Thread Tools Search this Thread Rating: Thread Rating: 191 votes, 4.74 average. Display Modes
Old 04-10-2013, 05:22 AM   #341
Juan-kirk
Banned User
Nice information but it can be complexed.
Juan-kirk is offline   Reply With Quote
Old 04-11-2013, 10:29 AM   #342
bumere46
My Ride: E92
yeah, very few 02's had this problem.
never seen trans failure in 03's and up
bumere46 is offline   Reply With Quote
Old 04-15-2013, 08:52 PM   #343
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
That is great work! Glad to see you found your reverse issue and fixed it yourself. This is the kind of repairs I like.
I am sure this will help others who have a reverse issue.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 04-24-2013, 09:46 AM   #344
danfey
My Ride: BMW 2000 328 ci
hi! my 00 328ci A/T is hard to shift during cold weather but when the engine warm up going back to normal again? what is the prob of my tranny?tnx! i have no reverse issue ..
danfey is offline   Reply With Quote
Old 04-25-2013, 02:07 AM   #345
fishb0n3
My Ride: 323ci convertible
yea i just had the no reverse on my car 10 days ago ! but its a ZF transmission ! so i had to rebuild it !! my car have only 108k miles on it !
2002 Viper GTS "2k original miles"
2003 e39 m5
1969 pontiac GTO the judge
1990 corvette ( C4 ) ZR1
2002 325ci vert " project car "
2000 323ci vert -totaled-
2003 z4 3.0i -sold-
fishb0n3 is offline   Reply With Quote
Old 04-25-2013, 08:44 AM   #346
BMWCaptain
This is a common problem, more noticeable in colder climates.
You need to change fluid and filter first to make sure it is not a result of low fluid level.
If fluid and filter change does not fix it, then it is probably aging of seals and pistons. Just need to warm fluid up a little before taking off.
BMWCaptainE46.com
Old 04-26-2013, 11:02 AM   #347
rickcarpenter
My Ride: 2002 325x1
I have read all I can possibly find on BMW Reverse and tranny issues. I can NOT find any that are similar to mine though. I will start from the beginning... I have a 2003 325xi wagon with 130K. Bought used 2 years ago. The first thing I noticed was that I would start it cold (like winter cold in Wisconsin) and it would surge forward (in park) just an inch or so until park gear stopped it. So the trans wasn't 100% disengaged as you'd think in park. Then #2 minor symptom was that I would back out of driveway, switch to drive and get a pause (like in neutral) before it engages.
So that brings me to the real issue: When backing up I noticed a few weeks ago that it felt like I hit several intermittent patches of ice (jerking) kinda like traction control was doing something weird or the trans was just engaging and disengaging rapidly. Looking at where I was there was no icy spots. Now it does it almost every time i back up for 20 feet or more and is much worse if im backing up with more "spirit" or load.
Is this what preceded the "no-reverse" folks that I am reading about, or do i have a totally different issue? Is it even the trans? Could transfer case or diffs be doing this? Sensors?
rickcarpenter is offline   Reply With Quote
Old 04-28-2013, 05:23 PM   #348
riverjamie
My Ride: 528i
Problems with GM trany on Breather leaking oil at times
Hello, I know I don't have an E46 but I'm hoping someone my have had the same problem with a GM Trany, my Green label has GM 1-423-875 VO on it. So it seems it the same one used in the e46 series. My problem is that at times. When the car is cold and I put the car in reverse, start to back out I see oil spots on ground, sometimes as big as 4" in diameter. After many attempts to find the problem, today I finally saw that it was coming out of the top of the BREATHER on top of the GM Trany. It does seem to do it only when it goes in reverse? But I can be 100% positive? The trans was serviced about 3k ago for this problem, but the shop never saw the leak from the breather so they just went ahead and serviced the transmission. So far the car shifts good and has no reverse problem, at least not yet. So any thoughts on the AFT coming out of the Breather? I don't think that the trany is overfilled? Because it was doing the same thing before it was serviced.
riverjamie is offline   Reply With Quote
Old 05-23-2013, 06:34 PM   #349
jrcarter_2000
My Ride: 323i
Exclamation valve body
replaced the valve body after the solenoid fix didn't work, shifts from 10-30mph range are a bit harder and not as smooth as the old valve body but hopefully this fixed the intermittent reverse issue
jrcarter_2000 is offline   Reply With Quote
Old 06-07-2013, 07:48 PM   #350
CORVAIRWILD
My Ride: Diesel Subrban 325xi
I read page 1 and page 18... Interesting... I'm a former ASE mechanic, and when I ran a little shop 20+ years ago, we would rebuild the occasional tranny. I just helped my very good friend & former mechanic rebuild a 4L80E from my '93 Silverado 3/4 ton diesel. That tranny is a giant sized TH400 w overdrive and some parts even interchange. In fact the reverse drum on mine was bad, so we used one from a '72 Delta 88.
Anyhow, as I read p. 1, I have a ZF tranny in my '03 325xi wagon, and from my wife driving it 325 miles home, and me testing it 1 mile on a side street, it seems to work very well! When I get the papers needed to register the car, I will change the trans oil and filter.
Are there solenoids like in the GM tranny to flush?
I had a slite downshift flare in Mrs Acura, and was suggested to flush the solenoids w carb cleaner. I did so, and the condition diminished appreciably.
Here's the video from the Acura a few years back. I recently saw the car around, I wonder if the tranny is still working. It was a 1 owner 125k car.
In a junkyard, under a Teeruk!
CORVAIRWILD is offline   Reply With Quote
Old 06-08-2013, 09:10 AM   #351
riverjamie
My Ride: 528i
Corvairwild, yes the GM has solenoids, but my 5L40e (2000 528i) are all inside. I liked your video, just curious after you fixed the Acura did it still leak to the outside? I pull out my solenoids when I do my ATF change after running this varnish cleaner I have in my Trany from SeaFoam Trans Tune. Not sure how hard it is to remove the solenoids? Well good luck.
Here's where I'm at with my 5L40E so far.
Well today added the SeaFoam Trans Tune 8oz. at 117302. I did notice that the Pentosin ATF1 looked very dark only after 4K. I don't know what it looked like when it was change at 113K? So can only take the mechanic's word thar it was changed? I called Pentosin they said that the ATF1 should be Amber and translucent. Well it look like neither. So going to run the SeaFoam then do a purge, install new fluid (Valvoline MaxLife and filter. I watched a good Youtube video by some German guys on how to purge the system by disconnecting the return cooler line and pumping the fluid out through it, then refilling the trany, after about three times the fluid looked pretty good. So hope that will work for me? Also has anyone used the Pentosin ATF1 product? Do you know if it turns to a dark brown in a short time, like 4K?
Also as I said above I might try to remove all the solenoids and make sure the screens are clean.
Old 06-08-2013, 09:29 AM   #352
CORVAIRWILD
The Acura was a few years ago, and I don't recall any leaks, but the shifting flare was greatly diminished. Any external leak could have been simply adressed w a new O-ring. I keep 2 different (made in China) O-ring kits on the shelf
Transmission oil will carry any deteriorating clutch material in it. If the oil is dark, it's an indication of lots of wear, or overheated oil. Smell it? If it has a toasted smell, the clutches may be toast... (Get it? Burned toast?). Deposit a drop on a piece of white tissue paper. Redder is better... Magnefine offers a transmission filter. I installed one a the Silverado after the tranny was rebuilt. I think it was from Ebay, made in Australia, I think. A quality filter.
https://www.google.com/search?q=magn...ient=firefox-a
ID:	509911   Click image for larger version
ID:	509912   Click image for larger version
ID:	509913   Click image for larger version
ID:	509915   Click image for larger version
ID:	509916   Click image for larger version
Old 07-21-2013, 02:03 AM   #353
Seth9976
My Ride: 2000 BMW328i
Help
2000 bmw 328i no reverse, I replaced the solenoid in the tranny filled with new fluid and filter still won't go in R any ideas what I should do? Any input will be helpful thanx
Seth9976 is offline   Reply With Quote
Old 07-21-2013, 05:08 PM   #354
Seth9976
Ok
I pushed the car out of my driveway drove down the road and back and reverse cam back I let the car sit for a few hours and it's still working so we will see tomorrow morning if it still works thanks ill let u know how it goes I have another issue after I replaced the battery in the car the doors won't unlock only with the key
Old 07-23-2013, 08:29 AM   #355
CORVAIRWILD
Punctuation?
Old 07-23-2013, 08:40 AM   #356
BMWCaptain
Originally Posted by CORVAIRWILD View Post
Punctuation?
You could have a ZF tranny, which means you need to open your tranny and replace the reverse drum.
BMWCaptainE46.com
Old 08-14-2013, 07:23 PM   #357
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
If the solenoid doesn't fix it or you have a forward gear problem I posted a rebuild DIY in the DIY section.
http://forum.e46fanatics.com/showthread.php?t=1000845
Darrell
ddaniel1 is offline   Reply With Quote
Old 08-15-2013, 07:29 PM   #358
bmwsedan99
My Ride: 1999 bmw 323i 2003h2
which Tranny do i have
Hey everyone I have a 1999 323I 4 door sedan I have had this car for a few years and want to do a fluid and filter change I counted the number of bolts holding the pan on and came up with 20 with none missing Now all the filters I see on the internet when I go to order a filter and gasket ask if it is a 16 or 22 bolt pan and also what size torx bit is used to take the fill plug loose
bmwsedan99 is offline   Reply With Quote
Old 08-18-2013, 12:26 PM   #359
bmwsedan99
well tag on side of transmission has GM on it with other numbers and every filter I have ran across so far either has a 22 bolt pattern or 16 even the one I ordered from BMW
Old 08-18-2013, 12:27 PM   #360
bmwsedan99
filter and gasket that is
neilgotastickiedthread!, no reverse, reverse, tranny, transmission
