Old 09-01-2009, 08:52 PM   #1
rkneeshaw
My Ride: 330i ZHP
OS Giken LSD in a ZHP with 3.07
OS Giken's app chart shows their diff available for AT 330i's so I sent in a question inquiring if it would fit in MT cars first of all, but more specifically in my ZHP with its 3.07 final drive. Their response:
Regarding our OS Super Lock LSD for the E46 BMW 330i with Manual Transmission, it is compatible with units equipped with the 3.46 and 3.38
final gears. It is not compatible with 2.93 final gears, due to the different gear height/thickness and its relation to where it "sits" on the
differential case.
Regarding your 3.07 final gear, we have not performed a test fitment for that final gear ratio.
If the differential equipped with the 3.07 final gear is compatible with either 3.46 or 3.38 final gear ratios, then you should be able to successfully install our LSD into your application.
Any experts on here know if, based on this response from OS Giken, their LSD can be installed in my ZHP with its 3.07 final drive?
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 09-01-2009, 09:02 PM   #2
AdamBath
My Ride: E30
You should be able to install it just fine, but why not go 3.46? You've got a 6 speed, and a 3.46 would put you in your power band every time you go to downshift, its well worth it.
AdamBath is offline   Reply With Quote
Old 09-01-2009, 09:40 PM   #3
rkneeshaw
My Ride: 330i ZHP
I figure the 3.07 will be nice with the extra power of a SC... .someday
I guess what would answer this question is if someone can tell me if its possible to fit a 3.46 final drive onto the same open diff that is in the zhp
2003 BMW 330i ZHP
Old 09-11-2009, 12:42 PM   #4
Terp1
My Ride: '01 325CI
Very interested in this. Also wondering where the cheapest place is to get this? Not to hijack but I'm a complete noob, as you can see from my number of posts. Would I need to get the LSD from OS Giken, and then the 3.46 gears from a junk yard, or would they come as a complete diff? Thanks for your help.
Terp1 is offline   Reply With Quote
Old 09-11-2009, 02:29 PM   #5
apollotrance1
My Ride: '02 330i, '05 GSXR1k
The LSD should have the final drive ratio installed when you buy it. And I thought all those final drive ratios were interchangable??
apollotrance1 is offline   Reply With Quote
Old 09-11-2009, 02:32 PM   #6
rkneeshaw
My Ride: 330i ZHP
I'm still a noob but I've only heard of folks swapping the entire diff pumpkin to get the 3.46, then the drop in a LSD into that. Not sure if the clearances inside the pumpkin are different....
2003 BMW 330i ZHP
Old 09-11-2009, 02:44 PM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
Some will sell you just the LSD mechanism, some will sell a complete final drive assembly. I haven't seen anyone advertising the OSG as a complete final drive (doesn't mean it's not available, I just haven't seen it) so you will likely have to provide the final drive and then have the LSD built in place of the open diff. I purchased a complete final drive assmebly with a 3.23 gear set and LSD through Koala Motorsport. All I had to do was swap pumpkins
Old 07-12-2011, 02:36 PM   #8
rkneeshaw
My Ride: 330i ZHP
Looks like Turner is selling the OS Giken unit but only for 3.46, not the 3.07. Maybe that means its not compatible with the 3.07 gear set....?
2003 BMW 330i ZHP
Old 07-12-2011, 03:14 PM   #9
ZeroSum
My Ride: 05 325
I can confirm it is not compatible with a 3.07 as I have tried to bolt it in (the ring gear is too thick). I am pretty sure it will only work with a 3.23 and upwards.
ZeroSum is offline   Reply With Quote
Old 07-15-2011, 05:19 PM   #10
rkneeshaw
My Ride: 330i ZHP
Thank you Zero, that is very good to know
2003 BMW 330i ZHP
Old 07-15-2011, 07:24 PM   #11
Another BM
My Ride: 330ci
How much was it??
Another BM is offline   Reply With Quote
Old 07-15-2011, 07:37 PM   #12
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by Another BM View Post
How much was it??
About $1800 + shipping + bearings($300) & labor.
Minimum $2500
SUMMIT POINT WV 1:24:229 SCCA
Old 07-16-2011, 09:45 PM   #13
rkneeshaw
My Ride: 330i ZHP
Yep, turner sells them now
Minimum $2500? so $400 minimum for the install? Got to be a way to do that cheaper.
2003 BMW 330i ZHP
Old 07-19-2011, 05:09 PM   #14
murph1379
My Ride: 2006 M3
Call Diffsonline. It'll work for the 3.07, but not the 2.93. $3k.
murph1379 is offline   Reply With Quote
Old 07-19-2011, 05:16 PM   #15
mvrk10256
My Ride: E30 325i
for 3K just get an e30 with a factory LSD (4.10 gears) and keep the e46 stock.
Old 07-19-2011, 07:06 PM   #16
ZeroSum
My Ride: 05 325
[QUOTE=murph1379;13393881]Call Diffsonline. It'll work for the 3.07, but not the 2.93. $3k.[/]
Interested to see if this is true, it no way fits straight in though, the thicker ring gear pushes the whole LSD to one side. Please let us know!
Old 07-21-2011, 03:20 PM   #17
murph1379
My Ride: 2006 M3
Well last winter I did call diffsonline, and that's the quote I got to put an OS Giken LSD in a 3.07 ZHP diff.
I ended up having Performance Gearing rebuild my existing 2.93 LSD, but Diffsonline *said* they could do it.
Performance Gearing can do an LSD in a 3.07 for about $2k, the main difference being that the OS Giken will never require a rebuild, whereas most other clutch type diffs will eventually wear out.
Wherever you get your LSD, I'd recommend talking with your builder about your expected use. The LSD can be tuned differently for tighter or bigger corners, and won't necessarily work as well if it's not tuned for your expected use. What works well on a road course with a high-HP car doesn't necessarily work as well for autocrossing.
