Old 09-13-2009, 02:44 PM   #1
Hinman
My Ride: 2002 330ci
Question Bank #2 Too lean?
this is the code i got when i ran a code reader on my car when the service engine light came on. a mechanic at the local shop i take my car to said it isnt a huge deal to deal with right now (he said that maybe 3 months ago). my service engine light comes on and off a lot more now, and its starting to worry me a little. apparently it something to do with the fuel injection/ trim? i'm not to sure to be honest.
is this something i should get replaced asap? or is it something me and my dad could manage to pull off?
Hinman is offline   Reply With Quote
Old 09-13-2009, 08:25 PM   #2
JB_ZHP
My Ride: 05' ZHP Dinan 3
Could be a crack in your lower intake boot, very common problem on our cars. It's about a $12-15 part you can replace in under an hour.
e46 signature
JB_ZHP is offline   Reply With Quote
Old 09-15-2009, 10:31 PM   #3
sirch
My Ride: 330i, 545i
I have the same problem as well.
Replaced the lower intake boot as Hinman suggested as it did have a crack.
DIY Replaced o2 sensors.
Dealer reprogrammed ecu.
I still have the same problem but now the dealer wants to change the o2 sensors because I orginally replaced them 3 months ago.
I'm thinking that it is a vacuum leak coming from somewhere??? Any other suggestions?
sirch is offline   Reply With Quote
Old 09-15-2009, 10:52 PM   #4
sirch
My Ride: 330i, 545i
Just thought I would add some information.
Recently change fuel filter.
Currently have the car hooked up to the computer and I'm getting range in the o2 sensor 1 in bank one and two but o2 sensor 2 in bank and one and two are pretty steady at around .45.
Intake air at 134 deg F. MAF air flow at 3.71 gm/sec. throttle pos sensor at 10.2%.
Old 10-14-2009, 02:02 PM   #5
Hinman
My Ride: 2002 330ci
okay, so i replaced the lower intake boot about 2 weeks ago, and it did have 2 big cracks in it. the service engine light came on again today, with the same problem any suggestions now?
Old 10-14-2009, 02:55 PM   #6
Kole
My Ride: e36 M3
I had a similar problem with my X5. I don't know if it could what is going on with you or not. I was getting lean codes and it turned out to be my mass air flow sensor. I tried cleaning the MAF but didn't work, so I replaced it. I then had to reset the trim values because they had maxed out trying to compensate for incorrect mass air flow signals. Wish you luck.
Limiter? Ah bob saget!
Kole is offline   Reply With Quote
Old 10-24-2009, 03:20 AM   #7
bluesolara
My Ride: 2001 330ci
how do u reset trim values??
bluesolara is offline   Reply With Quote
Old 11-08-2009, 04:26 PM   #8
rickxs619
My Ride: 330i
the real solution
Adjuster unit 1 11617544805 $212.50 +core i hade the same proble and i replace alot of parts my code was system too lean after i replace this problem was solve no more codes or wired noises on front of the engine by the manifold
rickxs619 is offline   Reply With Quote
