Old 09-02-2009, 11:56 AM   #61
phlfly
My Ride: 325i wagon
Originally Posted by dkirby147 View Post
This is all correct. As a general rule, you should size your wheels and tires such that the tires' outer diameter is as close to OE as possible.
Yes and no. The angular speed is the same at any point of the wheel/tire, but the linear speed is not. Regardless, my previous posts address how increased mass moment of inertia affects acceleration and braking... not steady speed.
If you keep the same tire OD and width then you are correct that the mass moment of inertia of the tires would decrease, but not enough to compensate for the increase in mass moment of a heavier (or even equally heavy, but larger diameter) wheel. As far as it's significance to the bigger picture, that depends on several other factors. A lighter car, a less powerful engine, a lower drag coefficient, or less rolling friction would all increase the percentage change in acceleration/braking due to a change in mass moment of inertia. As I said before, the effects would be more noticable on a 318 over an M3. Ultimately, it's up to the driver, if he/she notices or cares about any performance degradation. What's insignifcant to you, might be significant to someone else.
For the record, I can't wait to retire my 17" M68s for 18" TR Motorsports MT1s. Just waiting for the funds.
BTW 68 style is a lightness wheel for E46 model, according to some link has posted here to German website.
I was reading on Porsche forum about same problem, so they came up with dyno test for HP, so difference between 19 and 20, so hp loss was like a couple HP, but I think it's loss of the inertia only. In other words: you have a open road, so with lighter wheel/tire you will go to 100 mph for time X, but with heavy wheels it would time Y to reach same 100 mph.So the weight and tires would a make difference, because your drag will increase with weight, but HP should be same.
But narrow tires will decrease cornering performance and start up performance(narrow tires on rear, because we have rear wheel drive car, but front wheel drive will opposite to it).
<img src=http://img36.imageshack.us/img36/8432/img3889copy.jpg border=0 alt= />
phlfly is offline   Reply With Quote
Old 09-02-2009, 12:03 PM   #62
mkodama
mkodama's Avatar
Originally Posted by richyboycaldo View Post
OK, so how many "HP" are we talking around here? I had intake, header, and thn I upgrade for CSL reps, does that mine that my car is as fast as before the mods with 17s?. If yes, then when a noob asks, "what can I do to make my car go faster?" the first answer should be "Lighter wheels!". Because to be hones, 5 to 10 hp is not noticeable except on dyno or track, so If you guys are "feeling" it that means it must be good at least 15 hp.
If a noob asks that question, give them a and tell them to search. Most often there are 18, have no money, and expect increased performance from a cheap intake and exhaust, and they don't comprehend the fact that weight slows a car down.
Old 09-02-2009, 12:32 PM   #63
Kubica
My Ride: 2003 325xi
Where are you guys getting data for oem wheel weights? I need the link . . . .
Anyone know how much the Z3 style 42 16"x7" weigh? I'm thinking about getting a set for the track and put some Star Specs on.
I just don't want the setup to weigh more than my 18lb. BBS RC's
Old 09-02-2009, 12:45 PM   #64
mkodama
mkodama's Avatar
search noob!
plenty of places
http://felgenkatalog.auto-treff.com/
http://wheelweights.net/
http://bmwfans.info/
Old 09-02-2009, 01:13 PM   #65
richyboycaldo
My Ride: Mx5 300zx 240z 330c
"The tires were removed and measured for circumference and set on the scales to record weight. The stock steel wheels and 185/R70-13 were 6 feet, 3/8 inches in circumference and checked in at 29 lbs. Then, Nitto 205/ZR40-17 tires were mounted to 17-inch aluminum alloy wheels. This combo measured 6 feet, 2 1/8 inches and tipped the scales at 38.5 lbs. The upgraded combo was 9.5 lbs heavier and 1.75 inches more in circumference. Back to the dyno. The DX was brought to peak power and suffered losses throughout its entire rev range. At peak, 3.8 ponies were lost, but drops as high as 6 hp were realized at 70 mph. Ouch."
richyboycaldo is offline   Reply With Quote
Old 09-02-2009, 01:15 PM   #66
Kubica
My Ride: 2003 325xi
Well . . . this lists them at 8.6kg
http://bmwfans.info/parts/catalog/Z3...ross_spoke_42/
And this lists them at 9.9kg .. .
Old 09-02-2009, 01:24 PM   #67
Chris-TK
My Ride: Mk VI GTI
Go with 2nd site. That lists them as 21.78 lbs. each which is about right. The 8.6 puts them at sub-20 lbs...which I find hard to believe.
K.
Chris-TK is offline   Reply With Quote
Old 09-02-2009, 01:25 PM   #68
spikester550
My Ride: 330ci, 86.5 hardbody
Send a message via AIM to spikester550
i didnt notice a thing with my 19 vmr csl and when i got spacers.... the car felt sticker and easier to get off the line and alot quicker through the corners
MODS
ESS TX2, 3.38 Diff, K&N CAI, 19" LM's, UUC TSE3,
30 LED AE, OEM MT2 Front & Rear,
CF CSL Trunk, Black Kidney Grills, Smoked Corners,
Painted Reflectors, M3 Steering Wheel,
ZHP Shift Knob, Clutch Stop, Shark Injector,
15mm Spacers, 3k DDM HID Fogs, OEM M3 Hood,
Coilovers, UUC Sways, and many more..
spikester550 is offline   Reply With Quote
Old 09-02-2009, 10:07 PM   #69
nightrunner20
My Ride: will eat your dust
Send a message via AIM to nightrunner20
Yea but u have a 330 LOL on a 325 I feel it really bogged it down. (AND im guessing u have a stick too)
nightrunner20 is offline   Reply With Quote
Old 09-02-2009, 10:55 PM   #70
Chris-TK
My Ride: Mk VI GTI
doubt it.
K.
Old 09-03-2009, 01:26 AM   #71
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by ChrisTKHarris View Post
doubt it.
Miles, I like this guy. He calls BS when he see's it.
Old 09-03-2009, 01:41 AM   #72
mkodama
mkodama's Avatar
Yes, I Chris too.
You shoulda seen him on some of the E90 forums when a vendor made a statement about their wheels that wasn't entirely true. Chris was on top of it, and then I think the vendor got pissed and decided to be kinda creepy and started stalking Chris on E46fanatics.
Old 09-03-2009, 01:47 AM   #73
dmon_101
My Ride: has sexy fogs/shoes
Send a message via AIM to dmon_101
Yes, I Chris too.
who hasn't done that?
Dealer Programmable Options | Projector Fogs FTW
There are a lot of Fs and too many Ks in the F/M/K scenario <- posted before I met my wife
To answer your question, it's something you can find by searching the forum or using Google
dmon_101 is offline   Reply With Quote
Old 09-03-2009, 01:53 AM   #74
Chris-TK
My Ride: Mk VI GTI
I don't know you, but I from what I've seen...
Yes, I Chris too.
K.
Old 09-26-2009, 10:07 PM   #75
RAFF112
My Ride: 325ci M3 cbr 600rr
I really wanted to ditch my Style 44 and get rep e90 M3 18
RAFF112 is offline   Reply With Quote
Old 09-26-2009, 10:14 PM   #76
Chris-TK
My Ride: Mk VI GTI
k
K.
Old 09-26-2009, 10:20 PM   #77
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
this makes me want style 68's.
I never knew they were 20.9439149 pounds
firefirefire90 is offline   Reply With Quote
Old 09-27-2009, 10:41 AM   #78
bobtoronto
My Ride: 2003 320i
I have style 43 7Jx16 - quite light at 20.7lbs (bmwfans.info).
I won't be doing 18" wheels on a 320i! I can't spare the horses ....
Bob
  • 2003 320i - 5MT - Sport Package - 3.38 diff
bobtoronto is offline   Reply With Quote
Old 01-09-2010, 01:20 AM   #79
nightrunner20
Bob
haha smart man! yea thats the sacrifice.
Old 01-09-2010, 03:29 AM   #80
andrewboi
My Ride: PY M3
Interesting thread to read as I was considering the v710s. Would love to hear other 18'' v710 owners chime in. I am switching from 18'' m3 oem wheels to these in 18'' non-staggered. I am guessing I won't notice much difference will I?
andrewboi is offline   Reply With Quote
power, wheels
