Old 08-27-2009, 11:35 PM   #1
JJR4884
My Ride: BMW
3.38 Diff Installed, 4 hours my ass.... 1 hour install
Hi all.... just put a 3.38 in tonight and I gotta say, we did a lot of work and it wasn't difficult at all. So for anyone who can put their car on a lift, go for it, this was as easy as putting an exhaust on.......
K for starters, I used this DIY
http://forum.e46fanatics.com/showthread.php?t=145570
Perfect 10/10...... no roadblocks, no surprises (surprisingly lol), very straight forward, and thats that
In a nutshell... did a couple things different...
1. I have a TSE3, so rather than letting the exhaust hang, I simply removed the last two sections... made it very easy
2. Car was on a lift, left in neutral
3. Remove the clips on the sway bar, however didn't take it out, we just pivoted it down all the way, it gave more than enough room for the diff to clear when we took it out
4. Removed the rear suspension reinforcment bar..... took 1 minute, 6 bolts
5. Removed the 6 bolts per axle, took about a minute per side with the air gun... you can rotate the tires pretty easily rather than trying to maneuver around the axle
6. Removed the 6 bolts for the driveshaft.... took a few minutes since its a little less space to work in and a little harder to rotate
7. 2 bolts in the front and 1 bolt in the back holding the diff up, removed those in within a few minutes, then had to pry the diff off the driveshaft while we lowered it out of the car...
Diff off the car
Banged out the flanges, took a minute per side if that.... swapped them. Yes the 3.38 has a different flange....
-The 3.38 flange had 6 holes equally dispersed... so a normal 6 star pattern (think of a rim...)
-The 2.93 flange (on my 6spd 330ci) had 6 holes, but it was designed more like a split 3 rim... so, 2 were next to eachother, another 2 were next to eachother, and another 2....
No big deal, bang em out with a hammer, and bang the others back in
In the meantime with the diff off the car, we removed the back of the diff, cleaned all the sh*t out of the inside, sealed it, bolted it, and filled it up with oil. I used the 75w90 Royal Purple, one bottle will do the trick
Reversed everything and thats it...... install was very straight forward. Took about 15 minutes total to put the diff on the car, bolt everything back up, and take the car off the lift.
For all of you "thinking" about doing this, don't hesitate... there really isn't any hard part if you have the right tools... however I'm fortunate that a buddy of mine is a mechanic with a lift, so I give you credit to tackling this on jack stands
First Impressions
Right of the bat, the car felt lighter putting it in reverse and backing out of the garage....
When I am WOT at low RPMs, I feel like i'm in the gear lower...... so gunning it at 30mph in 4th gear feels like what 3rd gear gave me.
I didn't really notice too big a difference with the RPMs.. still drove at 35mph in 4th gear, however the car is comfortable in 5th gear at that speed as well. Of course the big difference is when I am going faster, so we'll see how I like going 70-80mph in 6th...
1st gear is very noticable, however definitely not neck snapping
I haven't done a highway run yet so no info on that
The most impressive is the 1st to 2nd pull when you really get on it.... 2nd gear is REALLY strong, so it feels good shifting and still having those g's pulling hard
I'll do a good sprint tomorrow on the highway
Oh and please check out www.car-part.com
This mod costs me a hundred bucks Found a local place that had the diff, had 70k miles on it, and wanted $100... When we opened up the diff, the gears still looked brand new. Coming out of an automatic, it would be pretty difficult to fvck up a differential so 70k for that is still nothing.
J
JJR4884 is offline   Reply With Quote
Old 08-27-2009, 11:42 PM   #2
secono330ci
My Ride: 04' 330ci/15' A3 TDI
I saw that you got this a few days ago I thought you were joking lol it seems too good to be true. Did you just give the place a call and picked it up?
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 08-28-2009, 12:34 AM   #3
JJR4884
My Ride: BMW
Pretty much lol... however I called last Friday, they said they had a 3.38 in.
Went there Monday to pick it up, however it was still on the car. They took it off in an hour, which gave me time to go to the ATM and grab a coffee...
So took it home Monday, brought it by my buddies shop today so he could get an idea of what needed to be done, and said "lets just do it, it will take no time"
Old 08-28-2009, 08:55 AM   #4
JJR4884
My Ride: BMW
Never again will I post in this forum friggin crickets
Anyways, took it on the highway today on my way to work, all I gotta say is WOW. 3rd and 4th are great, while 5th and 6th surprisingly pull relatively hard. The car is definitely more ready to GO
Need to get used to driving 60mph, i feel like i'm killing my car cruising at 2700rpms
Old 08-29-2009, 02:27 PM   #5
AdamBath
My Ride: E30
I did mine without a decent jack, took a little longer, but maybe like 15 minutes Its a very simple swap, even if you're lifting it up into the car on your chest
AdamBath is offline   Reply With Quote
Old 08-29-2009, 05:33 PM   #6
JJR4884
My Ride: BMW
haha that must have been fun
Old 08-30-2009, 12:12 AM   #7
E46Rida
My Ride: '04 330ci
Send a message via AIM to E46Rida
I was thinking about doing this in the future. I really hate the way first gear is so short. Whats your rpm when you're at 75-80mph? Around 3500 I'm guessing?
E46Rida is offline   Reply With Quote
Old 08-30-2009, 01:06 AM   #8
lkstaack
My Ride: 04 330iZHP, 05 325iT
My install took a few hours. As I recall, removing the half shaft bolts is tedious for those without air tools. You must turn the drive shaft every couple of bolts and then wedge something to prevent it from turning. This has to be done for both shafts. Of course, you wouldn't have to do this if you had an air wrench.
Lars
2004 330i ZHP ESS TS2
lkstaack is offline   Reply With Quote
Old 08-31-2009, 12:17 AM   #9
JJR4884
My Ride: BMW
actually its a tad over 3000........ probably 2900 at 75, 3200 at 80mph
I gotta say, I quickly noticed the higher rpms on the highway, and its helping me stay at 60-65mph
And.... after an aggressive tank of gas this weekend, i'm still averaging 22.5mpg, and i didn't go on my highways either
usually i'm at 23mpg, i'm sure that won't change
yep, put it in neutral and turned a little every 2 bolts....... definitely easy being under a lifted car
Old 08-31-2009, 12:26 AM   #10
Jelly335
My Ride: 2001 bmw 330I
Send a message via AIM to Jelly335
nice info bro. im planning on doing a 3.38 diff for my 330. got my cousins lift at his shop so i should be good. when u mean u turned the bolts a lil every 2 bolts u had to remove them evenly?
E46 330i retired
E92 335 current
<3 my one wheel wonder
http://www.cardomain.com/ride/2269710/1
-Jeremy
Jelly335 is offline   Reply With Quote
Old 08-31-2009, 12:31 AM   #11
Jelly335
ohh yea also do you need to get fluid for the new diff?
E46 330i retired
E92 335 current
-Jeremy
Old 08-31-2009, 12:33 AM   #12
JJR4884
My Ride: BMW
no, when you are removing the bolts from the drive shaft, you can't reach all 6 at one time, so when you remove one completely (or two), you'll have to turn the drive shaft to put the other bolts in the same position that way you can remove them
once you get under there you'll get it
remember, the flanges just knock right now, don't be afraid to give it a good whack
Old 08-31-2009, 02:53 AM   #13
Young Gun
My Ride: 05 330ci
You just convinced me on my next mod. Cheers!
Young Gun is offline   Reply With Quote
Old 08-31-2009, 03:30 AM   #14
brysterman
My Ride: 2002 330Ci
I want one!!!
brysterman is offline   Reply With Quote
Old 08-31-2009, 08:58 AM   #15
JJR4884
My Ride: BMW
You'll be VERY happy when you get it
Originally Posted by brysterman View Post
I want one!!!
Get one!
Old 08-31-2009, 10:41 AM   #16
AdamBath
My Ride: E30
I did my trans the same way when I replaced the clutch I really need to just invest in a damned jack already
Old 08-31-2009, 02:07 PM   #17
lkstaack
Now that I think about it, I remember that this install was easy, but turning and then locking the drive shaft every two bolts was a total PITA. I think that I had to wedge both my rear wheels every time. Of course, I was on my back by myself in the garage. Did anyone else find a better way to keep the shafts from spinning as they loosened the half shaft bolts?
Lars
Old 08-31-2009, 07:10 PM   #18
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Good to hear. I'm going with a 3.15 soon. Didn't want anything too short since I still spend a lot of time on the highway.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-01-2009, 08:49 AM   #19
AdamBath
My Ride: E30
I've got a 3.15 in my 330, and I wish I had a 3.46. The highway RPM difference is not enough to even worry about that, IMO.
Old 09-01-2009, 11:54 AM   #20
JJR4884
My Ride: BMW
using an air tool, i only had to hold the driveshaft with a firm grip, it didn't spin at all
meh... for the low end acceleration, the 3.38 is worth it. not to mention, i always drive by sound of the engine, not speed... so keeping it at 2500rpms will keep me at 65ish... i don't mind going a little slower, it will save me from getting an 80 in a 65 ticket
do you have a 6 or 5 speed?
idk i don't enjoy cruising at 80mph.... 3000 rpms sounds a little bit too much for the engine IMO, 2700 tops for me
