Sponsored by The Tire Rack
Old 08-24-2009, 10:07 PM   #1
Zelaya
My Ride: 02 325i
Tire question
Hi guys, I currently running Hamann PG2's with 18x8.5 all around with 225/40/18 and now that I need to replace my rear tires I was thinking on getting 245's. Is this possible considering that I don't have staggered setup. After I installed my PSS9 I'd like the tire to be as close to the rear fender line(wider). I've seeing people putting spacers but I haven't seeing any good or bad reviews. I called Tirerack this after noon and the guy told me that I should leave it 225 all around Can someone assist me with this as I need to order them tomorrow. Also do I need a camber kit install to avoid inside tire wearing out.
Thanks in advance
Zelaya is offline   Reply With Quote
Old 08-24-2009, 10:23 PM   #2
Chris-TK
My Ride: Mk VI GTI
You can stuff a 245/35/18 on those wheels. The issue isn't really the tire sizes, but your offsets. With a wider tire you run the risk of rubbing more if you have offsets that are more aggressive. Do you happen to know your offsets?
K.
Chris-TK is offline   Reply With Quote
Old 08-24-2009, 10:29 PM   #3
Zelaya
My Ride: 02 325i
No I don't know the offset. I only know that they are PG2's with 18x8.5 all around. I tried this afternoon on checking on the actual wheel and no info. How can I find the offset.
Old 08-24-2009, 10:34 PM   #4
Chris-TK
My Ride: Mk VI GTI
Remove the wheel itself and look inside the barrel. Sometimes it's a sticker on the inside of the barrel and other times it will be stamped in the inside of the spokes and should read something like this "ET ##".
K.
Old 08-24-2009, 10:40 PM   #5
Zelaya
My Ride: 02 325i
I'll try this tomorrow to confirm. If I can remember from the previous owner who I bought them from I think but I'm not too sure that they are ET38
Old 08-24-2009, 11:52 PM   #6
Chris-TK
My Ride: Mk VI GTI
ET 38mm sounds about right, just double check though.
K.
Old 08-25-2009, 11:18 AM   #7
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
If they end up being ET38, then 245/35R18 should fit just fine.
Tires
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 12-02-2009, 07:25 AM   #8
Echelon73
My Ride: 2001 33Ci and 2001 3
Would the 245/35/18 work on all four corners (square set up)? I have 18X8.5 ET35 on all four corners of my 330Ci and I was thinking about trying it.
Echelon73 is offline   Reply With Quote
Old 12-02-2009, 06:11 PM   #9
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
245 on ET35 will be very flush with the front fender and may cause some rubbing issues during compression or cornering.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 12-02-2009, 06:22 PM   #10
mrkedmnd
My Ride: "03 325i- 19" ST160
will 235/35/18 fit on my 2003 325I. I'm looking to purchase some 18" rims that come off of a 745 but change the tires.
mrkedmnd is offline   Reply With Quote
Old 12-02-2009, 07:29 PM   #11
VMRWheels
VMRWheels's Avatar
It depends on the the width and offset of the wheels. If it came from a 745, most likely the widths and offsets will not work on a E46.
-Charles@VMRWheels
Old 12-02-2009, 10:05 PM   #12
jack s
My Ride: 2005 325i
I have 235/40R18 on the front of my 325i, running on 8.5" rims with 40 offset, no problems. I'm not lowered, though.
jack s is offline   Reply With Quote
Old 02-17-2010, 08:47 AM   #13
mrkedmnd
