Old 09-11-2009, 02:49 PM   #1
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Question Springs Rates for my new ASTs?
I'm trying to decide which spring rates to go with on my new ASTs.
I'm sure that I want to go with a 650lb/in rear spring, but I'm just trying to decide what to get for the front. I'm thinking of either a 450lb/in or a 500lb/in front spring.
My confusion comes from the fact that Vorshlag is telling me to go with a 550#/in front spring and RRT is telling me to go with a 400#/in front spring
Thanks for any help and just wondering if I can get some more opinions from experiences.
SpeedDemon is offline   Reply With Quote
Old 09-11-2009, 03:13 PM   #2
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
Some info on what you do with your car would be helpful. For a street car, 400-450 is just fine.
shady3one3 is offline   Reply With Quote
Old 09-11-2009, 03:16 PM   #3
SpeedDemon
I'm more concerned about ratio between the front and rear spring rates since I've already decided that I want a 650# rear.
I'm going to be using the car for lapping days and a small amount of autocross. I'll probably do about 12 HPDE/Lapping days a year. I drive the car on the street regularly but have a high tolerance for a stiff ride. I just want to get the most neutral handling out of the car and still maintain a crisp turn-in.
Old 09-11-2009, 05:11 PM   #4
e46techtuner
My Ride: 2000 328i
I would go with what Vorshlag is recommending. Im sure they asked what you will using the car for and how much your car weighs.
iwsti.com forum has suspension calculator thread that might help.
e46techtuner is offline   Reply With Quote
Old 09-11-2009, 05:41 PM   #5
SpeedDemon
I think I'm really leaning towards a 500# front and a 650# rear spring unless someone here tells me that I'm going down the wrong path.
Old 09-11-2009, 07:32 PM   #6
oh2fly
My Ride: 2004 M3
I followed that link, and I'm not sure what you're referring to. Can you be more specific or provide a direct link to the thread/post you're talking about.
oh2fly is offline   Reply With Quote
Old 09-12-2009, 09:07 AM   #7
TxZHP04
My Ride: ESS TS2+ ZHP
I'd ask RRT for the reasons why they recommend 400/650 over a 550/650 setup. Then I'd ask Vorshlag why they recommend 550/650 over 400/650. Compare answers and see how they fit in with your goals for the car.
Also remember that you need to consider more than just spring rates. I would imagine that if you went 400/650 you might want to ditch the rear anti-sway bar completely.
Old 09-12-2009, 03:20 PM   #8
vaio76109
My Ride: Race Cars
For track use, I'd go 600 fronts.
vaio76109 is offline   Reply With Quote
Old 09-12-2009, 03:36 PM   #9
SpeedDemon
After, PM'ing vaio and talking with Vorshlag, I'm settled now on going with 550#f/650#r
I'll post a review up in a few weeks after I get it on the car.
Old 09-12-2009, 04:37 PM   #10
TxZHP04
I'm sure you'll be happy with that setup.
Old 09-16-2009, 01:27 PM   #11
murph1379
My Ride: 2006 M3
if you go 550, make sure to pick up a 30mm bar.
I've just been through a whole season of troubleshooting front end push on my AST 4200's with 550 fronts and a 27mm bar. Switching to 650's and setting the bar at full stiff finally prevented the car from being in the bumpstops up front and got rid of the push.
650/650 should work pretty well with H&R bars, I'm running 650/550 right now and it's working pretty decently. (basically just swapped my springs front to back from what I originally ordered)
murph1379 is offline   Reply With Quote
Old 09-22-2009, 02:42 AM   #12
M3it
My Ride: '02M3,325it,330Ci
Hey Murph,
So the source of your push was bottoming in front? Do you still think the diff make cause some push?
Thanks,
Rick
PS : Send a letter to the SEB to not take-back rule 14.2F, so I can keep my M-tech front spoiler lips.
Dunlop Tires / GreenFilter / ChaseCam in car video / Bilstein shocks / Enkei wheels
M3it is offline   Reply With Quote
Old 09-22-2009, 07:59 AM   #13
murph1379
My Ride: 2006 M3
I can definitely still get push if I'm already at the limit of front tire traction and get on the gas, but that's my fault, not the diff's. =] If I'm under that limit, I can feel the diff bring me around the corner nicely.
When the front end was in the bumpstops I was convinced I needed more rear end rotation, as the front end was already fairly soft. (and generally the way to fix push is to soften the front end) So I was doing all kinds of things that are against the norm for a BMW, like running almost no rear toe in and less rear camber and jacking up the rear ride height. Now I'm having to undo all of that, to get the rear end to behave, because the front is sticking much better.
When Basham did well in '05 he was using 500/500, but he was also using a 30mm front bar and 25mm rear bar. I'm using more spring and less bar, but I think I'm headed towards around the same overall roll stiffness.
Old 09-22-2009, 01:44 PM   #14
TxZHP04
What is/was your rear bar setup?
Old 09-22-2009, 01:58 PM   #15
murph1379
My Ride: 2006 M3
I use the H&R non-M bars, so 27/21, full stiff all around.
I think the H&R M bar fits up front, which is 30mm, but not the rear one.
RD were the bars Basham was using, 30/25.
I think the Hotchkiss bars are 30/25 also, and will fit non-M.
I like the H&R's for the teflon coating on the bushings, which make them nice and quiet.
I'm still trying to dial everything in using 650/550, but I may try 650/650 as well. 650/780 was too much.
Old 09-22-2009, 02:37 PM   #16
TxZHP04
Did you ever try softening the rear bar?
Old 09-22-2009, 02:46 PM   #17
murph1379
My Ride: 2006 M3
I've not, though mostly due to being lazy, it's easier to swap springs! (provided you have some lying around, which I did) Also the bar setting isn't going to make a huge change in wheel rate, maybe 50 lbs? I'm going to worry about the rear bar when I'm closer to having everything else dialed in. Right now, if anything the rear springs are too soft, so having a bit of extra bar is good.
Old 09-26-2009, 11:22 AM   #18
SpeedDemon
I think the Hotchkis bars are 30/25 also, and will fit non-M.
Two things...
The Hotchkis bars are hollow which makes them pretty different from the other manufacturers IIRC. Also, I've had the Hotchkis bars on my car now for 10 months and they are still really quiet.
Old 09-26-2009, 04:17 PM   #19
dfjaws
My Ride: E90 M3 / E86 M Coupe
To me 400F/650R sounds like a BIG difference in the rate. I'm not an expert though.
I have 550F/700R as per GC
dfjaws is offline   Reply With Quote
Old 10-07-2009, 12:39 AM   #20
SpeedDemon
For those interested, I ended up going with 550/650 and am very happy with the setup! I'm probably done going to the track for this season, but if I feel that I less understeer next season, I'll just swap out the rear 650 for a 700 or 750.
ASTs are incredible. I've had Konis, Bilsteins, and KWs now on various E46/E36s that I've had and these are by far the best!!!
