Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 02-16-2010, 06:21 PM   #101
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Use the attachment feature!!!
I want to see
Tim
tim330i is offline   Reply With Quote
Old 02-16-2010, 07:12 PM   #102
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Listen to Tim!
So, the only thing you're going to have to deal with is the spacers for the bearings? So cool...
Order some good fluid and get this moving... I'm going to start looking for an E36 differential
I want to see
Tim
Old 02-16-2010, 07:47 PM   #103
Another BM
My Ride: 330ci
Originally Posted by aggieE46 View Post
Listen to Tim!
ha, im glad your not in toronto or i would fight you for one...
Another BM is offline   Reply With Quote
Old 02-16-2010, 09:19 PM   #104
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
Well Brady, I think shimming it out is going to be the hardest thing yet.
As you could see.. the diff with the ring gear sits more to the right side. I'm going to have to buy that cnc'd piece that one company will sell me to space it out mroe on the left.
SL Blak Soldier is offline   Reply With Quote
Old 02-16-2010, 10:40 PM   #105
TxZHP04
My Ride: ESS TS2+ ZHP
Let me guess, your next project is gonna be a ship in a bottle?
Old 02-16-2010, 11:42 PM   #106
I_Miss_My_///M
My Ride: 325i-RIP, '03 330Ci
This, my friend, is freaking AWESOME!!!!
I_Miss_My_///M is offline   Reply With Quote
Old 02-17-2010, 02:49 AM   #107
SL Blak Soldier
hahahahah. yeah, maybe.
And I wouldn't buy any e36 lsds just yet. I wanna make sure i could finish this up. The part i'm getting is through a hook-up, I still haven't talked to them yet, so i don't know if they will be willing to sell this product to the general public. The grinding was the easy part, i just lagged it. It could definitely be done in about an hour or two with the right grinding stone. Finishing this up, and shimming it up will definitely take more effort.
Old 02-17-2010, 07:48 AM   #108
aggieE46
Keep it clean
aggieE46's Avatar
I believe in you.
Seriously, thanks for doing the work on this. We appreciate it!
Old 02-17-2010, 02:06 PM   #109
aggieE46
Keep it clean
aggieE46's Avatar
Took my stocker apart today
Old 02-17-2010, 03:56 PM   #110
alibusoul
My Ride: 04 330Ci
Hahahahaha Brady you would lol
if this works out, I have a feeling that there r gonna be a shit ton more N/A 330 builds... And also some baaaaayyyuuudddd little 330s running around
alibusoul is offline   Reply With Quote
Old 02-17-2010, 04:02 PM   #111
aggieE46
Keep it clean
aggieE46's Avatar
Raj,
Quick question. We were goofing around with mine today. From your pictures, it looks like it's just the one side that needs shimmed, right? We were guessing 3 ways of doing it. Spacing out the bearing, which seems like the hardest idea. Having a spacer cut to put on the flange that holds the bearing onto the LSD, or having a new race machined for the one side. I guess I was wanting to know, do you think you're going to have an issue with the output shaft clicking in?
Wait, does the CNC'd piece shim out the ring gear to bump the whole case right in the middle?
No... that can't be right. We're guessing the best thing to do is to either space out that flange from the body or have a new race made.
Old 02-17-2010, 04:02 PM   #112
aggieE46
Keep it clean
aggieE46's Avatar
I'm so excited, man. Poor man's LSD
Old 02-17-2010, 04:55 PM   #113
SL Blak Soldier
Raj,
Yes, only one side would need to be shimmed as the carrier sits more right.
As far as the output shafts go; i already checked with the carrier and the splines are correct, and it will click in. As far as will it click in when the carrier is in the housing and it's spaced far... that i'm not sure. i'll check it out tomorrow, as i have another day off.
And then the CNC plate i think spaces out the bearing on the left side. If you look at the e36/e30 lsds, they have a removable plate that holds the bearing. I think the cnc plate they have will space it out. I'm going to try and contact the diff place tomorrow and see if they could answer some questions of mine.
Tomorrow i'm going to try and mock up the diff with the race & everything (if i remember how to put it back together). and see what problems we will run into.
Old 02-17-2010, 04:57 PM   #114
aggieE46
Keep it clean
aggieE46's Avatar
Awesome, that's the plate we were thinking about spacing out. I'm sure I could have a machine shop do that for me. Super cool.
This is going to work out splendidly...
PS, you'd better get this going quickly or I'm going to have this done before you
Old 02-17-2010, 05:52 PM   #115
aggieE46
Keep it clean
aggieE46's Avatar
Woot. Found one locally. Too bad I'm broke. If I can come up with a few bucks, it's mine...
Old 02-17-2010, 07:25 PM   #116
n2Bimmer
My Ride: Loves Corners
Damn dude, Good job.
Old 02-17-2010, 09:23 PM   #117
SL Blak Soldier
LOL, i know right? you've already taken apart your stock diff. lol.
Old 02-18-2010, 02:45 PM   #118
aggieE46
Keep it clean
aggieE46's Avatar
I'm getting someone lined up to make me the spacer...
How thick does it need to be? Can you get the exact difference in height between the 2 units? I guess it'd just have to be the exact difference, probably needs longer hardware, too.
Old 02-18-2010, 03:02 PM   #119
SL Blak Soldier
Well, I don't know how to correctly place/line up the input shaft, so i wouldn't be able to get you an exact measurement. I have to go read up on how to rebuild a diff, so i could make sure everything is good.
I'll also mock up hte diff today, so i'll update later today.
Old 02-18-2010, 03:03 PM   #120
aggieE46
Keep it clean
aggieE46's Avatar
Measure without the shafts in. Just do from compressed bearing to compressed bearing, if you can.
If not, no worries, I can do it when I get it in hand. I just thought I could get machining started. If you can't get one through your hookup, I can have a couple made.
differential, e36m, housing, limited slip differential, lsd
