Old 09-18-2009, 09:11 PM   #1
Whammy
My Ride: ZHP
Transmission Mounts DIY
Is there a DIY for changing the transmission mounts? Or does someone know what the steps are? I need to change mine, but cannot find anything.
Any help would be appreciated. Thanks!
Whammy is offline   Reply With Quote
Old 09-18-2009, 11:00 PM   #2
neil1138
I hope you have a manual
Put car on jack stands
Get underneath the car
put your jack underneath the transmission and jack up a little to support the tranny
undo the bolts to the transmission crossmember
undo the mounts attached to the crossmember...
It's as simple as that.
neil1138 is offline   Reply With Quote
Old 09-19-2009, 08:20 AM   #3
Whammy
My Ride: ZHP
I do have a floor jack and stands Manual, still working on...
Thanks Neil!
Old 09-19-2009, 01:44 PM   #4
TheDanimal
My Ride: 01 330i
I think he meant manual transmission...
TheDanimal is offline   Reply With Quote
Old 09-19-2009, 03:56 PM   #5
neil1138
The automatic is pretty much the same process but I say I hope he has a manual tranny because the automatic is larger and harder to work around
Old 09-19-2009, 05:12 PM   #6
Whammy
My Ride: ZHP
Sadly I have an automatic.
Old 03-15-2011, 07:11 PM   #7
joneperry
My Ride: e46 + S60 + Z
Are the mounts for automatic and manual e46's the same? Looking to get an aftermarket set, but wondering if it will fit with my automatic..?
joneperry is offline   Reply With Quote
Old 03-16-2011, 09:53 AM   #8
joneperry
Anyone... automatic, manual transmission mounts the same part?
Old 03-17-2011, 07:37 PM   #9
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
same part for both
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
Old 01-11-2012, 04:07 PM   #10
///MPR77
My Ride: 02 ///M3 Tri-Ped
www.realoem.com
Old 01-11-2012, 06:55 PM   #11
Sansho
My Ride: 2001 325i
The bolts on the aluminum support under the engine/transmission are stretch bolts, so you want to replace those. You'll need some socket extensions to get the bolts on the top of the mounts. As I recall, a flexible joint helped to.
Here's what BMW says on the right mount:
22 11 001 Replacing right engine mount (M54 / M56)
Remove cover from cable duct and microfilter.
Remove lower section of microfilter housing.
Release right engine mount from above from engine support arm.
Raise engine with special tool, described in Removing oil sump .
Remove front splash guard.
Release engine mount from front axle support and remove.
And on the left mount:
22 11 011 Replacing left engine mount (M54 / M56)
Remove plug and intake hose from air-mass flow sensor.
Release left engine mount from above from engine support arm.
The raising engine part talks about suspending the engine from above like this (Harbor Freight sells a bar that works):
Sansho is offline   Reply With Quote
Old 01-11-2012, 07:04 PM   #12
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
If installing performance aftermarket tranny mounts then make sure u don't over torque your bolts or else it will rattle.
sent from HTC EVO
Old 02-14-2013, 06:21 PM   #13
Cloudbase
My Ride: M Coupe, 325xiT
Does any body know if you can do this on an auto XI without dropping the exhaust? I'm temped to lower the tranny and Xfer case a little to get the main bolt that goes through the mount out.
Cloudbase is offline   Reply With Quote
