Old 09-15-2009, 12:36 PM   #1
lmyamen
My Ride: 00 328i
Creaking noise coming from rear of my car when leaving stop lights and at slow speeds
So i have noticed this creaking sound in my rear suspension area ( i think ). When ever i am at a stop and let the clutch out and start going theres a creaking sound coming from the rear of my car. It does this pretty much mostly in first gear at low speeds. I have no idea what it could be.. Sorry for starting to different threads about problems i am experiancing but i wanted to have specific questions answered in each thread. Thanks guys
Current XC90
Sold 00 328i.
lmyamen is offline   Reply With Quote
Old 09-15-2009, 12:45 PM   #2
TeKNiC3
TeKNiC3's Avatar
My Ride: GT-R/M3/996TT/330Zhp
Send a message via AIM to TeKNiC3
Cracked rear subframe?
TeKNiC3 is offline   Reply With Quote
Old 09-15-2009, 12:47 PM   #3
manilaboy1vic
My Ride: 2002 330Ci
i got it too.... it usually seems when i start the car up after its parked for a bit.. i hear it when i go in reverse too when letting the clutch out..
subscribed.
manilaboy1vic is offline   Reply With Quote
Old 09-15-2009, 12:49 PM   #4
manilaboy1vic
My Ride: 2002 330Ci
isnt subframe while upshifting, every gear, and its a noticable thump??
i think i know what the OP is talking about, its a faint creak, when letting the clutch out slowly at very low speeds with no pressure/load on the subframe
Old 09-15-2009, 01:16 PM   #5
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
not really. Although I will have to say, even after having my subframe repaired, the rear end of my car still creaks like a mofo
firefirefire90 is offline   Reply With Quote
Old 09-15-2009, 01:33 PM   #6
manilaboy1vic
My Ride: 2002 330Ci
hmmm i only hear a faint creak, when going in rev. or starting off super slow 1st to 2nd gear, i looked under the car when i did my suspension and didnt see anything cracked near the subframe...
i do remember seeing another thread with a differential bushing causing some creaking too..
Old 09-15-2009, 01:35 PM   #7
firefirefire90
Banned
good way to check if the subframe is bad, is while you're going, push in your clutch pretty firmly and see if you can make the rear end "clunk". This can be from diff bushings or subframe. I'd have an indy shop check it out.
Old 09-15-2009, 01:42 PM   #8
M3revspeed
My Ride: TiAg DINAN-S2 M3
Is it a faint "tink tink tink" noise? Coming from what seems like the muffler area?
M3revspeed is offline   Reply With Quote
Old 09-15-2009, 01:49 PM   #9
manilaboy1vic
My Ride: 2002 330Ci
i would think the subframe clunk or thump would be noticeable when upshifting at faster speeds..... for me, i mainly hear it when i go in rev.. very slowly.. hardly even pushing the accelerator and slowly letting out the clutch, same goes for when im in first.... letting out the clutch slowly... at super slow speeds..
actually for me its not while shifting.. from gear to gear, its while in 1st or reverse and letting the clutch out to move (slowly)
Im not sure about the OP, hes not even watching his thread.
Old 09-15-2009, 04:29 PM   #10
ujjbd16
My Ride: 330ci sport vert
I had an e46 coupe with fold down rear seats which also creaked at first pull away. turned out to be the rear seat doing it. never did figure out why. at least it wasn't anything major. worried me for weeks though. lol.
ujjbd16 is offline   Reply With Quote
Old 09-15-2009, 04:36 PM   #11
jetskier88
My Ride: 330i ZHP S/C TS2+
Send a message via AIM to jetskier88
rtab
/thread
ESS TS2+ - OEM M3 LSD rear end swap - Meth Injection - Recaros PP - Defi Guages - Dinan TB - Headers&M3 Custom Quad Exhaust - UUC LTW Flywhl - UUC SegKev Clutch - Rogue SSK - KW V2 Coils - H&R Sways - TMS Subfrme&Sway Reinfrcmnt - VMR V710 & M PS2's - Brembo X Rotors and more....
jetskier88 is offline   Reply With Quote
Old 09-15-2009, 04:37 PM   #12
Bimmer^Hue
My Ride: 330i
Send a message via ICQ to Bimmer^Hue Send a message via AIM to Bimmer^Hue Send a message via MSN to Bimmer^Hue Send a message via Yahoo to Bimmer^Hue
***********Check ur exhaust, while the car is cooled, try and move ur exhaust abit left and right and see if it sounds the same. ur exhaust can be alittle loose and its hitting something
2002 BMW 330i Titanium Silver Metallic | Gray Dakota Leather | 5-Speed | /// Sport, Winter and Premium Package
Bimmer^Hue is offline   Reply With Quote
Old 09-15-2009, 04:38 PM   #13
Bimmer^Hue
My Ride: 330i
Originally Posted by jetskier88 View Post
rtab
/thread
+1 check ur RTAB also
Old 09-15-2009, 04:40 PM   #14
TX325i
My Ride: 2003 325i
My car also does this. Can mostly here it a very low speeds. Only in the rear as well.
TX325i is offline   Reply With Quote
Old 09-15-2009, 05:37 PM   #15
manilaboy1vic
My Ride: 2002 330Ci
rtab
/thread
arent there other symptoms besides a slow start faint creak sound?
Old 09-22-2009, 07:05 PM   #16
M3revspeed
Check your motor mounts. See if its moving ever so slightly causing that tink tink noise when you accelerate. I had to replace mine.
Old 05-20-2010, 10:51 PM   #17
e36-2.0
My Ride: 330xi
ok im bumping this thread. i just replaced my RTABS with M3 rtabs with limiters and i am hearing this faint squeak/creaking noise at low speeds
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 05-20-2010, 11:58 PM   #18
magnuzza
My Ride: Black 323i
rtab
/thread
winnar!
magnuzza is offline   Reply With Quote
Old 05-21-2010, 01:50 AM   #19
Mynewbimmer
My Ride: 325CI-2004-5SPD
have you inspected your rear differential bushing and guibo?
Mynewbimmer is offline   Reply With Quote
Old 11-04-2010, 11:52 PM   #20
WFRFitness
My Ride: 2000 328CI E46
Slight thread revival here but I'm having the same exact low speed, low load on chassis creaking sound from rear suspension area. After backing up on a set of ramps, pulling the e-brake, and putting bricks under the front I got under it while someone else accelerated slightly against the e-brake. The sound is coming from the sub-frame mount to the body where it was repaired last fing September through the class action deal. I'm taking it in to be checked out Wednesday we will see if it is sub-frame bushings or a shotty repair job from last year if it's the later it will be a big and a little
http://forum.e46fanatics.com/showthr...920&highlight= it's the subframe mount failed again.
WFRFitness is offline   Reply With Quote
