Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 06-13-2010, 02:43 PM   #181
JimmyOberg
My Ride: BMW 330Ci 2001
This is one way to get a LSD E46 non-m.
E30 188 diff vs E46 diff.
E36 Diff cover
These are also from E36, And fits fine with the E30 diff and E46 halfshafts.
New mounting brackets...
Then I guess you're ready to go.
JimmyOberg is offline   Reply With Quote
Old 06-13-2010, 03:47 PM   #182
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
WOW!
so you modified the subframe to fit an e30 diff?
can you please elaborate?!!!!!!!!!!!!!
...i knew there were guys that have retrofited lsd's into their cars, but everyone keeps about it. lol
SL Blak Soldier is offline   Reply With Quote
Old 06-13-2010, 07:31 PM   #183
tinkwithanr
My Ride: '00 323i + '75 2002
damn.... lotta work but it gets the job done.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 06-13-2010, 08:08 PM   #184
bigdog2003_99
My Ride: 2009 Audi B8
wow thats pretty sweet, i never thought of doing that, maybe thats what ill do to the 323ci
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 06-14-2010, 01:53 PM   #185
JimmyOberg
Originally Posted by SL Blak Soldier View Post
WOW!
It's not my car.
I can ask Patrik who is the owner if he can do a little write up of how it's done... And I can try to translate it. Or if he see's this thread maybe he will post some info himself, I know he has an account here.
Old 06-14-2010, 04:07 PM   #186
Patrik_S
My Ride: E46 325ti
Originally Posted by JimmyOberg View Post
It's not my car.
Well, its not that hard doing the 188 diff installation into the E46 subframe as you may think. I`ve investigate lots of alternatives when I build my E46 325ti race car. There is some options from BMW Motorsport and Drexler that fits right into the E46 diff housing that were used in supertouring, but its pretty expensive. The 210 diff from M3 is to heavy and dont work that smooth as the 188. Quaife could work, but this is no alternative for me due to the functionality. I had a couple of 188 diff`s in my shop "over" from previous race car builds so my option was pretty easy
I will post some pictures and try to explain how to do this operation.
Take some measurments and notice that the 188K (E46) diff`s input shaft/output shaft dont center as the 188 (E30) diff.
Its important that the 188 diff center based on the drivshafts not based on the input shaft.
Name:	E46 subframe_inga fästen_low.jpg
Name:	mått subframe.jpg
Name:	mått subframe kardan medbringare.jpg
Name:	E46 subframe_low.jpg
Name:	mått subframe drivaxel cc.jpg
Name:	mått underkant kardanmedbringare.jpg
When you have all the measurments, its time to fix the subframe into a "rigg" or something and start to manufacture the new mounting points.
Some pictures from the first modification i made:
From the second one:
The E30 output shaft will fit the E46 drive shaft with just a little modification.
Finally, some pictures from me and my brothers race cars E36ti and E46ti
last year setup:
this year:
Name:	E46_på _liften_premiär!.jpg
Patrik_S is offline   Reply With Quote
Old 06-14-2010, 04:20 PM   #187
SL Blak Soldier
Wow!
Great work man! Love the ingenuity! That's a pretty good alternative to going with an aftermarket lsd. Relatively cheap also.... as long as you have some welding skills.
Great job!
-Raj
Old 06-20-2010, 07:12 PM   #188
mrshelley
My Ride: 2004 330i
That just seems like 100X the work over taking out an existing diff, sending it out, receiving it in a week and reinstalling it. Jim at Performance Gearing installed his first e46 LSD in my car back in 2000. The first two burned up and the third one worked like a champ. That diff lasted from 2002 to 2008. Then the diff ran 2 hours at Mid-Ohio with no oil in it (the left axle came out of the diff). At that point, it needed to be replaced. That diff lasted 25,000 miles of Grand-Am competition without a diff cooler.
With all of the options out there to just send the diff out, I don't understand why you'd want to modify the subframe to install another type of diff for a regular old track car.
Since Jim has been installing LSD's in e46's for 10 years, he probably has plenty of experience to get you what you need and something reliable.
If you want a real challenge, try installing a M5 diff into an e46 m3 with a one piece Pankl driveshaft attached to a Hewland gearbox.
Old 06-20-2010, 09:36 PM   #189
tinkwithanr
I don't know about everyone else, but I can't afford to send out my diff. the e36 lsd I picked up cost me $100. Add at most another 150 for machining a new end flange and another 100 for getting the backlash adjusted correctly and I should have have an lsd for well under the $1500-$2000 that the aftermarket units cost. It's not like I need it to hold up to constant track abuse, just spirited driving and the occasional autocross event.
Old 06-20-2010, 09:57 PM   #190
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
There's still more to it than that.
Old 06-20-2010, 10:03 PM   #191
tinkwithanr
Is there something major I'm missing? I'm not trying to like a douche, just want to see if what you've researched match up with what I've figure out so far.
Old 06-20-2010, 10:06 PM   #192
SL Blak Soldier
I gotta say, i'm just totally confused on what you guys are talking(arguing) about.
I think mr.shelly was talking about why do all the modification to the subframe to fit an e30 lsd, instead of just getting an carrier?
I'm not sure what Brady is implying.
Old 06-20-2010, 10:13 PM   #193
aggieE46
Keep it clean
aggieE46's Avatar
There's quite a bit that I've gotten from a GOOD source, but he's asked me not to share his name. You can't just shift over the LSD unit, it'll be off center. You not only need to shim the casing, but you'll need to have the other side bearing seat ground down. You'll need to shim the internals to make up for the shift in center. You'll need to do something about there not being circlips inside the e36 unit to clip in the stub shafts. Also, if you're using a 3.15 or higher, you'll need a spacer plate for the pinion gear.
I'm still debating if I want to do all of this, although it would be fun and cool, or just scrap it. I'm actually at a crossroads with my car and life situations, so I may be rethinking some of my plans.
Old 07-11-2010, 09:11 AM   #194
Another BM
My Ride: 330ci
this has been the most disappointing thread i have followed in a very long time
Another BM is offline   Reply With Quote
Old 07-11-2010, 11:32 AM   #195
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Why? Have you posted up quality content and had people say it wasn't any good? That kind of disapointing?
Please clarify.
I have found this thread packed with neat information...and I'm not "new" to E46 diffs....
Old 07-14-2010, 10:53 PM   #196
B6T
My Ride: 330Ci
their whole deal is they cnc'd a piece that i saw was taller then that pictured above. long enough to push the whole unit to one side so that both sides sits flush and perfect.
There is a problem with this. The splined flanges that bolt to the driveshafts go through the differential casing and engage a mating spline inside the differential itself. If you are shifting the differential to one side, as your differential shop has suggested, you are reducing the depth to which the flanges on that side of the different can engage the splines in the differential. If you don't have enough contact area (i.e. depth), you can strip out the splines on a hard launch (etc.).
In my opinion, this isn't a good idea. I'm with the guy saying that it's a good idea to buy a purpose built limited slip unit.
B6T is offline   Reply With Quote
Old 07-14-2010, 10:57 PM   #197
B6T
My Ride: 330Ci
Tell me if this is possible:
Swap the rear covers from from the E46 differential to the E30 differential. Design/machine a pair of brackets that spans between the two mounting pads on the top of the E30 diff that provides a mounting boss in the position compatible with the E46 subframe.
This is the approach i would attempt.
Old 07-15-2010, 08:37 PM   #198
Another BM
My Ride: 330ci
Please clarify.
The information in this thread has been amazing and the effort was great so far...
the only disappointing part is the LSD never got complete with the e36 guts..
Thats all.
no disrespect to the all those who posted information. I just really hope someone can complete this project
Old 09-08-2010, 07:44 PM   #199
Thaniel
My Ride: 06 E90, 01 330
All good stuff. Big thumbs up to all that have contributed information. The swaping in the E30 diff got me thinking. Any other diffs that would fit? Changing the mounts isn't really all that difficult if one can weld (I can).
Would like to see the end results on the changing the internals of the E46. Are there any other BMW internals that would fit better? Anyone tried E30 guts?
Thaniel
My LS1 V8 into E36 and then E46 Blog
www.LS1BMW.blogspot.com
Thaniel is offline   Reply With Quote
Old 09-08-2010, 07:49 PM   #200
aggieE46
Keep it clean
aggieE46's Avatar
E30 guts are the same as e36 guts
differential, e36m, housing, limited slip differential, lsd
