Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
Old 11-12-2009, 09:08 AM   #21
Zelaya
My Ride: 02 325i
Originally Posted by HAFPAST3 View Post
Hey what brand opener are you using? I did the installation without a hitch until i got to the programming. The homelink just WON'T LEARN THE SIGNAL from my GENIE transmitter!!!
I've a craftman garage opener and I did exactly what says in homelink instruction but I ended up going all the way to step 4 which was I went to my garage module (located in the ceiling) and just press the red button but don't hold it or otherwise will reset the whole thing and I came back to the car and press button #1 for maybe 3 seconds until I heard a click and flash from the garage module and that was it. Please note that the universal remote will only work while the key is inserted in the ignition. Good luck
http://www.homelink.com/programming/programming.taf
Originally Posted by BM-MAN View Post
I second that!! Excellent stuff man. Getting my opener installed soon. Now to find a cheap module. Can't wait to see your Parrot bluetooth DIY. I want that exact setup.
Check this seller which I bought one from him he might have another one for sale.
http://forum.e46fanatics.com/showthr...893&highlight=
Zelaya is offline   Reply With Quote
Old 11-21-2009, 07:47 AM   #22
Camelius
My Ride: M3 Vert
Does the car have to be prewired for Homelink? If not, is it just power, light and ground wiring? I'm not sure if the euro models have this prewiring.
Camelius is offline   Reply With Quote
Old 11-21-2009, 03:21 PM   #23
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
It is basically power/ground wiring. You can tap into a bunch of stuff for that around your dash and headliner area
delmarco is offline   Reply With Quote
Old 12-25-2009, 02:57 AM   #24
Mike00135
My Ride: BMW
Question
Can't find the wire is their a chance my car doesn't have the wire installed?
Mike00135 is offline   Reply With Quote
Old 12-27-2009, 02:19 AM   #25
gnome
My Ride: 2003 325iT
Originally Posted by delmarco View Post
No, you can just program it from the remote control. Its easy and quick.
Hey does this HL module or the rear view mirror module work with SEARS late model Garage Door openers? I have two cheesy garage door openers on my visors (yes 2, as Sears changed the frequencies 2 years ago - one model has dark blue buttons and one model has black buttons and they are not cross-compatible.).
Not sure what vendor limits exist...?
THX
gnome is offline   Reply With Quote
Old 12-27-2009, 12:27 PM   #26
newtuner
My Ride: '04 330CI, M package
I noticed the bulge on my headliner isn't as big as the one in Delmarco's, is that only due to mine being a 2 door and his a 4? I would love to put this in so I can open the door to my parkade. Does anybody know which cars came prewired for homelink?
newtuner is offline   Reply With Quote
Old 01-09-2010, 09:14 PM   #27
York
My Ride: 01 330Ci
... Your Homelink wire harness will be wrapped up in black velvet tape and should be tucked in towards the passenger side of the car. I had to dig pretty deep to get mine out. Be careful not to damage the sunroof motor parts.
You weren't kidding! I removed my panel and found two velvet wrapped connectors. Neither was the correct one. I could not find the connector for the Homelink, I double checked my trunk for the "pre-wired" button and it was there. So, I looked again - brighter flashlight, small mirror, from the driver side and passenger side - nothing. Took a five minute break and looked again. This time I just reached my fingers as far as they would go over towards the passenger side. Almost felt like I was over the sunvisor, but I could feel another velvet wrapped wire, so I started to ease it towards the opening and bingo! From there I cut the opening in the panel, installed the Homelink and programed it. Work fines with my Lift-Master (Chamberlain) opener. Thanks delmarco for the DIY and lots of pictures.
Question: I have a 2001 330Ci with sunroof and my panel was flat. The Homelink still fit OK. Which cars have the bulge panel and will this bulge panel fit in my 330Ci?
Name:	Homelink Panel 1.JPG
ID:	344328   Click image for larger version
Name:	Homelink Panel 2.JPG
330Ci
York is offline   Reply With Quote
Old 01-11-2010, 11:32 PM   #28
delmarco
No. The roof line is shorter and wider on the coupes than on the sedan and this discrepancy is reflected in the shape and size of the attached headliner and all the pieces on the headliner the homelink hatch being one of them.
Old 01-11-2010, 11:48 PM   #29
Many330i
My Ride: e90 M3
Nice and clear diy - something to put on the radar!
Many330i is offline   Reply With Quote
Old 01-12-2010, 11:47 AM   #30
SPQR ROMAN SPQR
My Ride: 2004 325ci
Prewiring is listed on the inside liner of the trunk by the tool kit when you open it. The little round buttons tell you what was prewired.
I installed this as well last week and i have a coupe (325ci) and I did not have the bulge. The bulge is only on sedans and not coupes. I do not know why. I do not think the panel will fit but I could be wrong.
SPQR ROMAN SPQR is offline   Reply With Quote
Old 01-12-2010, 11:51 AM   #31
SPQR ROMAN SPQR
My Ride: 2004 325ci
great diy delmarco i only have two things to add from doing this myself
1) unplugging the mic and the sunroof switch was a PITA!!
Anyone else feel that way??
I had to yank from the wire bundle and rammed my knuckels on metal twice.
I thought I was going to break it
2) do not do this in the winter when its cold out either! like me when it was around 40 in the garage.
I think this is why the connectors where such a PITA to unplug and it was also why i sheared off 3 of the plastic clips.
The panel sits there still, but there is an obvious gap where those clips where supposed to go. Now I gotta go buy a new panel in the summer/spring when it gets warm out
I recommend anyone to do this, but do it cautiously and definately follow this diy, i used it and it was fantastic
Old 01-12-2010, 12:11 PM   #32
Wreckless
My Ride: E60 528xi
Nice! Bookmarking this for later
Wreckless is offline   Reply With Quote
Old 01-26-2010, 04:28 PM   #33
km4n
My Ride: 2002 325i
This one was brand new and the new style for rolling codes.
Delmarco, you mentioned that there are newer ones that are for rolling codes. How do you know it is for rolling codes since most of the ads on Ebay don't mention that.
km4n is offline   Reply With Quote
Old 01-26-2010, 10:59 PM   #34
delmarco
The buttons on the newer gen ones have the white numbers. The older ones have all black buttons.
This is the NEWER 2nd Generation Model with all the features:
This is the OLD 1st Generation Model (has non Rolling Code and lacks full remote functions):
Old 01-27-2010, 02:21 PM   #35
delmarco
hey, so what items are homelink, i.e. you mentioned that you can search for items that will turn your tv on, etc. when i search homelink on ebay it only brings back car modules..
Sorry I wasn't specific
You want to search for "home remote kits" or "remote power"
http://shop.ebay.com/i.html?_nkw=rem...link&_osacat=0
This is actually one of the kits I bought:
http://cgi.ebay.com/Wireless-Remote-...item414c861db1
They are a lot more various types of switches and remote but the most IMPORTANT thing is that it MUST BE REMOTE powered or controlled for it to work with your homelink.
Old 01-31-2010, 04:12 PM   #36
km4n
My Ride: 2002 325i
I don't see these buttons in my 02 325i. Do they put these pre-wiring buttons in Canadian models? Can someone take a picture of it and post it?
Old 01-31-2010, 04:19 PM   #37
km4n
My Ride: 2002 325i
did you guys take out the battery when doing this DIY?
Old 01-31-2010, 04:53 PM   #38
redrum0486
My Ride: 2011 328i xDrive
I don't think that is necessary at all.
| 2011 328i xDrive | Titanium Silver [B]|
Past: | 2004 330xi | Titanium Silver
redrum0486 is offline   Reply With Quote
Old 01-31-2010, 06:12 PM   #39
SPQR ROMAN SPQR
My Ride: 2004 325ci
no it is totally unecessary.
Old 01-31-2010, 07:07 PM   #40
delmarco
see first post in this PICTORIAL DIY Thread! I heard they are tons of pictures concerning the prewiring....
