Old 08-30-2009, 01:30 PM   #1
M3 Baddie
My Ride: 05 M3 SMG
day time running lights...
How do they work? are they the highbeam function on the M? and can dealer turn this option on?
///M3
M3 Baddie is offline   Reply With Quote
Old 08-30-2009, 04:26 PM   #2
Phillips0417
My Ride: 03 330i ZHP
The DRL's are operated through the high beams, not only on the M's. They're supplied a low wattage (2.5V) from the LCM to be on when the ignition is on, and yes the dealer can turn them on/off.
Phillips0417 is offline   Reply With Quote
Old 08-30-2009, 05:06 PM   #3
M3 Baddie
My Ride: 05 M3 SMG
awsome TY!
///M3
Old 09-01-2009, 11:45 AM   #4
mirob
My Ride: E46 M3
if you have bi-xenons than your high beams are your xenons, hence bi, the DRL's are only used for DRL and flashing oncoming trafic
mirob is offline   Reply With Quote
Old 09-01-2009, 01:40 PM   #5
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Your dealer or someone with a GT1 can program your car to have or not have DRL
Bixenons work by raising a flap when you lock out the high beam function on your stalk:
Bixenon do not affect flash to pass - your inner "high" beam units, those are still in affect when you pull the stalk towards you.
DRL functions at 1/2 (6V) voltage - which is generally between 25-35W output - for the standard 55W H7 bulbs in your high beams.
Old 09-05-2009, 05:40 AM   #6
stapler12345
My Ride: Mineral White F30
my dealership Gault said they could not turn them off. what can i do from here
i took out the high beam bulbs so that my DRL could be on when ignition is turned on
Originally Posted by Penguin Koolaid View Post
I've never heard of a woman wanting more than she actually deserved. Never.
stapler12345 is offline   Reply With Quote
