Old 09-08-2009, 10:54 PM   #1
EXNoodle
My Ride: 330CI
Send a message via AIM to EXNoodle
Start-Up Issue
Ok, I have had a rough idle at start-up for the past 6-8 months.
I have done the following, it has helped, but it has not gone away yet:
-Fuel filter
-CCV (cold weather kit)
-Vanos seals, valve cover, cleaned ICV, cleanded MAF
Here is the current symptom:
At cold starts, I turn the key. The engine takes a bit longer to turn on, once on, it immediately goes into a rough 300-500 rpm idle. The second I tap the gas, the engine fixes itself and idles smoothly for the rest of the ride.
No fault codes on the PEAKE tool...
I have 88K on the car.
Anyone else have this issue, and if so, how did you fix it?
Gray 2004 330CI ZHP
EXNoodle is offline   Reply With Quote
Old 09-08-2009, 11:48 PM   #2
djlinux64
My Ride: 2000 BMW 323i 5sp
Bad ECU flash? Clogged catalyst? I'm just throwing that out there.
djlinux64 is offline   Reply With Quote
Old 09-10-2009, 07:07 AM   #3
chasz17
My Ride: 2005 645Cic
Give this a try: Turn the key to on and wait 3 to 5 seconds. Then start the car. Please let me know if this helps.
chasz17 is offline   Reply With Quote
Old 09-10-2009, 07:19 AM   #4
Richy_Boy
My Ride: Alpina B3S
^ that wouoldn't eplain the rough idle, but my car doesn't want to fire up until the check light has gone out...
It might be soemthing like a leaking injector or possibly a valve seal i.e. fluid is leaking into the cylinder which takes a blip of the throttle to clear.
Rich
Alpina B3S - 3.4L, 305bhp, 267ftlb
K&N panel filter, SPAX Coilovers, M3 Sway Bar, RedStuff pads, Brembo Grooved/dimpled discs.
Richy_Boy is offline   Reply With Quote
Old 09-11-2009, 04:28 AM   #5
EXNoodle
My Ride: 330CI
I will try the key thing today and let you know.
As far as something leaking into the cylinder, I have eliminated that as a possibility. If I turn the car on, and it goes into a rough idle, it will continue until i tap the gas. I have let it go in rough idle for as long as 30 second, after that i cringe and can not take it any longer.
I should also mention it does not happen all the time, but at least 3 times a week.
I will see how i can check the ECU flash and catalyst.
Could it have anything to do with the MAF sensor? I have cleaned it, but maybe it is going bad and a little jolt of air, from pushing down the gas puts it back in check? I have already taking apart and inspected the intake lines, clean with no cracks.
Does anyone now how to check a MAF sensor? Can it be done with a simple volt meter?
Gray 2004 330CI ZHP
Old 11-14-2012, 08:54 AM   #6
EXNoodle
My Ride: 330CI
Richy Boy was right.... http://forum.e46fanatics.com/showthr...600&highlight=
Gray 2004 330CI ZHP
