Old 09-07-2009, 07:25 PM   #21
tdekany
E46Fanatic
My Ride: 2001 VR6 Jetta
Originally Posted by suprtran View Post
anyways, i ask because using running water as lubricant for clay barring upon rinsing the car after a soapy wash would save A LOT of time versus spritzing small sections after the car has dried.
It however wastes a lot of water, however I do that all the time.
Another method I use is I "rewash" the car (panel by panel) a second time and use that as the lubricant.
Try your method and see how the paint reacts. Unless it is a spot claying, polishing is recommended after decontemination.
tdekany is offline   Reply With Quote
Old 09-07-2009, 07:27 PM   #22
tdekany
E46Fanatic
Originally Posted by Eazy-E46 View Post
It's cool man all love from my side. the water method worked out just fine for me.
That is the only thing that matters.
Old 09-07-2009, 07:27 PM   #23
suprtran
My Ride: E92M | E36M | E46M
sounds good. thanks.
suprtran is offline   Reply With Quote
Old 09-07-2009, 10:04 PM   #24
THATS FRESH
My Ride: SSHNIPER
Send a message via AIM to THATS FRESH
I'm glad you said it was silly to prove a point, because I love shutting people up.
I give you, WATER+CLAY!
Jebus I seez lot's and lot's of marring! OMG someonez helpz meh!
im sorry but those pics dont mean anything. you cant see marring with that quality of pics or that type of lighting.
alot of detailers do use the leftover water from the previous rinse to use less lube or qd to save some product. i myself use the leftover water from the rinse plus clay lube. just using water may work for you, but i wouldnt suggest it. thats like using a medium grade clay on a typical clean car. youre just creating more work for yourself.
how does paint finish look under halogen lights on in the sun? but if you feel fine with just water and it works for you then let it be
to the OP, there are seveal cost effective solutions to clay lube if you dont feel like spending $5-$10 per qd bottle. ONR can be diluted to be a clay lube.
THATS FRESH is offline   Reply With Quote
Old 09-07-2009, 10:09 PM   #25
THATS FRESH
My Ride: SSHNIPER
I do this for a living, I may have a few more hours of detailing behind me.
^ is internationally known for his knowledge on detailing.
Old 09-08-2009, 12:50 AM   #26
SpecC
My Ride: 07 Scion tC, E90 330
Send a message via AIM to SpecC
water + clay is a terribad idea
it will depend on the type of clay though
however, most otc clay and clays you can buy in the US need a lubricant
asdf
SpecC is offline   Reply With Quote
Old 09-08-2009, 09:39 AM   #27
Hogan773
My Ride: 2002 325xi
I don't get the point of this method - is it to save money?
As stated already, diluted ONR can be used. Or I would think even just some normal carwash soap heavily diluted with water would work too, but I've not tried it.
Hogan773 is offline   Reply With Quote
Old 09-08-2009, 05:48 PM   #28
suprtran
it's more for convenience not to save money.
Old 09-08-2009, 06:24 PM   #29
Shuskan3
My Ride: 2004 M3
Originally Posted by thats fresh View Post
im sorry but those pics dont mean anything. You cant see marring with that quality of pics or that type of lighting.
Alot of detailers do use the leftover water from the previous rinse to use less lube or qd to save some product. I myself use the leftover water from the rinse plus clay lube. Just using water may work for you, but i wouldnt suggest it. Thats like using a medium grade clay on a typical clean car. Youre just creating more work for yourself.
How does paint finish look under halogen lights on in the sun? But if you feel fine with just water and it works for you then let it be
to the op, there are seveal cost effective solutions to clay lube if you dont feel like spending $5-$10 per qd bottle. Onr can be diluted to be a clay lube.
+1
2004 Carbon Black/Grey BMW M3
Hardwired V1 ~ Turner Motorsport Front and Rear Sways w/ Ground Control Endlinks ~ Powerflex RTAB’s ~ OEM BMW Performance SSK ~ ZHP Shift Knob ~ Painted Reflectors ~ Bluetooth ~ Satellite Radio ~ CDV Delete ~ Clutch Stop ~ Euro Tray ~ 19” CSL Wheels ~
18” OEM Wheels for the track
Shuskan3 is offline   Reply With Quote
Old 09-08-2009, 06:44 PM   #30
booboocakes
Account Under Review
My Ride: 330cic & M3
soapy water seems to work best for me! I have used just water and the clay bar has left streaks of clay, other times it has not.
I find that the soapy water lasts a little bit longer so you don't need to keep re-wetting the car!
It may depend on the grade of the clay bar as well!
I have also used spray wax and that seems to work really well because you can do the car section by section and wipe the spray wax off with a microfiber rag and the car comes out really nice!
booboocakes is offline   Reply With Quote
Old 09-08-2009, 08:31 PM   #31
ljim52
My Ride: 04 Dinan S1 M3
Guys- I wanted to respond to this thread as I was the guy who detailed Kris's car. It is not my intention to get into the great debate over water vs lubricant but to defend my client and friend since he stood up for me. It was at my doing and instruction that we used this process. I use a non-abrasive clay product and lots of water. BTW- I too use halogen lighting and we surveyed the car the whole way through. For those of you that made comments about angle or position of photos taken, you are quite correct. We all know how lighting shows the real issues of paint and clear coat. I brought my M3 out in the sunlight and let it sit there through the whole process so Kris could see the condition of my car in direct sunlight. I have clayed my car with water more times than I want admit with no adverse reactions. I give the guy props for standing up for me but felt it only responsible on my part to interject my position. I admire the work that some of you do and respect your views on all subjects relating to detailing or paint correction.
"If you don't stand for something, you'll fall for anything".
2004 M3 Vert. // Jet Black // Nav. // SMG2 // 19" Alloy Wheels // Dinan S Package // Dinan Foot Pedals // Bilstein PSS1O Coilovers // 3.91 Gears // Dinan Strut Brace // Blacked Out Grills // Smoked Corners // Orion V2 LED Angel Eyes // ION LED Turn Signals // V2 Side Marker LED's // Ground Control Rear Racing Sway Bar
ljim52 is offline   Reply With Quote
Old 09-08-2009, 09:53 PM   #32
Kris.R
My Ride: 2012 Dodge Charger
All the noob detailer's in this thread just got owned.
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 09-08-2009, 09:57 PM   #33
04yfz
My Ride: A car
May I ask why you insist on using no lube just plain water? I mean surely it isn't cost because if you use a product like ONR it costs pennies. Jet black is such a delicate/soft paint that I find any precaution to prevent marring should be taken.
04yfz is offline   Reply With Quote
Old 09-09-2009, 12:06 AM   #34
Shuskan3
My Ride: 2004 M3
Why do you insist on making this into an one side against another, your way is 100% correct and if no one agrees their morons type thread? You seem to be the only one in the thread that is not actually learning something from the posted material, and to be honest you sound to be the only "noob" detailer in this thread. Grow up!
And for what its worth I suggest that if you do not have any clay lube or quick detailer to use, mix regular car soap and water at a 1:8 mix for a great homemade lube.
Old 09-09-2009, 01:14 AM   #35
SpecC
All detailing clay, even the OTC Mother's and Meguiar's stuff, is abrasive.
asdf
Old 09-09-2009, 09:18 AM   #36
Hogan773
My Ride: 2002 325xi
Oh nooo he di-int!!!!! Huh????
This thread is ridiculous. In all respects it makes sense to have some form of lubricant (which is also a diluted cleaning solution) for the clay, which assists in the cleaning better than water alone and also helps keep the surface slippery.
Just because someone said they CAN use clay with just water without noticeable marring doesn't mean it is the ideal method. We don't have a scientific study to show whether they are cleaning as thoroughly with water alone vs a lube.
I'm all for shortcuts that make sense, but I don't buy the "convenience" thing. Why is it so "inconvenient" to spritz some form of lube from a 99 cent Home Depot spray bottle vs constantly running a hose across the area? I'm sure everyone has little personal biases and shortcuts etc that they use on their own cars but I am not feeling this one. And why does this have to become some "battle-rap" competition to defend a deficient short cut that wasn't a process problem to begin with?
Give me a shortcut that actually saves time or money please
Old 09-09-2009, 10:20 AM   #37
fisher_330ci
My Ride: 2002 BMW 330ci
The entire reason you dry a car immediately after you wash it is to prevent water spots. Water spots are partly the reason you clay a car... removing industrial fallout, sap, and whatever else is on the paint. If you dry the car first, it is very easy to do a panel at a time with out worrying about the rest of the car spotting while it dries.
Unless you are using pure filtered water, I wouldn't recommend using just plain old water.
fisher_330ci is offline   Reply With Quote
Old 09-09-2009, 10:28 AM   #38
Rooz
My Ride: 2003 M5
Yes water WORKS, but is it the BEST thing to use? No.
Its like saying "can I use just water to wash my car?" Yes, you could take a hose and a mitt, and wash your car with just water. Would it be cleaner? Yes. Is it the better to use soap that helps clean better, lubricate and emulsify dirt, etc......YES
+1 Sums the all thread up without any epic battle of who uses just water and who uses lubricated solutions.
Originally Posted by Gregg
Umnitza now provides a mechanic to install all parts ordered right in the box! It's their new "Total customer service program" that will eliminate all the haters and keep incompetents from breaking **** and blaming the vendor! When you are all set simply call INS and they will pick him up free of charge.
VIEW MOD LIST & PICS
Rooz is offline   Reply With Quote
Old 09-09-2009, 12:23 PM   #39
watchbuff
My Ride: 2005 330Ci
soapy water....did someone not read the post, and keep it lubed real good. Wash the car, and then a second rinse. Then some soapy water (car wash soap) will work as good as lube.
Fast and the furious wanna-be's are always good for a laugh at the "Green light Grand Prix" .
watchbuff is offline   Reply With Quote
Old 09-09-2009, 07:17 PM   #40
tdekany
E46Fanatic
