Old 08-27-2009, 08:57 PM   #1
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Question about P46 Bulb
Hey Guys,
First time I've had an issue with this, so sorry if this is stupid. I bought my P46s roughly 3 years ago from JLevi. Aside from 3/4 of the angel eyes not working, I've never had any problems. Well, 2 days ago my passenger's side xenon went out. I got a bulb-out warning. Turned it off, turned it back on. It'll work for about 2 minutes and go off. I switched it over to the driver's side and it does the same thing, so I'm guessing it's the bulb.
Well, here's my problem. I would have assumed I needed the D2S bulbs, but it seems that my bulb and wiring to the ballast are all one piece. There's no way to remove the bulb from the wiring? Am I stupid? Neither JLevi or Umnitza sell this "setup" on their site. I have seen a harness available on EAS's site to adapt a D2S bulb to a "generic" ballast.
Did I just get screwed on this and now I have to buy bulbs and new wiring, or do I need to myself?
Thanks.
Old 08-27-2009, 10:47 PM   #2
KHOALTY, Inc.
My Ride: BMW
Send a message via AIM to KHOALTY, Inc.
P46 headlights accept the h7 bulb. Temporary you can stick in a halogen h7 in there to solve your issue until you find a replacement.
KHOALTY, Inc. is offline   Reply With Quote
Old 08-28-2009, 06:05 AM   #3
aggieE46
Keep it clean
aggieE46's Avatar
This is not an H7 bulb. there is no way to install an H7 into them.
I'll post a picture when I can.
Old 08-28-2009, 08:05 AM   #4
aggieE46
Keep it clean
aggieE46's Avatar
Here's the "bulb". One solid molded piece. Options?
Old 08-28-2009, 08:09 AM   #5
mhagley323
My Ride: 330i
Brand New 6000k H7 bulbs. P46 replacement.
http://forum.e46fanatics.com/showthr...768&highlight=
03' 330i
Mods
|M Tech II|P46| Orion V2|Painted Rear Diffuser and Moldings|Clears|Painted Grills|Koni FSD|Eibach|M6|WeissLicht LED|
09' ///M5
Mods
|BMW Performance Gloss Grills, Gills and Reflectors|SuperSprint|RPI|WeissLicht LED|
mhagley323 is offline   Reply With Quote
Old 08-28-2009, 08:21 AM   #6
aggieE46
Keep it clean
aggieE46's Avatar
Saw your thread last night, my car doesn't take H7s.
Old 08-28-2009, 10:07 AM   #7
aggieE46
Keep it clean
aggieE46's Avatar
Okay, I just ordered some D2S adapter harnesses. Hopefully along with some bulbs, I'll get going.
Old 08-28-2009, 10:43 AM   #8
aggieE46
Keep it clean
aggieE46's Avatar
Okay, I'm seeing that I'm a severe lighting noob. I'm guessing this is an H7 HID? I just cancelled my order for the harnesses. Hopefully I can just find these.
Old 08-28-2009, 11:34 AM   #9
KHOALTY, Inc.
My Ride: BMW
That is an h7 hid bulb, a d2s does not have wires to it.
Go to www.khoalty.com/Hids.html and you will see what they look like.
One trick to see what bulb you have, look around the bulb and it will say the bulb type on there as well.
Only oem headlights have d2s from the start as depo comes with halogen from the start.
Old 08-28-2009, 11:44 AM   #10
aggieE46
Keep it clean
aggieE46's Avatar
Yeah, thanks. My bulb has no marings, whatsoever, except for the 6k sticker.
So, if I end up with the adapters, will I be able to plug in a D2S? Any advantage?
Old 08-28-2009, 12:06 PM   #11
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The P46's use an H7 HID bulb. We don't have them on our site but we offer them if you need a replacement pair. Just give us a call and we can set you up.
Old 08-28-2009, 12:58 PM   #12
KHOALTY, Inc.
My Ride: BMW
You can't put a d2s bulb in your housing bc it won't fit. It's like putting a h1 bulb in a 9006 housing, won't work.
Pair of replacements are just 30 plus shipping so it isn't bad.
