Old 08-26-2009, 06:16 PM   #1
infinkc
My Ride: m3 e46
p46 lights, can you remove the angel eyes that come with them?
im looking for a set of p46's for my e46 m3. I found that DDM has them the cheapest with an HID kit. I dont like the angel eye kits they offer, so if i get the lights with the stock option can i pull them out and change to a different brand?
I was looking on the umnitza site, they have the angel eyes i like but the xenon kits are more expensive.
thanks!
infinkc is offline   Reply With Quote
Old 08-26-2009, 07:04 PM   #2
Mike@F1 Autohaüs
Past Site Sponsor
My Ride: E46 330ci
You can swap them out no prob
http://forum.e46fanatics.com/showthr...298&highlight=
Mike@F1 Autohaüs is offline   Reply With Quote
Old 08-26-2009, 10:43 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Easily done, you can remove the plastic cover and install a CCFL or LED ring in place. We do this for you when you choose the angel eye upgrade.
Old 08-27-2009, 04:07 PM   #4
umnitza
877•486•6489
umnitza's Avatar
My Ride: E39M5, Sequoia
thanks!
We offer a kit that doesn't have errors, even given this, we can offer you very competitive pricing.
Just give us a call and we'll work something favorable out to you.
Old 08-27-2009, 04:19 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
When doing this, does it still use the old ballasts? I believe that's part of what's wrong with my originals. What all is included in the kit?
Old 08-27-2009, 06:34 PM   #6
umnitza
877•486•6489
umnitza's Avatar
HID setup with Xenons and angel eyes.
Angel eyes are Orion v2 exclusively.
HID is an error canceling system.
Old 08-27-2009, 06:41 PM   #7
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
bingo. I had P46s (purchased from jlevi) that I got back in 2004. I purchased the new Orion V2 LED kit and had a local fanatic pull open the P46s, take out the old halos and put the new led based halos in their place. Looks perfect
Timeless Motor Group
Old 08-28-2009, 06:13 PM   #8
aggieE46
Keep it clean
aggieE46's Avatar
Let me ask a different way. I have P46s with the pre-installed rings. When I upgrade to the Orion V2, what all is replaced? Just the rings, or do I get new ballasts? I believe both mine are screwed up (as 3/4 of mine work).
Old 08-28-2009, 06:37 PM   #9
umnitza
877•486•6489
umnitza's Avatar
You don't need new ballasts.
From another thread you also need a light bulb. That can be included in your upgrade. The Orion V2 would replace the rings and ballasts, give you this look:
Old 08-28-2009, 07:09 PM   #10
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
The P46's have built in plastic bezels with bare rings inside. You will open those plastic bezels and remove the rings to be replaced. If you are going from CCFL to LED, you will remove the ballasts and direct connect the rings to the harness.
Old 08-31-2009, 10:55 PM   #11
infinkc
My Ride: m3 e46
Is there any writeup with pics for installing the orion v2 into older p46? Can you pull the prions apart, or is it better to keep them whole and glue them where the old ring was
Old 09-01-2009, 01:17 AM   #12
umnitza
877•486•6489
umnitza's Avatar
if the glue you can use is unobtrusive and strong, we recommend keeping them intact. Otherwise, you should take them apart.
Old 09-01-2009, 12:16 PM   #13
infinkc
My Ride: m3 e46
how hard is it to take the orion v2's apart to just use the ring?
Old 09-01-2009, 01:32 PM   #14
umnitza
877•486•6489
umnitza's Avatar
It's no picnic even for our guys. We did it this way to prevent tampering.
