Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum by BimmerWorld
From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Sponsored by BimmerWorld
Old 01-21-2010, 02:17 PM   #41
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: Evo, 330Ci, Xterra
Good question.
Originally Posted by TxZHP04 View Post
I need to replace my oil pan gasket soon so I thought I would revisit this subject. Seems the only bulletproof solution is the Motorsport kit but the pricing on that makes for an expensive bit of insurance given the price of a replacement engine these days. Where would vaio's 3/4 bolt sprocket shaft slot into the upgrade heirarchy? Why doesn't this solution seem to be more common? Have any new options surfaced recently?
^No longer looks like this
Buy my::
3.46 Differential
Coolant hard line
European Head Unit
Old 01-21-2010, 03:10 PM   #42
mrshelley
My Ride: 2004 330i
Vaio's oil pump is the most cost effective solution. I suggest contacting him and get the details. If I had a street 330 and was going to track it, that's what I'd do.
Old 02-06-2010, 08:51 PM   #43
bigjae1976
bigjae1976's Avatar
My Ride: A car
I'm planning on doing the VAC baffle and Vaio oil pump then calling it day. Go balls to the wall until my engine blows up.
Old 02-10-2010, 08:32 PM   #44
SpeedDemon
My Ride: 08 M3/05 ZHP/02 325i
Are there any problems with the VAC oil baffle? Or does it do a great job compared to stock of keeping oil pressure up?
SpeedDemon is offline   Reply With Quote
Old 02-23-2010, 05:49 PM   #45
McSpeed
My Ride: 2005 ZHP TT Stg 1
Bump^
Interesting scenario I hadn't heard before: I talked to Jay(?) at Bimmerworld about their OPN w/ safety-wire and he said, without it, spinning out and going backwards with the clutch engaged would shoot the OPN right off.
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque - updated
McSpeed is offline   Reply With Quote
Old 02-23-2010, 06:09 PM   #46
vaio76109
My Ride: Race Cars
I've got it and don't appear to be suffering any oil starvation, although I've only had an oil pressure gauge installed for one race at Barber(long right handers, no long lefts). I do still run 1qt over...
vaio76109 is offline   Reply With Quote
Old 02-24-2010, 03:16 PM   #47
JamesClay
My Ride: Any BMW with 4wheels
The VAC baffle works well. We do the dual sump on pure track cars (willing to spend the $1500). It gives a little more oil pressure in all situations and better defense on starvation as well.
New 2010 BimmerWorld Racing Shirts Now In Stock - White or Black
Bimmer World
James Clay
Race Proven Performance
www.bimmerworld.com
www.bimmerworldracing.com
JamesClay is offline   Reply With Quote
Old 02-24-2010, 03:34 PM   #48
McSpeed
The dual sump works in an E46?
Old 02-24-2010, 03:50 PM   #49
JamesClay
Verifying on an engine here, but I know we have run it. I will make sure noting needs tweaking. May be a few different parts required but I know we can do it if interested.
Bimmer World
James Clay
www.bimmerworld.com
Old 02-24-2010, 04:36 PM   #50
JamesClay
We just mocked one up. We can make it work. Similar to the Z3 aluminum block setup.
Bimmer World
James Clay
www.bimmerworld.com
Old 02-24-2010, 04:43 PM   #51
McSpeed
Ha! Nice. And with this you wouldn't need an oil baffle, correct?
Old 02-24-2010, 04:46 PM   #52
Rob43
Rob43's Avatar
My Ride: 2003 BMW 331Ci, 5spd
James, i buy a lot of parts form you, and I'm very happy to see you responding to the Motorsports & Track thread that you sponsor.
Keep it up, we all would like more of your knowledge and insight.
SUMMIT POINT WV 1:24:229 S.C.C.A.
http://www.vimeo.com/8486878 (Dyno Video)
........add a sh!tload of cowbell.
Old 02-24-2010, 05:14 PM   #53
JamesClay
Correct
Thanks! I can only spread myself so thin, but I am always available via email.
Bimmer World
James Clay
www.bimmerworld.com
Old 02-24-2010, 06:58 PM   #54
SpeedDemon
Thanks for chiming in James!
If my car was a pure race car then I would have gone with that dual pickup (I had talked to Brian and Jamie about it over the phone), but I decided on going with the VAC baffle instead. I picked up some of your guys solid rubber URO engine mounts and the RE tranny mounts as well for while I'm doing the install. I also settled on VAC $300 competition oil pump... it might not be the perfect solution but I'm thinking it should work for me if they made it work for a number of seasons in World Challenge. I'm looking forward to putting everything in next week.
Old 02-25-2010, 06:45 AM   #55
McSpeed
Is there any downside to the dual sump setup off the track?
Old 02-25-2010, 08:56 AM   #56
JamesClay
In WC, we (and most other teams) used something custom in the pan a little more extensive than the VAC baffle. But the baffle definitely chips away at the problem.
Absolutely no reason this can't be used on the street - I thought about that when I typed it and not exactly what I meant. Better said - most people that make a $1500 investment are racers who are willing and accustomed to spending a little more money on parts that won't make the car faster.
Bimmer World
James Clay
www.bimmerworld.com
Old 02-25-2010, 05:03 PM   #57
vaio76109
My Ride: Race Cars
Ha, I've got the most expensive slow car there is.
Old 02-25-2010, 05:47 PM   #58
JamesClay
You guys don't have PCA and Ferrari club out there? BAM!
Bimmer World
James Clay
www.bimmerworld.com
Old 02-25-2010, 06:47 PM   #59
vaio76109
My Ride: Race Cars
Haha, well are we now talking slow cars or slow drivers?
Old 02-25-2010, 10:27 PM   #60
bigjae1976
bigjae1976's Avatar
My Ride: A car
