement plates in.
nothing was touched at the front tho..
Old 06-15-2011, 05:23 PM   #132
Brissyjohn
My Ride: 2007 MX-5
Raising the dead here I guess. A question was asked earlier (about post #98) as to whether this cracking also affected E46 Compacts. Has anyone heard or experienced subframe mount cracking in the 316ti, 318ti or 325ti?
Brissyjohn is offline   Reply With Quote
Old 06-15-2011, 05:54 PM   #133
BMW //MPOWER
My Ride: The bus...
The 16 and 18's wouldn't have near enough power to cause the cracks, so if your concerned about one of them you shouldn't be.
I think the 25 would be just as succeptible as the coupes, however the primary cause of the cracks is usually the way the car has been driven.
BMW 325Ci MY2004 Individual //M Clubsport Edition, //M Clubsport package, //M Sport 18"s, Manual //M Short Shift, Carbon Black, Black Aluminium Cube Interior.
BMW //MPOWER is offline   Reply With Quote
Old 06-15-2011, 08:51 PM   #134
M3BAS
My Ride: E46 M3
I notice a slight clunk from right rear when turning in carparks etc- is this a symptom of subframe?
2005 PY M3
M3BAS is offline   Reply With Quote
Old 06-15-2011, 09:09 PM   #135
ating
My Ride: 2004 M3
are you sure it's not a noisy diff?
ating is offline   Reply With Quote
Old 06-15-2011, 09:19 PM   #136
BMW //MPOWER
My Ride: The bus...
when did u last change your rtabs?
Old 06-16-2011, 05:35 AM   #137
Brissyjohn
My Ride: 2007 MX-5
Thanks for that - gives me food for thought. I'll have to be sure to get a good PPI when/if I find the car for me.
Old 06-16-2011, 07:43 PM   #138
M3BAS
My Ride: E46 M3
RTAB's have been changed, i'll get workshop to inspect when it goes for service in couple weeks.
2005 PY M3
Old 03-28-2012, 06:39 AM   #139
Aussiemark
My Ride: 2002 E46 M3
Hi,
I realise that this is an old thread but would be greatful for any assistance that anyone can provide. I have a 2002 E46 M3 that has done 90,000km. It has never been tracked, launched or crashed. It has developed a crack in the right rear trailing arm mount. BMW Australia haven't decided yet if they will help with the cost of repair.
Could anyone with experience or advice please PM me?
Thanks and regards,
Mark
Aussiemark is offline   Reply With Quote
Old 03-28-2012, 06:46 AM   #140
LSM3
My Ride: E46 ///M3
If you get the car inspected at a dealer, make sure it is as original as possible.
When mine was inspected they went right through it, had it on a hoist, checked the service history, compared what it came out of the factory with and what it had at the time of inspection (ie wheels) - even the thickness of the paint.
You want to make sure you have the best chance of getting a positive response. So if you have different wheels or suspension components - put it back to stock!
___________________________________________
2006 CS M3 | ESS Tune : CSL SMG tune : Eisenmann Race : Eibach : Tekarbon
LSM3 is offline   Reply With Quote
litigation
