Old 09-09-2009, 12:43 PM   #1
MrMartin
My Ride: 2008 335xi
Lightbulb Installation of License Plate LED lights
Hi All
I did some searching on this topic and couldn't find anthing on it. If there is a thread on this topic that does exist, please paste the link after your condesending face palm.
I ordered WeissLicht LED License Plate Illumination Upgrade from Bimmian.ca. The DIY on this is 1/5 so I know there is something small I am missing but I can't seem to find out what it is. The car is an 04 320i so I had stock filament bulbs that I have removed. Now I am stuck. Do I remove the housing or do I try to intall these directly on the old filament housing? The way it looks to me is I just dont have enough room to fit the LED's in. Even with the housing removed I am still skeptical that I will have enough room. If anyone could share some knowledge on how to install these or point me in the right direction, it would be greatly appreciated.
My apologies in advance for the crappy pics, they were taken with a blackberry.
ID:	330828   Click image for larger version
ID:	330829   Click image for larger version
ID:	330830   Click image for larger version
MrMartin is offline   Reply With Quote
Old 09-10-2009, 10:20 AM   #2
Punkz32
My Ride: '03 M3, '93 TTZ
The way I did it was just pop the covers off and put the new bulbs in. The LED bulbs I had were a little larger then the OEM ones but for that all I did was a slight bend of the tab and it went in fine.
Punkz32 is offline   Reply With Quote
Old 09-11-2009, 02:24 PM   #3
Devas
My Ride: 2011 E90 M3
Are you trying to install them on a Sedan? cause I was told by Bimmian that they dont fit sedans E46
Devas is offline   Reply With Quote
Old 02-23-2010, 05:43 PM   #4
brandonpburns
My Ride: 2000 e46
whats up plano? always cool to see another DFW e46'er
neways OP, Punkz32 is talking about LED type bulbs that snap in where the old halogens went. i believe the weiss set is true LED replacement...meaning you will need to remove the old halogen housings...if you havnt already done so, prob a good idea to remove the trunk lid liner so you can access the back of the license plate lights..im sure its prob necessary for the installation..
did you check bimmians site for install guide? they usually have an install guide or video for almost all their products
brandonpburns is offline   Reply With Quote
Old 02-23-2010, 10:35 PM   #5
Solatso
My Ride: 2001 330i
I think you can get back there by removing the carpet on the inside of the trunk lid but I could be wrong. If so there are 4 plastic plugs that hold it on, just pop them off and you should have access to that area. Beyond that I don't know.
UNDER CONSTRUCTION
Solatso is offline   Reply With Quote
Old 02-24-2010, 06:43 PM   #6
Bryan@Jlevi SW
1.888.JLEVISW
My Ride: E46 330i ZSP
Send a message via AIM to Bryan@Jlevi SW
If you bought the full LED replacement housings, it just replaces the entire housing assembly. Should just snap right in.
Bryan@Jlevi SW is offline   Reply With Quote
Old 03-22-2012, 01:02 PM   #7
barchetta316
My Ride: 04 //M3
Send a message via AIM to barchetta316
Im having the same problem as MrMartin(I have a e46 m3 w/ LED tails)... The new weisslicht LED housing is to big to just snap right in. I feel if i use too much force i will end up breaking the LED's. Cant seem to find any DIY's anywhere on this product
barchetta316 is offline   Reply With Quote
Old 03-22-2012, 04:42 PM   #8
jinxie
My Ride: 2000 BMW 323ci
I'm about to buy some myself
I'm pretty sure there are 2 different kinds from WeissLicht... one for e46 that came with factory LED tails, and ones that came with factory Halogens... maybe there's a size difference on the trunk itself?
jinxie is offline   Reply With Quote
Old 03-24-2012, 01:34 PM   #9
barchetta316
My Ride: 04 //M3
well the ones that are supposed to fit OEM LED's, dont fit lol.......does anyone know where i can find a DIY?
Old 05-10-2012, 12:25 PM   #10
hicucr
My Ride: 2005 330ci
I just got my WeissLicht in today and on the box it states to just snap it into where the old ones were, after taking the old cover and bulb out but im having difficulty too
hicucr is offline   Reply With Quote
Old 05-16-2012, 06:53 PM   #11
jinxie
Just got mine today, they went in easy, but there's a lot of other issues, so i'm reserving judgement until i can see them at night. If you are having difficulty putting them in, make sure that the contact points on the LED circuit board are going on the inside of the two contact prong thingies up in the trunk lid. (Assuming yours originally had Halogens)
Old 05-16-2012, 11:38 PM   #12
Cyanide72
My Ride: 2002 325i
I had those WeissLicht ones for about 2 weeks before I raged and binned them. The right one would ALWAYS flicker on and off and no matter how hard I tried, it would never remain lit. The left one was fine though, but it looks so horrible with one on and the other off. In the end, I trashed the entire set (equivalent of trashing $50) and bought myself the LED bulbs from Khoalty. Same effect, way less hassle. Took me less than 2 minutes to put them on and be done with it.
http://www.khoalty.com/bmw-e46/led-b...te-lights.html
Extremely pleased with them.
Cyanide72 is offline   Reply With Quote
Old 06-23-2012, 06:00 PM   #13
Kobaili
My Ride: ///M3 Dropped Top
I had the Weisslicht set on my E46 and the didn't fit correctly as advertised so I returned them. I have since bought some LED bulbs with the resistors built in. They work great with no error codes and they look sik at night also.
"Drive it Deep and Stroke it Sweet"
Kobaili is offline   Reply With Quote
led, license, light
