Old 08-23-2009, 09:10 PM   #1
Chr325is
Chr325is's Avatar
My Ride: 325i
DIY: Swaybar Endlinks
After a few months of having a horrible clunking noise in my front end (which I thought was my worn out shocks) I did some searching and decided to replace my swaybar endlinks. It was a relatively easy process, but having the right tools makes all the difference.
Here are the tools you will need:
18mm open ended wrench
18mm socket with extension
16mm open ended thin wrench (this is key)
Here are the part numbers of what I replaced.
31356780847 - Endlinks (2)
33306760587 - Hex Nut (4)
I started off by removing the top nut on the link, with a 18mm wrench holding the nut in the rear and an 18mm socket to remove it. The rear link nut has only one spot for a wrench to fit, the rest of it is rounded so make sure you have the wrench fully on the nut.
Once you have the top removed, do the same for the bottom, except you're removing it from the swaybar and not the strut housing.
Here is what my old sway links looked like compared to my new ones, you can see the difference. The old links would move freely while the new ones felt much firmer. This was definitely causing my clunking noise.
I was able to remove the old ones without having to use a thin wrench. Unfortunately I was unable to tighten the new sway links on with a normal sized open ended wrench. Luckily for me I had a thin 16mm open ended wrench laying around. The new sway links have a different rear nut that is 16mm, and not 18mm like the original ones were.
Installation is basically the same as removal. Tighten the nuts to 44 ft. lbs (59Nm).
Although it is not entirely necessary, I recommend using all new nuts for this install. My hardware was fine, but I always like to replace them when I can.
-Chris
2004 325i 5MT ZSP
Mods
KW V1, H&R F/R Swaybars, Rogue Engineering RSMs, Meyle HD FCABs,
M3 RTAB with Rogue Engineering Shims, UUC Motorwerks Evo3 SSK, ECIS Intake,
Vorsteiner CF Console, 20% Tint, VMR 18x8.5F 18x9.5R CSL Reps
MTech 2 Front Bumper, M3 Steering Wheel.
Chr325is is offline   Reply With Quote
Old 08-28-2009, 03:49 PM   #2
Boston325Ci
My Ride: is a gas HOG...
Nice write-up!
Boston325Ci is offline   Reply With Quote
Old 08-28-2009, 05:18 PM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Did this the other night. All 4 of my boots were busted. I ordered the Febi links. Quality was good, my only issue was that the replacement hardware was 11/16th. Grrr.
Old 08-30-2009, 02:28 PM   #4
BrianLeveille
My Ride: 325xi
Guys,
I have my front end in the air because I need to re-tighten my end links nuts after a DIY. Problem is, it looks like I can't get a wrench onto the shaft to counter-hold because the shaft is completely round. How is a wrench supposed to counterhold on something round???
When I tighten the nut, the shaft just spins.
Help!
-BL
p.s. I'm pretty sure I have the OEM Lemforder end links on my 2002 325xi.
p.p.s. The nuts do have a torx end , but I can't use them to counter-hold when my rachet is on the tightening nut! I tried using the torx to do the tightening while using a open-wrench, but that wasn't getting too far as I couldnt' apply much force to the torx without the bit slipping out, so I don't want to strip it too much.
Thoughts?!?
BrianLeveille is offline   Reply With Quote
Old 09-10-2009, 01:02 PM   #5
Egon
My Ride: 323SE
Just done my front two as they were knackered. In my struggle to find an odd sized slim width spanner, i found an old bicycle spanner (you know the sort, loads of hex holes and c spanner in a mildly useless metal...) and filed one of the end holes out a bit, voila! cheapy spanner!!
Might help someone...
Egon is offline   Reply With Quote
Old 10-07-2010, 01:55 PM   #6
zwei e46
My Ride: '99 323i & '05 325xi
Thanks for this great DIY.
Just did this on my '99 323i w/130k. Even though I have ramps, I chose the jackstand route with wheels off. IMO it gave easier access to the area.
The ones I removed were beat, my guess original. I could move each end with my pinky finger!
I replaced mine with FEBI. I agree with the other posters ... get thin set wrenches. It's a must. One other thing I'd like to add if your using FEBI links, make sure you have a 17mm DEEP SOCKET before you start this.
I noticed the results as soon as I left the driveway. Tighter steering and no more wandering on the highway!!
Thanks to all who contributed to this thread. It made a HUGE difference for only $32.00
zwei e46 is offline   Reply With Quote
Old 10-09-2010, 09:59 PM   #7
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
Originally Posted by BrianLeveille View Post
Guys,
Help!
-BL
Thoughts?!?
You need to use the torx to hold it and then an open end 16mm wrench to tighten, I used a short 16mm to do this. its a pain but worked well!
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 11-14-2010, 03:43 PM   #8
Chr325is
Chr325is's Avatar
My Ride: 325i
**UPDATE**
After a bit more than a year, I seem to have gone through another set of swaybar endlinks. I ended up upgrading to Meyle HD ones from AutohausAZ.
There are a few differences in the Meyle HD ones that I felt worth mentioning, as well as a correction to the original post. The size for the thin wrench to take off the swaybars is 18mm, not 16mm like I stated above. Also, make sure you have a deep 15mm socket as that is the size for the Meyle endlinks.
The Meyle HD endlinks do not require a thin wrench, but you will need one for when you take your original endlinks off. I misplaced my wrench, but was able to get an 18mm one from thinwrench.com (http://www.thinwrench.info/7-single-ended-thin-wrenches). Additionally, the Meyle HD endlinks have their own hardware so purchasing nuts for them is not necessary.
-Chris
2004 325i 5MT ZSP
Mods
Old 12-07-2010, 11:39 PM   #9
tmoritz
My Ride: 325xi '04 & 323i '99
Guys,
Help!
-BL
Thoughts?!?
Brian - I know this is much too late for you. But the answer is to use a Thru-ratchet (like the Kobald set from Lowe's). With Thru-ratchets, the handle fits around the outside of the bit. The bit has a large enough hole in the middle to allow you to stick your T-30 torx bit in there while turning the wrench. You may need a 16mm (to get the old links off) and a 17mm to get the new ones on. Depends on manufacturer, of course. Some have reported needing an 18mm, but not me. No flat open wrench needed.
tmoritz is offline   Reply With Quote
Old 12-30-2010, 10:47 PM   #10
Whammy
My Ride: ZHP
Chr325is,
Do you instructions on how to do the rears endlinks? I need to replace mine and am not sure of the proper way to do so. Any information would be appreciated! Thanks!
Whammy is offline   Reply With Quote
Old 01-03-2011, 07:57 AM   #11
Whammy
My Ride: ZHP
bump for some help...
Old 01-04-2011, 04:39 AM   #12
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
Would anyone happen to have pictures on this DIY?
Thanks.
BMW /// 323i /// Sedan
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// DEPO corners /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 01-04-2011, 04:23 PM   #13
Chr325is
Chr325is's Avatar
My Ride: 325i
dp
-Chris
2004 325i 5MT ZSP
Mods
Old 01-04-2011, 04:23 PM   #14
Chr325is
Chr325is's Avatar
My Ride: 325i
Sorry, I haven't done the rears. Now that you mention it, it might be worth considering.
I have the pictures, but don't have anywhere to host them anymore. I can e-mail you the picture if you'd like.
-Chris
2004 325i 5MT ZSP
Mods
Old 04-29-2012, 11:17 AM   #15
akhbhaat
Lying, drunken cheat
My Ride: German Civic
Found this thread and thought I'd revive/update it:
I wasted the better part of a day yesterday trying to change the front sway bar end links with the car up on ramps.
It simply cannot be done (at least on my 2005 330i w/ZHP) for two reasons:
1.) There's not enough room to reach the upper bolt with both arms. This is necessary because you need to grip the inside washer/locking nut with a wrench whilst turning the outside bolt because they'll just rotate in place together otherwise.
2.) In order to install the Meyle HD links (which I bought to replace the dead OEM links), you need to use a deep socket (although unlike the normal links, there's no locking nut to counter). There's not enough clearance between the tire and the upper bolt where it attaches to the strut to fit a torque wrench or ratchet with the deep socket.
The fact that I was even able to reach and turn the bolts at all while jammed underneath the car with little room to work on either side makes it very apparent to me that this job would be downright easy with the wheels off the car. I attempted to resort to ramps this time around because my jack is in storage 500 miles way, but it looks like I'll have to bite the bullet and buy a new jack.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
akhbhaat is offline   Reply With Quote
Old 04-30-2012, 03:41 PM   #16
alpine003
My Ride: BMW
Not necessarily. If one side is higher than the other, the swaybar link will bind and that is the secret to getting that nut off/on without having it spin freely.
Are you able to use only one side of the ramp and loosen that link, then jack up the other side with your factory jack to remove the link and then lower it again to get the new on on there?
alpine003 is offline   Reply With Quote
Old 04-30-2012, 04:13 PM   #17
akhbhaat
That MIGHT address #1, but it won't address #2.
Even that aside, there's no way I'd go under the car if it were partially supported by the OEM jack (even if the side I'd be under has the ramp). I'll use it for redundancy when the car is already on ramps or jack stands, but that's the extent of it. I need a decent jack anyhow--$100 is a small price to pay for the added convenience now and in the future.
Old 07-05-2013, 09:32 AM   #18
Oz Striker
My Ride: '00 330Ci, '07 350Z
Just thought I'd post my experience of installing my H&R front sway bar
For the front bar I only jacked up the right wheel, and managed to swap out the bar with the left wheel still on the ground. After completing the install there was a little knocking coming from the front left especially as I went over bumps in the road. I think with one side of the suspension/bar loaded and one side unloaded this probably caused and uneven and excess load/pressure being place on the left end link and caused it to fail. I replaced it with a new Lemforder end link and all has been good.
I had no knocks prior to the install, and when the old bar was off I checked the lower joints of the end links and they both felt pretty good, although left didnt feel quite as tight as the right one.
And as for the improvement in handling..... Wow, so much flatter through curves and front end more willing to turn in (although i do already have H&R cup kit springs/shock combo installed). Would recommend this to every fellow fanatic over springs & shocks if you are looking for improvement in handling rather than just a visual drop.
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 08-05-2016, 04:22 PM   #19
OnTheFence
My Ride: 2001 330i (and 530i)
My Lemforders replacements do not have a hex hole, and the flats are 18mm. Not 16mm.
OnTheFence is online now   Reply With Quote
Old 01-09-2017, 12:45 PM   #20
vilord
My Ride: '02 325Cic, '07 e91
I was going to do this DIY last night, but didn't see this comment...
One of my links was completely broken and disconnected, so I took that one off so it stops bouncing around bending things.
Returned the 16mm thin wrench to the local bike shop and ordered an 18mm thin wrench. Next weekend, I guess
I wonder if it is better to have one good link and one disconnected, or better to have zero? hmm.
vilord is offline   Reply With Quote
