Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 11-09-2009, 08:11 PM   #41
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
lol. meh. been either lazy or busy. haha.
the next two weeks i definitely won't be able to work on it. turnin 21 and going to vegas. maybe after that i'll be able to get this put in.
/shameless plug for my bday.
SL Blak Soldier is offline   Reply With Quote
Old 11-10-2009, 02:49 AM   #42
SoundOfSpeed
My Ride: Clownshoe
Hey, you're cute
Ghery
SoundOfSpeed is offline   Reply With Quote
Old 11-10-2009, 08:11 AM   #43
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Make sure you actually make it BACK from Vegas.
Old 11-25-2009, 12:44 AM   #44
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Any updates ?
Old 11-25-2009, 02:31 AM   #45
SL Blak Soldier
no. to be honest. i kinda died out on the idea of fitting it in there. it's going to take some more grinding which i don't want to do. maybe later on i'll pick up the project again.
Old 12-21-2009, 09:58 AM   #46
aggieE46
Keep it clean
aggieE46's Avatar
Boo. You suck!
Old 01-27-2010, 12:04 PM   #47
aggieE46
Keep it clean
aggieE46's Avatar
I'm not planning on letting you forget about this.
Old 01-27-2010, 12:04 PM   #48
aggieE46
Keep it clean
aggieE46's Avatar
Send me the guts, I'll try to fit it into my old 2.93. I don't mind grinding.
Old 01-27-2010, 05:06 PM   #49
SL Blak Soldier
Okay, okay. i have a day off tomorrow. i'll go buy some more pads and take the angle grinder to it some more.
Old 01-27-2010, 05:11 PM   #50
aggieE46
Keep it clean
aggieE46's Avatar
Heck yes you will. Post results, I'll be waiting. Make an impact on the community, Raj!!!
Old 01-27-2010, 05:16 PM   #51
SL Blak Soldier
Hmm so something i noticed the last time i looked at the diff (actually a few weeks ago). If i grind more into the sides to make it fit, i'm going to slowly cut into the inside of the output shaft hole. I don't know how to explain it any better, but if anyone has ever pulled their diff apart the part where the bearing rest will be cut into a little. Do you guys think that will effect anything?
Sorry, i'm a noob at differentials. it's my first differential i've taken apart.
And also, i probably shouldn't grind down the ring gear to help it fit right? as that will throw off the balance?
Old 01-27-2010, 05:20 PM   #52
aggieE46
Keep it clean
aggieE46's Avatar
I wouldn't grind the gear, now. Post a pic of what you are talking about on the grinding.
Old 01-27-2010, 05:21 PM   #53
SL Blak Soldier
I'll get to it tomorrow. I'm on lunch right now and by the time i get home tonight it'll be dark.
Old 01-27-2010, 05:22 PM   #54
SL Blak Soldier
Actually you could see it in this pic.
See how if i grind more, it'll start to go into the bearing seat? do you guys think that will be a problem?
Old 01-27-2010, 05:23 PM   #55
aggieE46
Keep it clean
aggieE46's Avatar
Cool, I'm counting on you All the non-M guys are!
Old 01-27-2010, 05:25 PM   #56
aggieE46
Keep it clean
aggieE46's Avatar
Possibly. The guy that you got this idea from, did he have any pictures of his grinding?
Old 01-27-2010, 05:31 PM   #57
SL Blak Soldier
No he didn't. Let me find the thread he posted.
http://www.dtmpower.net/forum/e46-3-...nto-330ci.html
^ original thread. then i asked dhim for any other tips and he didn't really reply. lol.
Old 01-27-2010, 05:40 PM   #58
aggieE46
Keep it clean
aggieE46's Avatar
Yeah, he really doesn't say what was done to install it.
Old 01-27-2010, 07:01 PM   #59
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
This is a really cool thread! It looks like the LSD center section ring gear mounting flange is larger than the open, could you just machine that down or does it hit on the ring gear itself? Seems like taking a little off the ring gear wouldn't be a huge deal.
Tim
tim330i is offline   Reply With Quote
Old 01-27-2010, 09:48 PM   #60
TxZHP04
My Ride: ESS TS2+ ZHP
Keeping the rotating components balanced might be a bit of a problem though.
differential, e36m, housing, limited slip differential, lsd
